Question about Panasonic PT-50LC13 50" Rear Projection HDTV
TV HAS COLOR BALLS A LITTLE LARGER THAN GOLF BALLS, COLORS VARY, RED, GREEN, BLUE, ETC. THANK YOU.
  • 336 Answers
Hi,it seems you are experimenting a light engine problem.This is how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo So basically the 3 Lcd chips that create the colors and image is going bad and thats why you get that color discoloration.Contact Panasonic or look for your light engine online.God bless you and your house!
Posted on Nov 17, 2009
Testimonial: "thank you, I will check into that."
    Problem Solver:
  • 18 Answers
WELL IT SOUNDS LIKE YOU ARE HAVING PROBLEMS WITH THE LCD CHIPS ONE OF THEM IS STARTING TO BURN OUT,YOU NEED TO REPLACE THE OPTICAL BLOCK
http://www.discount-merchant.com/PANASONIC-1117B1I-Optical-Block-p/1127630.htm?click=48428
Posted on Nov 18, 2009
Testimonial: "THANK YOU"
We have a JVC LT-32JM30 and recently for no reason at all, the picture color has messed up, we have tried resetting and adjusting the tinit, etc but nothing works. Everything is a varying shade of green or...
an internal degaussing coil circuit is already installed in the unit to neutralized color pattern...a loose solder connection may have caused this because as it operates temperature increases between the thermistor..
Jul 15, 2011 | JVC AV-27530 27" TV
Projection is messing up. Too much red and blue color.
A CRT projector requires Convergence and Color balance adjustments from time to time. These settings can drift. What you are seeing is a lack of Green color intensity. Do you see some pink in the 'whites'?
The Green CRT surface also burns off faster than the Red and Blue leaving behind the same appearance. As long as your Green CRT is not too burned by gaming or watching Golf and football, a local tv tech will be able to dial it in for you.
Jan 07, 2010 | RCA HD52W56 52" Rear Projection HDTV
Color not right
HI
you have defective RGB Circuit The Red, Green, Blue, You have shorted Green Circuit in Crt circuit this needs to diagnose to locate the shorted parts...
Thanks!
Apr 12, 2009 | Zenith B27A11Z 27" TV
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
What type of fuse does a 1992 volkswagen golf use?
is it called a blade fuse ,could be blue,yellow,red,green,brown etc color designates amp size.
Oct 08, 2008 | 1992 Volkswagen Golf
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Color problem
CONNECT YOUR DVD PLAYER TO SOME OTHER TV .IF THE COLORS ARE OK ,THEN YOUR TV IS AT FAULT .
THE COLORS OF YOUR TV CAN EASILY BE RE ADJUSTED BY A TV SERVICE MAN.
THE CORRECT RATIO OF RED ,GREEN ,BLUE NEEDS TO BE ADJUSTED .
Jun 02, 2008 | Sanyo DVW-6000 DVD Player/VCR
Picture color - it is a blue and green picture- no other color- looks artificial
update your tv with a usb drive. worked on my phillips 60PP9200D/37. get update at phillips web site. solves many problems
Jan 18, 2008 | Philips 60PP9200D Television
Bad Color - Not much red
picture tube is goin bad............
Dec 28, 2007 | Sony KV-32S26 32" TV
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
106 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
