Question about Whirlpool RF364 Electric Kitchen Range
How do i replace the surface element for a glass top cook top range
  • 5,911 Answers
The cook top on this model range will lift up, exposing the surface burners and wiring harness. The screws are located along the bottom of the front edge of the cooktop. You will need to open the oven door to see them. Then, just follow these steps:
Before you begin:
1. UNPLUG the range before servicing. There is dangerous voltage still present even with burners turned off.
2. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, Follow these steps:
a. Unplug the cook top and leave the elements in place.
b. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
c. Remove the bad surface element by removing only the bracket pair that the affected element is attached to. Leave the rest of the elements wired together. Write down the wire color codes so you can be sure the new element is installed correctly. HINT: A digital camera can save you some time.
d. When installing the new surface element, make sure you use the same alignment marks (the numbered positions around the perimeter) as the old element. Avoid touching the burner surface and handle with care. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure. The elements are fragile.
If the wiring harness does NOT unplug, prop the cook top in place and install the surface element from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
If you have any questions about this repair, please let me know. You can reference searspartdirect.com for some helpful exploded view diagrams of you range for assistance if you need it. I hope you find this information helpful.
Posted on Nov 17, 2009
Can one cook with iron skillet on glass top electric stove
Cast iron is NOT recommended to be used on a glass cook top due to its weight and potential for damaging the surface. Cast iron also heats rapidly and retains heat for a long time. Its great for gas stoves, but not a good idea for a glass surface.
The best cookware to use should be lighter in weight, have even heating properties with a SMOOTH flat cooking surface on the bottom for proper heat transfer. Some cookware that IS approved for use on a glass cook top is baked enamel, stainless and copper.
NOTE: Cooper and Stainless can leave marks on the cook top, but these marks do come off with most approved cook top surface cleaners.
If in doubt, always refer to your owner's manual. It explains in detail how to select the proper cookware for your range and the limitations and/or characteristics of each. If you have any questions, please let me know. I hope this helps you.
Dec 29, 2009 | Frigidaire FEF366 Electric Kitchen Range
Tip
Proper Use and Care of Ceramic Glass Cooktops
Here's some helpful tips that can hopefully ensure many years of quality use of your ceramic glass cook-top.
NOTE: It is important to maintain PROPER care of your ceramic glass cook top as they can be very expensive to replace. Prices vary between models, but most are in the $200 to $300 range. With added labor charges, this repair can cost over $600 from an appliance repair company.
WARRANTIES: Most manufacturer warranties DO NOT cover cosmetics. That is, if your cook-top paint starts to wear off from normal use, or from the selection of cookware you choose to use, manufacturers typically WILL NOT replace it. Warranties also DO NOT cover accidents such as dropping something on the top and chipping or breaking it. Some warranties WILL cover, however, blistering, warping and heat related breakage that were no fault of the consumer (as long as you were using the recommended cookware). It is important to become familiar with, and follow, all the manufacturer's use and care instructions that come with your range.
CERAMIC GLASS CHARACTERISTICS:
It is normal for the ceramic glass to change color when heated. This is especially true for lighter colored surfaces. The color should return to normal when cooled. It is also normal for the enameled or painted areas on the cook top to show signs of wear and fade over time. Proper cleaning and cookware selection can extend the cook top appearance.
It is NORMAL for the radiant heat surface elements to glow red and cycle on and off. There is a thermostat associated with each individual element that regulates the temperature. The frequency at which the elements cycle on and off is determined by the heat setting.
PROPER COOKWARE:
Use ONLY flat bottomed cookware for the best results of heat transfer from the surface elements. Cookware with warped, rounded or ribbed bottoms can cause uneven heat transfer which can result in uneven heating of the cooking surface and cause damage to the cook-top such as cracking and/or permanent surface discoloration.
An easy test you can use to determine the flatness of your cookware, is to turn the cookware upside down and place a ruler across the surface. As you rotate the ruler around the surface perimeter, you should not see any light along the ruler edge where it meets the surface. Cookware with slight indentions or expansion grooves can still be used, however.
Make sure the cookware bottom is always clean and dry before use to prevent any foreign matter from burning to the cook-top surface and leaving stains. ALWAYS place your cookware on the cook-top surface BEFORE turning the surface elements on.
Make sure the selected cookware matches the size surface element in use. The cookware surface should NOT exceed one inch beyond the radiant surface element surface.
COOKWARE CHARACTERISTICS:
The material of the cookware you select will determine how well it transfers heat and how evenly it cooks. The ideal cookware should be of medium to heavy thickness.
NOTE: A non-stick surface will take on the characteristics on the base metal used. (i.e., non-stick over aluminum, will take on the heating characteristics of aluminum).
*ALUMINUM - Heats quickly and evenly, light weight, suitable for all types of cooking tasks.
*COPPER - Heats quickly and evenly, light weight, suitable for all types of cooking tasks.
*Both aluminum and copper are great when used as a core metal cover with a non-stick or enamel surface. However, when used as a base metal, alone, they can leave metal transfer marks on the cook-top surface which will have to be cleaned immediately following use.
GLASS or CERAMIC - Heats slowly and unevenly, may scratch cook-top surface if there are any rough edges, best results are when using low or medium heat settings.
CAST IRON - Heats slowly and evenly, maintains heat for slow cooking, great for browning and frying, rough on cook-top surfaces, may scratch.
STAINLESS STEEL - Heats quickly and unevenly, a base or core of aluminum or copper can provide more even heating.
DO's and DON''T's:
DO NOT store heavy items, such as jars, cans, pots and pans above the cook-top surface. Any inadvertent dropping on the cook-top surface and cause cracks or shattering.
DO NOT lay hot lids on the cook-top surface. Heated air can become trapped under the lid creating a hot spot as the rest of the cook-top surface cools. The cook-top surface could potentially crack when the lid is removed.
DO NOT slide cookware across the cook-top surface. LIFT cookware as much as possible when moving from surface to surface. This will minimize metal transfer marks and scratching.
DO NOT cook popcorn in prepackaged aluminum containers. The aluminum could potentially melt and may not be able to be removed from the cook-top surface.
DO NOT store anything on the cook-top surface that could melt (such as plastic and aluminum foil). Once melted to the surface, some of these substances may not be able to be removed.
DO NOT store empty pots and pans on the cook-top surface.
DO NOT attempt to use the cook-top surface while the oven is on a self-cleaning cycle. The oven super heats to temperatures in excess of 500 degrees and causes radiant heat to be exhausted from the oven vent on the stove surface.
DO NOT use a cook-top that is cracked. Any spill overs could potentially leak into the radiant heat elements and create an electrical hazard.
DO clean up any spills from the cook-top surface that contains milk or sugar. You may allow the cook-top surface to cool in order to safely clean, but do not allow these substances to remain on the cook-top for extended periods. If not removed, these substances can cause permanent discoloration and stains.
DO wipe down the cook-top prior to, and immediately following use, to maintain the surface appearance.
DO NOT attempt to cook any foods directly on the cook-top surface without a pan!
CLEANING and CARE:
Clean all spills and boil overs immediately.
Any substances that become adhered to cook-top surface can be removed by wiping up excess with hot soapy water and a kitchen sponge.
Use a non-abrasive pad (the green kitchen pads are considered non-abrasive) and a straight edge razor blade, pushing in one direction to remove stubborn particles.
Some metal transfer marks (copper and aluminum) may be removed by simply wiping cook-top surface with a damp sponge. Any remaining marks can often be removed with an approved cook-top cleaner.
Use only approved, non-abrasive cook top cleaner to keep the surface clean and polished.
DO NOT use scouring pads that will dull or damage cook top surface (i.e., steel wool or SOS pads).
DO NOT use any harsh chemicals such as ammonia or bleach that can etch or dull cook-top surface.
on Apr 19, 2011 | Cooktops
Tip
Surface Burner Replacement on Electric Smooth Top Range
Steps necessary to replace one of the surface elements on a smooth top electric range.
Before you begin:
on Apr 05, 2010 | Kitchen Ranges
Opening the cook top in a Whirlpool electric range
The cooktop on this model range will lift up, exposing the surface burners and wiring harness. The screws are located along the bottom of the frotn edge of the cooktop. You will need to open the oven door to see them. Just follow these steps:
Before you begin:
1. UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
Nov 12, 2009 | Whirlpool RF378 Electric Kitchen Range
How to replace the glass for whirlpool oven serial # RPO 713144
This advice is for Electric Ranges equipped with glass smooth tops. If it becomes necessary to replace the cook top due to wear or damage, here's some helpful tips on how to complete the repairs yourself. NOTE: Cook tops are NOT cheap. Prices vary between models, but most are in the $200 to $300 range. With added labor charges, this repair can cost over $600 from an appliance repair company.
WARRANTIES: Most warranties DO NOT cover cosmetics. That is, if your cooktop paint starts to wear off, most manufacturers will not replace it. Warranties also DO NOT cover accidents such as dropping something on the top and breaking it. Warranties DO cover blistering, warping and heat related breakage (if you are using the recommended cookware). This is why it is important to follow all the manufacturer's use and care instructions that come with your range. I know this does not include ALL manufacturers, but this is true with most.
This is a recommended two-person repair job. Please read through the instructions carefully before starting the repairs, and follow any safety recommendations.
2. If the old cook top is broken, you will need to get rid of a much of the glass shards as you can and thoroughly vacuum the area around the oven box. Use extreme care when handling broken glass. Wear safety glasses and gloves.
3. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
4.On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, Follow these steps:
1. Unplug the cook top and leave the elements in place.
2. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
3. Remove the surface element assembly leaving all the elements wired together.
4. Place the new cook top face down in the same manner and lay the surface element with wiring harness directly on to it and screw in place.
5. Install the new cook top back on the range and you are DONE.
5. If the wiring harness does NOT unplug, follow these steps:
1. There are a series of screws holding the element assemblies in place. Leave these assemblies wired together for ease of replacing. It is recommended that a second person holds the assemblies in place to support the wires until all the screws have been removed.
2. Lay the intact element assembly, with wires still connected, on top of the oven box. Handle the surface elements with care. They are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure.
3. If you have to remove the elements, individually, make sure you write down how the wires were connected to ensure you reconnect them in the right order. Make sure you also take note of the numbering scheme on the element and make sure you place the mounting brackets in the same holes that they came out of. Use care when screwing into the new cook top. CAUTION: The screw holes are usually painted and a little force may be required to thread the screws. Do not apply too much pressure on the glass, or you can damage it.
4. Prop the new cook top in place and install the surface element assembly from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
5. Lower the new cook top into place and secure with screws.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 05, 2009 | Whirlpool SF367 Gas Kitchen Range
Tip
Replacing a Glass Cook Top
    Good luck and I hope this helps.
on Mar 02, 2010 | Kitchen Ranges
Tip
This advice explains the steps necessary to replace one of the surface elements on a smooth top electric range.
The cook top will lift up, exposing the surface burners and wiring harness. The screws are located along the bottom of the front edge of the cooktop. You will need to open the oven door to see them. Then, just follow these steps:
Before you begin:
on Dec 22, 2009 | Kitchen Ranges
I have a Kenmore electric range oven Model # 79095201103 that has a glass top. The top cracked and I ordered a new glass top for it. What steps do I need to do to replace the top. Is it complicated???
Here ya go...
Apr 06, 2008 | Kitchen Ranges
Kitchen Aid KESC 307 hbs4 electric range control
CESAR, THE OVEN CONTROL IS THE CLOCK,HOWEVER, ON MANY KITCHEN AID RANGES, THERE IS AN INLINE FUSE 15AMP, THAT IS IN THE OVEN CIRCUIT. I WOULD SUGGEST THAT THE INLINE FUSE BE CHECKED FIRST BEFORE CONDEMNING THE CONTROL.
DAVID, THE GLASS TOP ELEMENTS ARE CONTROLLED BY THE SURFACE SWITCH FOR REGULATING TEMPS. THE SWITCH WILL TURN THE ELEMENT ON AND OFF TO REGULATE TEMP. I WOULD SUSPECT THE SURFACE SWITCH(WHAT THE KNOB IS ATTACHED TO) AS THE DEFECTIVE COMPONENT. THERE IS A HIGH LIMIT SWITCH THAT IS PART OF THE ELEMENT. IF IT WAS BAD, THE HOT SURFACE INDICATOR LAMP WOULD BE LIT ALL THE TIME.
THE ELEMENT IS NOTHING MORE THAN A COIL OF WIRE THAT HEATS WHEN CURRENT IS PASSED THROUGH IT.
IF IT WAS BAD, IT WOULDN'T DO ANYTHING AT ALL.
Mar 28, 2008 | KitchenAid KERC607 Electric Kitchen Range
Tip
on Feb 11, 2008 | GE Spectra JBP78 Electric Kitchen Range
Whirlpool RF364 Electric Kitchen Range Logo
804 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
