Question about Intel Pentium 4 1.7G, 1.7 GHz (p41700400256sk478) Processor
No sound after formatting my pc everything works but i can not get any sound from the speakers i have tried all the usual things but i keep coming up with there are no active devices available
  • 4 Answers
Did you install the sound driver? try to install the sound driver if u didnt, and try to reset the bios to default.
Posted on Jan 10, 2008
Detected a problem with sound device keeps coming up
Please correct sound driver install. If you are correct install then go to control panel and sound and audio device click and check all points. If all thing ok then one time windows format may be solved your problem. Because some file miss but not error show that time format windows and solved all problem. If not format windows then you are check sound to another computer, you identify what a problem.
Thanks..
Oct 27, 2013 | Dell A215 Computer Speakers
My ASUS K50IJ sound comes from only one speaker. I've tryed everything and the balance seems ok
One of the speakers failed or it has a bad connection.Most likely the non working speaker will need to be replaced.
Mar 29, 2013 | ASUS K50IJ-C1 Notebook
Sound comes out of the moniter but not my speakers they worked before but i messed with things i dont know about to try and get sims 3 working for my daughter
You probably have a single speaker jack on your computer. It sounds like you unplugged the wire to the speakers and plugged in the wire to your monitor.
Aug 05, 2009 | Sony Audio Players & Recorders
Sony vaio audio driver problem
if not anything open the system and check the connections sounds like you have hit on everything else besides that
Jul 21, 2009 | Sony VAIO VGN-FS840/W Notebook
No sound at laptop speaker but audio output is ok
I have lenovo notepad 3000n100 with winXP sp2.
I downloaded realtek audio from ibm site and installed.
Now sound is coming at my output port but the in-built laptop speaker is not giving any sound output.
The hardware is ok as the sound was coming at in-built speaker before formatting. The previous audio driver set up file i have lost.
Plz help.
Apr 16, 2009 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Desktop pc
Yes the laptop will stay connected, for the sound problem, check the cable of your speaker and the amplifier of the speaker sounds a leaky capasitor, try a different speaker.
Nov 03, 2008 | Computers & Internet
Acer speakers- no sound!!!!!
Check the socket of your speaker to the computer if they are on the right socket.
Re-install the sound driver of your computer if you dont see an speaker icon at your task bar usually found at the right side of the task bar.
Oct 04, 2008 | Acer (90.18612.36B) Computer Speakers
Sound
Make sure your volume is not on mute. If the speaker icon on your lower right has a red x means its on mute. To test go to control panel and double click sounds and test. If Windows sounds work without speakers then problem is with speakers. Make sure volume is up, make sure its properly connected to correct output jack (usually green or light green). Also make sure speaker power on. If those things are correct check your device manager ( right click my computer) select "manage", click on "device manager" and on right pane check to see if theres any yellow exclamation, question mark or red x on the sound device section. Yellow exclamation or question mark means to update or install correct drivers. Check your speaker box if it comes with a CD.
Jul 29, 2008 | Dell Inspiron 530s Desktop Computer...
Compaq monitor speaker
If everything worked before you moved it, I would try checking the simple things 1st.
Make sure that the plug from the speakers is plugged into the correct hole in the back of your computer. Usually, the color of the plug for the speakers and the jack are GREEN.
If the power isn't coming on the speakers, then I would make sure that you have the correct power plug (If the speaker type that you have, has a removable power supply).
What you can to to test out the speakers, is plug the speakers into an IPOD or a MP3 player and test it out.
This will at least eliminate the possiblity that the speakers/wires/power supply are bad.
Hope this helps.
Good luck.
Feb 08, 2008 | Compaq PC Microphone (Black or Beige)...
NO SOUND FROM SPEAKERS
HI Surthi
First thing came basic, check your speakers with other PC, and see if work correctly, then use the software control volume to see if not set to "mute" connect the speakers to the right slot in the sound card, sometimes according to the colors, usually green. see if you have installed the drivers for your sound card.
good luck!
Carl
Nov 05, 2007 | HP (PP036AA) Computer Speakers
Intel Pentium 4 1.7G, 1.7 GHz (p41700400256sk478) Processor Logo
75 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
