Question about BenQ FP731 17" LCD Monitor
Monitor displays breifly then goes to blank screen
Hi, Whenever I turn on my monitor it displays the computers output briefly (~half a second) before going blank. I have tried the monitor on two other computers with the same result so it is definetaly not a computer problem. The power light on the front of the monitor stays green when the screen goes blank. Whenever I turn the power off and back on again the exact same thing happens. Help please!! If i switch on the system with in one or two seconds the monitor goes blank. but the power light of the monitor remains green. if i switch off the monitor and switch it on again the display comes and vanishes with in two seconds.
  • andreascyp Jan 10, 2008
    I have the same problem...I dont know what to do...
    pls help
  • 579 Answers
The green power light indicates that the monitor is receiving from the computer correctly. I suspect it is going into high voltage shutdown. There is a safety circuit that monitors the high voltage and shuts the monitor down if it sees anything amiss. So the monitor comes on and then shuts off. High voltage problems are generally not worth trying to repair. Another example of a worthless safety feature. High voltage failures are not dangerous, and adding the safety circuit just kills the unit when it may have some life left or worse, sometimes it is the shutdown circuit itself which fails!
Hope this helps.
Posted on Jan 10, 2008
I gave my FP731 to my brother thinking that my PC was the culprit and bough myself a new system. He told me he had the same problem on his system. He brought it to students in PC repair and had it opened. They found out that it was a set of wires that were being crushed by the monitor housing. They carefully put the wires back at their place and the monitor is functinning well now. Hope this helps.
Posted on Oct 06, 2008
Same problem here with a BenQ 15" panel, the fault lies with the inverter section driving the CCFL tubes for the backlight (as the image can still be seen on the LCD panel itself).
There isn't a 'consumer' fix for the problem, it's either get an entirely new inverter board or pull out the soldering iron or hotair-reflow gun to do the job... quite probably it'll need replacement parts (output drive transistors or possibly a faulty load sensor).
Posted on Aug 08, 2008
I had same problem, same moniter seriees, as suggested get benq to fix it... they did mine in 2 days with no reciept, theyll even pick it up 4 u and bring back afta. mine was 2 years old.
Posted on Jul 24, 2008
    Champion:
  • 220 Answers
Is this a BenQ 731?
If so check inverter transistors on power/inverter board.The transistors and inverter transformers are generally dry,Resolder them.
Samir
Posted on Feb 27, 2008
  • Samir  Shah
    Samir Shah Mar 10, 2008
    BenQ has a 3 year warranty on LCD monitors.Please check out BenQ Support on www.benq.com. for local contact details.
    Samir
Hi, I have the same problem, I have also tried with differents OS with out any improvement. What I do now and works is when the monitor is working I play a video/movie and let it run in the background with muted sound, I works good, never turns blank whit this trick,I Use Totem player on Ubuntu (Linux), but it might work with other players and platforms.
Posted on Feb 25, 2008
I have the same problem, what I am doing is, when I come from work just turn on and off the moniter few time, during the on period ( when I can see the screen) I go to windows shut down screen when windows XP goes black and white. Moniter stays on on that screen. when the black and white screen stays for 4 / 5 min I cancel the shut down process and the monter work fine upto 4 / 5 hours.
Posted on Jan 16, 2008
    Sergeant:
    Champion:
  • 317 Answers
Sounds like there is a problem with the RGB Decoder.  What that means is that the monitor is not decoding the sinal properly. which explains why it comes up for a split second, and then goes blank.  I would suggest trying a different monitor connection like DVI or HDMI if you have it, otherwise it sound like the monitor is defective
I turn my monitor on and I see the display breifly
hi. it sounds like the power supply has gone bad... try to purchase a new power supply cord..
thank u
rate me
Jul 19, 2009 | ViewSonic VX800 18" Flat Panel LCD Monitor
ViewSonic VA720 Screen displays briefly then goes blank.
it looks like the Inverter's gone in your screen, it works like a starter in a florescent tube, it 'kick starts' your screen to come on. Turning it on/off many times eventually 'kick starts' your screen and makes it come on eventually.
Jan 15, 2018 | ViewSonic VA720 17" LCD Flat Panel Monitor
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Fran
Sep 07, 2008 | Proview PL926WBi 19" LCD Monitor
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
F1 = Fuse 1
You should be able to locate a surface mount fuse at your local electronics store.
Apr 12, 2008 | NEC MultiSync LCD1830 18.1" LCD Monitor
I am not familiar with your particular model, but I do know what the problem is.
The inverter that runs the lights behind the screen is faulty and needs to be repaired. The lights shine from the top and bottom and reflect outwards through the panel so you can see what is on the screen. If you start the computer up, then shine a bright light into the panel you will see an image on the screen, but very feintly.
This can be cheap, it can also be expensive depending on where you go to get it repaired. Call aorund to a few TV shops in your area to get a rough idea on prices.
Hope that helps =)
Apr 11, 2008 | Sceptre X7GNAGAV 17" LCD Monitor
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After going blank, you check that you can see the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Feb 23, 2008 | Gateway FPD2275W LCD Monitor
Wont stay on
IF there is no display even with a flashlight, the P/S board is malfunctioning. Bad capacitors or LCD driver board circuit. Mine did this and it was bad caps, 4 of 8 were bad and a burned out chip on the P/S board.
Oct 20, 2007 | Proview PL913S 19" Flat Panel LCD Monitor
Problem in monitor
Sounds like the inverter board or lamps are bad
Feb 26, 2007 | Dell E173FP 17" LCD Monitor
BenQ FP731 17" LCD Monitor Logo
774 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
