Question about Tally Genicom 4440 Printer
How do you clear print buffer on Genicom 4440XT printer?
    Novelist:
  • 169 Answers
The buffer on the 4440XT can be cleared by powering the printer OFF and then back on again.
You may however find print jobs are held in the spooler on the computer system and will simply reprint when you turn the printer back on again, you will need to check the spooler on the system also to delete any unwanted print jobs.
Posted on Nov 20, 2009
Why can't I print through a Tally T5040 printer?
Tally genicom 5040 passbook printerre download the drivers and make sure you have a good connection (USB )
Mar 21, 2012 | Office Equipment & Supplies
The printer is not printing receipts and the error indicator is blinking on and off, what is the solution to this?
Flashing (approx. once every second): Out of paper
Flashing (approx. twice every second): Mechanical error (Buzzer sounds once.)
Most likely your paper feed is giving you the error. Remove the current feed, ensure there are no paper jam & insert fresh paper.
If
Mechanical Error :: Quick blinking Buzzer Sounds continuously for a pprox. 1 second :: Reset the Power
switch
Paper End Blinks.:: Buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Paper Near End Blinks.(Once a second) :: buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Mechanical Error : If the printer mechanism has a greater load due to a paper jam, etc., the buzzer will sound and the SEL/ERROR lamp will blink to stop the printer mechanism.
Paper End : If the printer has run out of paper, the paper sensor in the paper path near the print head will detect the end of the paper roll, turn on the buzzer, and blink the SEL/ERROR lamp to stop the printer mechanism. If the paper is inserted into the paper path, the paper will be loaded.
Paper Near End : If the paper is running out, the paper near end sensor will be activated to turn on
the buzzer and make the SEL/ERROR lamp blink. Even after the paper near end is detected, a command can be used to print by the specified number of lines. (See a description on the command for setting the number of print lines after paper near end detection)
Finally
Backup Data Clear : When the power is turned on, depending on the SEL switch operation, the
backup data in the input buffer will be cleared according to the flowchart on the next page.
To clear the input buffer, turn on the power while pressing the SEL switch.
The following messages will be printed.
"Clear Data in Buffer"
"Cleared Data in Buffer"
To print the data in the input buffer, simply turn the power on.
The following message is printed and the data in the input buffer is printed.
"Power Down(Data in Buffer)
Dec 13, 2010 | Citizen iDP-3550 Matrix Printer
CANT STOP OKI 591 PRINTER TO STOP PRINTING REPORT
Check that the LINE FEED button is not jamming or on.
The LINE FEED + POWER ON will print the "Printer Character Report" or "Test Page".
May 24, 2010 | Okidata 591 Printer
T6312
The problem coming from your logic card hammer bank cable . Need to be replace logic card and hammer bank cable.
May 19, 2010 | TallyGenicom 6312 Matrix Printer
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Apr 20, 2010 | Tally T6218 Matrix Printer
I have printer genicom 4440 xt and have not a driver i want a diver for this printer thank you
Just try using a generic print driver in windows. This driver will send standard ASCII code and the printr should allow you to print standard text. try it.
Apr 10, 2010 | Tally Genicom 4440 Printer
TallyGenicom 2265+ not printing with custom paper size
There may be a number of causes for the problem you are seeing. There are a number of places which may hold the origin to the page length problem you are seeing, in order of precedence these are;
  1. The page size set in the software package printing the 6 x 4.25 cards
  2. The page size set the printer driver printing to the printer
  3. The page size set on the printer
I would recommend the follwoing;
  1. Set the form length on the printer to 6 inches (i am assuming this is the length of the card)
    The form length can be set through the menu and is normally set in lines (normaly the print size is set to 6 LPI) so the form length should be set to 33 lines
  2. Create a custom form size in SERVER PROPERTIES on the Windows XP machine to match the form size you are using.
    Ensure you select this form size in both PRINTER PROPERTIES and PRINTING PREFERENCES
  3. Try printing some Windows Test pages to see if these respect the page size selected withing the printer driver properties.
If the Windows Test Pages do not print correctly I would recommend checking how you are creating the CUSTOM SIZE form, perhaps create a new form and double check the form properties one it has been saved to confirm these are correct.
Check you are using the correct printer driver for the printer, you should be using the 2265+ printer driver. As a test you may wish to install the GENERIC TEXT printer driver or the EPSON LQ2250 driver, these will be included in the Windows Add Printers Wizard and should print OK to the 2265+.
If the Windows Test Page prints OK I think you would need to look at the software package printing to the printer. Ensure the correct page size is selected here also, perhaps try printing from another software package selecting your custom size form to see if these print correctly.
It is passable your software package is sending escape commands to the printer to call up the page size, I note you say Genicom printers printed ok from Win 98. The 2265+ may not have the same emulations as the Genicom printers.
You can print a menu print on both Genicom (if these are available) and 2265+ and compare the settings on these.
I do not believe the 2265+ has a Genicom emulation as standard, but you may be able to load an alternative version of firmware into the 2265+ which provides the Genicom emulation. If the data going to the printer contains Genicom Escape command to set form length this may resolve the issue.
You may need to contact your TallyGenicom support department for the firmware (I think it may be called 7265+ firmware)
If you are able to provide Hex Dumps of the data to the TallyGenicom support people they should be able to say what is going wrong with the form length setting.
May 07, 2009 | TallyGenicom 2265+ Matrix Printer
PRINTER PROBLEM where is my hp tool box? I HAVE INSTALLED NEW INK CARTRIDGES AND NOW MY PRINTER PRINTS OUT A LOAD OF PRINT I CANT UNDERSTAND. THANKYOU
Try double-clicking on the printer in the Printers and Faxes folder and clear any pending jobs. Turn off and disconnect the power cable from the printer for a few minutes to clear its buffer. Keep the paper removed from the tray during this process and only re-insert it after the printer has stopped attempting to print. When the spooler and buffer are cleared normal printing should resume.
Nov 11, 2008 | HP Deskjet 6940 InkJet Printer
KX-P1124 Dm Printer -- Cannot clear the buffer, keeps printing garbage
Put one page in printer and tape paper so it will not feed as buffer print out data on paper.
May take one minute or one hour, that depends on how many times you hit the enter on keyboard
You must let the printer keep printing no matter if it is one word or one letter. Some old printer do not have cancel on printer, only thru computer or program. I have three in serv. from the 70's
A buffer happen and will always happen after it get information from computer. It takes many sheet of paper
Bob
Oct 03, 2008 | Panasonic KX-P2130 Matrix Printer
Clearing buffer
Press the SEL or ONLINE key, then turn the printer off. Clear the print queue in the PC and then turn the printer on again.
May 05, 2008 | OKI MICROLINE 321 Elite Matrix Printer
393 people viewed this question
Top Tally Office Equipment & Supplies Experts
Alexey Krenvalk
Alexey Krenvalk
Computer Links
Vasil Hristov
Vasil Hristov
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
