Question about Jabra BT350 Bluetooth Headset Headset
Can not pair my bluetooth., I can find the PIN
Can not pair my bluetooth., I can't
find the PIN number
  • 11 Answers
Try 0000. this is usually a default PIN for many brands.
Posted on Nov 18, 2009
Whatis the bluetooth pin for samsung c6112
check the bluetooth in settings go into bluetooth .. turn on bluetooth and phone will scan for devices to pair with. The other device will show if it has bluetooth on and set to discoverable.
Under available devices on your mobile touch with finger it will try to pair and say boothtooth pairing request. Confirm passkey is {whatever number it generates} to pair with {whatever device it is pairing with } note what the number is and press ok. At the top of the screen is a note says visable to all nearby bluetooth devices . the box needs to be ticked and other device should have same pass code when it tries to pair. It will ask you to confirm code.
Jan 12, 2018 | Cell Phones
Need pin code
Bluetooth pin numbers can be any four digit number you like as long as you input the same four digit number into both the headset and the phone ie 1234 or 0000 when you are pairing them together
Apr 28, 2011 | Samsung HKT450 Bluetooth Headset
Motorola h715 bluetooth pin number
Try '0000' (four zeros), which is the code chosen by the vast majority of bluetooth devices' manufactures.
I was able to find the user guide for the H710 headset, but unfortunately not for the H715. It's here, anyway. Hope you find it useful, somehow.
Cheers! Carlos
Apr 18, 2010 | Motorola Mobility H710 Bluetooth Headset
When trying to connect my mobile via bluetooth to my car phone it says sim rejected why ?
We suggest you to reinsert the sim once again and check for the same. And try to perform the following steps: Apply the Bluetooth Pairing Helper application to your BlackBerry smartphone. Download the Bluetooth Pairing Helper application file using your BlackBerry smartphone browser Note: The Bluetooth Pairing Helper is available for BlackBerry smartphones running BlackBerry Device Software 4.2 and later. Complete the following steps for the Bluetooth Pairing Helper software. The following steps use the Land Rover as an example. Place the vehicle into pairing mode. For instructions, see the vehicle user manual. Start the Bluetooth Pairing Helper application. See links above. The following message appears on the BlackBerry smartphone: Please initiate the pairing process on your car. Click ?Done? when pairing is complete On the vehicle, press the Dial button. The following message appears on the Land Rover, and the progress bar on the Bluetooth Pairing Helper Application begins to advance: Searching The Land Rover display lists the name of the BlackBerry smartphone (and any other Bluetooth devices found within range). This may take one or two minutes. On the vehicle display, use the dial to highlight and then select the BlackBerry smartphone. The vehicle displays a random personal identification number (PIN) to pair. When the BlackBerry smartphone prompts for a PIN, type the PIN shown on the vehicle display in step 8 and press Enter. The BlackBerry smartphone displays Pairing complete. Connect to and press Yes. Pairing completes and an Connection to vehicle succeeded should appear on the BlackBerry smartphone. If the Bluetooth Pairing Helper application does not close, click Done to close the application. If you find the same error as sim rejected even after performing the steps, you need to check with the service provider relavent to the sim problem.
Oct 18, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Pin number
The pin number for pairing every bluetooth is 0000.
I hope that solves your Problem, If so kindly accept it.
Thank You,
Arjun.
Apr 10, 2009 | Motorola Mobility H550 - Bluetooth Headset...
I don't know the pin number to my bluetooth HBM-730
Are you trying to pair these two devices? In that case enter any number as your PIN when prompted and enter the exact number in the other device when it asks for. PIN number is asked when you try to pair two or more bluetooth devices. PIN can be any number but make sure you enter the same number in all devices.
I hope it helped.
Feb 10, 2009 | Cell Phones
Bluetooth pairing
that motorola is in the series of bluetooths that all have 0000 for pin numbers and they are NOT changeable.
turn bluetooth off push the button with the phone on it until lited LED turns Purple immediately release and open mic, now it is ready to pair.
then go to the phone tool>bluetooth> search for device enter pin 0000
it will then verify and Voila you are set
Nov 25, 2008 | Motorola Mobility HS850 Consumer Headset
Forgot how to par my bluetooth PLT 510 to my Palm Centro
To pair with a Bluetooth device:
  1. Make sure the device's Bluetooth radio is on.
  2. Set the handset's Bluetooth discover mode to On.
  3. Select the appropriate Bluetooth accessory.
  4. Enter your PIN number.
Once a Bluetooth accessory has been paired with the device, it can be used with the device, without the need for re-pairing, assuming the appropriate profile exists for the required service.
Sep 16, 2008 | Plantronics Lands Phones
Jabra BT350 Bluetooth Headset Headset Logo
353 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Michial Gueffroy
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
