Question about Poulan Garden
Leaf blower recoil won't pull - Poulan Garden
spekgt
  • 60 Answers
SOURCE: willnotrecoil
Hello . First thing is remove the starter rope and check to see if the flywheel turn by hand . If turn by hand you have a bad recoil starter , if does not turn by hand the piston is seized . Remove the spark plug and put 2 or 3 drops of oil (2stroke mixing oil) on the spark plug hole and try to turn it again by hand . If still does not turn you have to replace the piston and maybe the cylinder .
Hope this help
Posted on Aug 29, 2009
  • 62 Answers
SOURCE: my echo pb2100 gas leaf blowers pull cord is loose
COULD BE THE SPRING INSIDE THE RECOIL NEEDS MAY NEED A NEW ONE
Posted on Sep 25, 2009
mickey813
  • 472 Answers
SOURCE: Poulan wild thing leaf blower won`t start. Has
SOUNDS LIKE YOU SHULD GET YOU A NEW ONE ITS CHEPER TO GET A NEW ONE
Posted on Sep 30, 2009
rwvanlue
  • 486 Answers
SOURCE: LEAF BLOWER ON STIHL BG65C RECOIL SPRING
Parts may be purchased from your nearest STIHL dealer
Posted on Nov 11, 2009
Mike258
  • 1498 Answers
SOURCE: gmc petrol leaf blower
Believe it or not, I've had a lot of luck with local Goodwill outlets as a source for spare parts. You see a lot of what gets dropped off isn't exactly in tip-top condition and not resellable as-is.
I ask to see what they have and sometimes make an offer. They usually accept.
It turns out to be a win-win and there's nothing wrong with that.
Best of luck
Mike
Posted on Mar 23, 2010
Testimonial: "Hi I never thought of them. I will give them a try over the next few day. Thanks mate. Kindest regards Anthony"
Pull Cord has stripped and won't recoil. Can this be repaired?
Stripped? Maybe the recoil Spring just broke. Easy repair, sometimes you can just re-bend the 'Stop' on the old Spring
Nov 09, 2014 | Garden
Why won't my Poulan leaf blower pull cord turn motor over?
If the recoil is spinning free and you feel no resistance either the engine is damaged or the recoil dogs are not engaging. Fixing either of these at a shop will likely cost more than buying a new unit.
Jul 29, 2014 | Poulan Bvm200vs/bvm200le Blower/mulching...
Rewind pull cord poulansnowblower
this is an engine problem, you should of mentioned the engine or supplied numbers but if it's an older model check the one way clutch underneath the recoil... I.E. does recoil go back in when its remove, Yes then check the clutch, no replace the recoil
Dec 19, 2013 | Poulan Garden
How do I replace the recoil spring on my Husqvarna blower
I know the video shows a chainsaw but its the same principle.
Apr 22, 2013 | Husqvarna 28cc Hand Held Blower HVH 125B
Weedeater pull cord won't pull out on a leaf blower
Suggest to remove recoil housing/assembly and try to rotate the flywheel. Remove the spark plug & check for a silver or aluminum color or coating.
If the flywheel will not turn by hand, the piston/cylinder is seezed. No further repair is affordable.
If the flywheel turns by hand and the spark plug is a dark brown color, then focus your attention to the recoil assembly to see if rope is bound or wound around the rope rotor.
Nov 10, 2009 | Poulan Garden
I have a craftsman leaf blower model 335879770. The pull start doesn't engage. You can pull the cord and it recoils back but doesn't crank the engine. I have it apart but how do I get to the starter pulley...
you shouldn't have to there are little ears on the flywheel that the starter recoil hits when pulling the handle they might be stuck or not moving when pulling handle
Nov 09, 2009 | Garden
The pull cord on my leaf blower will not move
it sounds as if the blowers engine is locked up. pull the recoil cover off and see if you can turn the flywheel. if you cant the engine is locked and no good.
Oct 26, 2009 | Poulan Featherlite Gas Blower, with Low...
We have a featherlite gas blower model # F1 1500 LE - need part # for pull cord and assembly
Recoil starter pulley - Part # 530071792 (Rope & Handle NOT included)
Recoil starter spring - Part # 545008011
Hope this helps,
Dolf-
Oct 15, 2009 | Poulan Featherlite Gas Blower, with Low...
My echo pb2100 gas leaf blowers pull cord is loose and will not recoil
Sep 24, 2009 | ECHO, Inc. PB-251C Handheld Blower
Garden Logo
120 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
