Question about Dream Maker Spas Pool & Spa
When you first plug your dreamaker spa in the outlet,does the pump run all the time until the temp reaches 100 degree's? my jet button will not shut off the unit.
  • Anonymous Mar 20, 2014
    The unit is an older model ez spa grey square model
    Champion:
  • 246 Answers
TURN THE BREAKER OFF FOR 20 SEC THEN TURN BACK ON AND FAST TURN ON ALL PUMP FOR 30 SEC THIS WILL BLEED ANY AIR TRAP INSIDE THE SPA
Posted on Nov 18, 2009
The OH Light keeps coming on although the temperature never exceeded 100 degrees.
check your recirculation pump it sounds like it isnt working or plugged filters
Oct 16, 2014 | Pool & Spa
When pump runs on our spa we are getting air bubbles through the jest even though the vales are closed. Dreamaker Spa older model
id say even though you think your air induction valves are closed they in fact are not , if all the jets get air in them look for leaks in pump or piping this might be more evedent if run slow or off as pump cant suck air in hole if its off , if not air induction valves can be rebuilt by obtaining the parts from mfg
Sep 26, 2014 | Pool & Spa
Hot ub heats up then heater stops working i think when i turn on the jets
your heater works when it has to with or without jets on. you won't be able to feel the temp difference on your skin because it has a very small heater coil versus 210 gallons of water. As long as the spa maintains the set temp, it's working fine. maybe your set program for the spa isn't set to your needs. check your manuel for setup and make sure your not in vacation mode, thst will drop the water temp by 20 degrees.
Jul 20, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
Spa heateer run by Balboa 500Z control box. Standard mode will not shut off. Lowering temp to 88 still gets temp up to104.what is problem?
Sounds like the temp probe is not working or is disconnected. Temp going high, motor running means that it is calling for more heat which brings both the heater and the pump on until after set temp is reached. Once reached, heater will turn off and a few seconds later the pump will shut down.
Check connections for the temp probe. If connected make sure probe is where it should be. If it is, might try to replace it before considering the control board.
Aug 25, 2012 | Garden
Dreammaker x-400 clicking sound and pump surge
This might be a problem with the topside control. When the spa is clicking, try unplugging the topside control and see whether or not the problem stops. If the jet button is stuck on the topside, the pump will turn on-off-on-off-on-off until the topside is unplugged.
If unplugging the topside worked, replace it.
Apr 11, 2017 | Pool & Spa
Spa kicks off in a cycle. needs to be reset
Dean,
Thank you for asking me to help you with your problem. However, this is either not within my level of expertise or the question is unclear or there is not enough information and I cannot help you at ths time.
Nov 25, 2011 | Jacuzzi Pool & Spa
I just installed my new X400 Dreamaker Spa. I filled it with water (although cold) and it has been warming up for approx. 18 hours and is only at 80 degrees? Is this normal? How long should it take to...
This is normal with the dream maker spa. The dream maker spas are poorly insulated, and only run 120 volts with a very small heater.
When the unit is first filled, the hot tub will not heat full time either. Most new hot tubs will have freeze protection below 50 degrees F. They will recirculate automatically using the friction and the pumps heat to warm the water above 50 degrees, and then the heating unit will kick on. These hot tubs do not heat while the jets are on high either, so once you are in it using the jets on high, the temperature will start to fall.
Now that you are up to 80 degrees, it should heat up fairly quick however.
Nov 19, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Panel reads HHO-----, no temperature display until activate jets, then shows a temperature drop sometimes down to 65 degrees ,then starts heating upwith jets going
"OH" is an overheat error. In normal function, it is used as a safety shut off if the spa water temperature reaches over 110 degrees in the event of a thermostat failure. But more commonly, (if the water temp hasn't gotten too hot) it indicates that the temp sensor(s) have failed. If you have a digital display on the topside controller of your spa, then it is a circuit board controlled spa pack. Most spa builders use the same control pack manufacturer - Balboa Watergroup. The sensor kit usually consists of 2 probes and wires that plug directly onto the circuit board. Depending on the spa, they could both be located onto the heater manifold, or one on the manifold and one mounted to the tub making direct contact with the water via a thru-wall sensor mount. If I knew the spa manufacturer, I could further assist you. If you replace the sensors, and encounter the same problem... then the circuit board is bad, and usually a costly replacement. The sensors are usually listed as a "BA sensor assy" Hope this helps you,
Dec 24, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
QCA Opal hot tub display reading OH.
The tub experienced an overheat situation. This may be due to leaving the t stat turned all the way up and not monitoring or the hi-limit sensor is defective. The hi-limit sensor will shut down the heating cicuit if temp gets above 105 D optimally.the fact that the heater light is on is a good sign that things are working at this point.Whether or not a suitable temp(100-103 D) will be arrived at is to be seen. If spa heat kicks off before set temp is reached then replace hi-limit sensor.
Apr 10, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
Pool & Spa Logo
383 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
