Question about Frigidaire ATF6000ES Front Load Washer
My fridaire front load washer will not spin at high speed
  • 6,784 Answers
HI. Your unit is equipped with a Motor Speed Control Board. This board regulates the spin speed, with the help of a tachometer, which, is located and mounted on the motor. When this Control board is experiencing issues, the spin will not preform at optimal performance. I recommend to replace this Motor Control Board asap. Once replaced, the unit will spin properly.
Posted on Nov 17, 2009
Testimonial: "Thaks very much. Where Is this control board located"
  • Michael Masters
    Michael Masters Nov 18, 2009
    The motor control board is mounted in close proximity of the motor. you can access it by pulling the back access panel. It is accessible by pulling the front panel, as well.
    You may need a star wrench set with this unit. Most units of this nature will use the star, or hex screws on the back access panel.
    Problem Solver:
  • 6 Answers
You can't automatically say its the control board-you have to pull the trouble codes and see what the are. Your door lock switch could be bad and that will keep washer from spinning at high speed.
Posted on Nov 18, 2009
Kenmore front load washer model 41744052400 will not enter into high speed spin at end of cycle. I can run the test for the different cycles and can get the high speed spin, but only in the test mode. ...
Try to get the repair manual for your machine, it's worth the cost. Meanwhile, with the power unplugged, undo any wire connectors that just plug in and check for corrosion. Check the capacitor, a dent will ruin it.
Nov 26, 2013 | Hotpoint WMA64 Front Load Washer
Does not go into high speed spin
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a Frigidaire front load washer. Model #: LTF2940EE0 Serial #: XC64319573 and it is not spinning on high speeds. It is spinning but only slow. When I put it on the rinse/spin cycle it spins in low...
Motor has some shorted windings. Timer switches to higher current for faster rotation and the thermal overload protection shuts the process off as the current is too high because of the shorted windings.
Oct 04, 2017 | Frigidaire GLTF2940ES Front Load Washer
Will not go into final spin
Just a Idea, belt is slipping this is why when it is empty it works on high speed when full its to heavy and belt slips
May 06, 2010 | Frigidaire HE 3.1 cu. ft. Extra Large...
Front loader, will not spin at high speed drain
Drain strainer on output side of pump could be clogged a little.
Sep 11, 2009 | Frigidaire ATF6000ES Front Load Washer
My TROMM washer only spins on extra high speed
This washer will automatically choose the fast spin, you can do only spin, don't make the first selection "soil level", just press the spin speed then start.
Is the problem that it is noisy and shaking?
try to level the feet. The installers should have given you a wrench to accomplish that.
Jul 25, 2009 | LG WM-2277HW Front Load Washer
Imbalance
all front load washers must be very close to level because of the high spin speed
May 31, 2009 | GE WSXH208A Front Load Washer
Frigidaire front load washer will not spin
Two possible reasons the lid switch may be defective, or the spin bearing may be worn.
Aug 31, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
721 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
