Question about Paragon 4001-00 24-hr Timer Control 120v Ac Cd101
Have a Paragon 4001-00 timer that is not turning on load. Verified power is coming in to the Paragon. Have manually turn on the load, thats ok. The time is set correctly but noticed that the timer wheel has no tension, it spins easily, do not sense any tension, resistance when setting the time. After 15 minutes the timer did not move ( advance), timer still set to time set. Please advise.
  • 52 Answers
Go to electricalexpeditors.com for replacement parts.
Posted on Dec 30, 2009
Paragon model 8141-00 defrost timer wont turn.
Is this a used timer?
8141-00 is 120 volt timer.
Is your 120 volt Hot wire on terminal 3 and Neutral on terminal X?
Test across 3 and x for 120 volt.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
Don't buy used defrost timers... they always look good when you inspect, but never work when connected... that's why the timer was taken out of service and sold as used timer.
Save the old trippers for use on new timer.
Gene
Water Heater Timers Save Money
Mar 28, 2015 | Paragon Hardware & Accessories
Can i get a wiring diagram for model 7007-00 i dont know what all these terminals do thanks jason
Wiring diagrams
http://waterheatertimer.org/images/4PST.jpg
http://waterheatertimer.org/images/4PST-example.jpg
Paragon 7007-00 timer has 120Volt clock motor, and 4 switching relays.
All 4 switching relays are NO and turn on-off at same time.
Connect 120V Hot and Neutral to terminals A and B.
Terminals 1 thru 8 are dry, and receive no power when 120V is applied to A and B.
There are two terminals for each relay.
Terminal 1 is for Hot wire and terminal 2 goes to load.
Terminal 3 is for Hot wire and terminal 4 goes to load.
Terminal 5 is for Hot wire and terminal 6 goes to load.
Terminal 7 is for Hot wire and terminal 8 goes to load.
http://waterheatertimer.org/pdf/Paragon-4000-24hr-7000-7day.pdf
http://waterheatertimer.org/Paragon-timers-and-manuals.html#7000
Aug 15, 2011 | Paragon 7007-00 Electromechanical Indoor 7...
How i can do the instalation
1) Need more information.
Heres some help to get you started, then you add a comment and fill in details so I can give accurate answer.
2) You posted under Paragon 7008-00 timer.
3) People post under Paragon when they have Tork, so I need exact model number and what voltage you have and what Load you are trying to wire.
4) Also what terminals appear on timer, since any timer can be in a box that is marked 7008.
Then add what color wires you have coming from breaker box, what size breaker, and if same breaker is going to supply voltage to timer and to Load, and what color wires are going to Load.
5) Open following link to identify timer for sure, and see manual and wiring diagrams.
6) Typical wiring diagram for 7008 showing one set of NO NC terminals:
http://waterheatertimer.org/images/Paragon-7008-00-timer-wiring-350.jpg
7) 7008 timer has 120Volt clock motor. So power to terminals A and B has to be 120V.
But timer can still control 120V or 240V loads.
8) According to manual, 7008 timer has 2 NO (normally open) terminals that are OFF when timer is OFF
Timer also has 2 NC (normally closed) terminals that are ON when timer is OFF
9) Both sets of terminals reverse when timer turns ON.
10) NO and NC terminals are frequently used for continuous-operation 2-speed motors, for example.
You do not want power to both speeds at same time, or motor will burn out. So low speed is connected to NO terminal, and high speed is connected to NC terminal. This way the motors windings are kept separate, and either low speed is ON or high speed is ON.
11) Another example of NO NC terminals could be store lighting. When store closes, the timer turns off exit signs and store-room lights inside store, and at same moment timer turns on burglar alarm and outdoor lights. In this example the timer controlled 4 different circuits: exit signs, store-room, alarm, and outdoor lights. With 2-NO and 2-NC terminals, that is possible.
Apr 15, 2011 | Paragon Indoor Electromechanical Timer...
Program a timer
You posted under Paragon 2606 Panel-mount countdown timer.
If this is not your timer, add a comment.
2600 series is mechanical interval timer.
26006-00 can handle 10 amp loads.
Interval timer is a countdown timer that keeps Load turned on for set amount of time.
You set the time by rotating dial
To start timer, Rotate dial from 1 minute to 30 minute.
Rotating dial turns on Load and begins countdown.
Timer turns OFF Load after set amount of time expires.
Nov 26, 2010 | Electric Paragon 2606-00 Timer
My paragon timing motors model 1015-00RSB are not timing as desired,how can i or guide me on how to programme and make schedule adjustments on it? Please help me
http://waterheatertimer.org/Paragon-timers-and-manuals.html#1015
The Paragon 1015 timer is a 24-hour timer.
The tripper pins or tabs are built into the timer dial.
This timer has NO and NC terminals.
NO NC terminals mean the timer can control two different circuits.
One circuit would be ON when the other circuit is OFF.
When the timer turns on, the circuits change so now one circuit is OFF and the other circuit is ON.
If you have just one circuit, then the following instructions will help you.
If your timer controls two circuits, you can add a comment and I can help further.
OK, your timer controls one circuit.
Locate the tabs on the timer dial.
Push down all the tabs.
Now lift all the tabs for the times you want your Load to turn ON
So if you want the Load to turn ON from 7pm to 5am, then lift all the tabs between those times.
Now when the timer dial rotates, the tripper tabs operate an on-off lever that turns the Load ON and OFF.
Set current time of day
The timer has to be set to current time.
For example it's 6pm.
Grasp and rotate dial until 6pm lines up with the stationary red pointer
Skipper wheel:
The 1015 series has a skipper wheel that lets you skip days of the week.
On these days the timer program will not turn the Load ON or OFF
So if your regular schedule is ON from 7pm to 5am, then the Load will remain OFF for those times.
Set skipper wheel:
Locate day to be skipped on the small dial.
Raise the set screws for the days you want to skip
Raise set screw until it is tight, but do not force
After a power failure, current time of day has to be reset.
If you need more help, add a comment and I will assist.
Nov 03, 2010 | Paragon 1015-00RS Indoor Multi Operation...
Have a 4003-00 Timer for a business park outdoor parking lot lights. I need to change hte tim to come on ~ can't find the book to tell me how to change this? Can you help?
ef74fbb.jpgParagon 4000 series is a mechanical dial timer
Image explains general operation of timer
Attach Black tripper to dial at time you want lights to turn OFF
Attach Silver tripper to dial at time you want lights to turn ON
Minimum on-off period is 1-1/2 hours
Re-set dial after power outage.
The dial rotates with passing time
The timer takes the Paragon X2772 tripper
If tripper does not turn lights off-and-on, then you might need new trippers
If dial does not rotate, you might need new timer
If manual override does not work then check electricity
http://waterheatertimer.org/Paragon-timers-and-manuals.html#Paragon4000
If you need more information, add a comment below and I will respond.
Oct 27, 2010 | Paragon REPLACMENT MECHANISM 110V SPST -...
We have an AMF Paragon 4001 timer for the light outside our building. The light goes on lately at the wrong time. We want it to be on at 7:00pm and off and 5:00am but it goes on at 12:00 at noon.
To set paragon timer: Pull large round dial straight out towards you, then rotate dial until correct time is lined up with stationary 'pointer' on front of dial
Sep 08, 2010 | Paragon 4001-0G Defrost Timer
Paragon 4001-00 24-hr Timer Control 120v Ac Cd101 Logo
580 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
Steve
jdthefixer
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
