Question about Sony VAIO VGN-AR630E Notebook
Would u know a website that i could get a single key for a key board
I have a single purple/pink line running vertically on my 40 inch samsung lcd tv 720p it goes away usually after awhile but comes back ive tried just about everything i know to make it go away permantly...
The tv board that call the T-CON decodering board is the caused.This board sit at the middle of the bottom of the LCD screen panel.Check the cableling connections or the T-CON decodering board is dying.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decodering board for the replacement.
Mar 29, 2011 | Televison & Video
Hello I had one question in regard to 865GBF motherboard intel can 2 sata port will support 2 TB of harddisk storage please let me know the ans for this. presently I am using 1.TB stoarge of sata...
most motherboards natively (now adays) support up to 1.5 tb on a single disk. with most bio's now being upgraded to support upwards of 3tb on a single disk via a bios update you just need to update your bios from intel's website and be good to go!
Mar 22, 2011 | Intel D865GBF Motherboard
Key pad problem
what can i say Maytags have many key pad problems, it is very easy to replace you will need the make , model, s/n to order the key pad board, and the board also has a number on it , The dishwashers are rally bad for keypads
Jan 19, 2011 | Maytag CWE4800A Electric Single Oven
The keys have suddenly become hypersensitive and the caps lock is stuck on. This happened after a battery change that I did with the keyboard face down on a table. I can get a single letter by barely...
I want to follow those steps but my spacebar is too sensitive, so it won't fit in the ~ key and I have the terrible HP G62 and I don't know how to remove the keys.
Nov 23, 2010 | Apple Wireless Keyboard
I want to download sound drivers in my computer eaisly how can i do this
Before downloading and installing any driver you need to know manufacturer and model number of your computer. Therefore, when you start your system you need to enter into BIOS.
Start your system, you will notice that it will also show you the keys to enter into setup. Mostly its F2 or ESC key. Press that key to enter into BIOS, get the model number of *********** board along with the manufacturer name. (It should be like a heading)
After getting model number, go to google and type in the manufacturing company and model number, for instance"dell drivers optiplex gx260" you will get the page related to the your motherboard. Select Sound and download it from the website. You do not need to spare even a single penny, it should be absolutely free!
After downloading install it on your computer and reboot it, Should Work Perfectly
Jun 29, 2010 | Computers & Internet
Hi my pc 3edc keys are dosnt work i changed new key board weeks later again same porblem
I would like to know whether it is HP branded part no. that you have changed. Because if it is HP keyboard then you can replace it with HP.
If not then I need the product no. of your notebook so I can find the correct part no. for keyboard for your notebook.
You can also purchase single keys from below website if only those 3 keys are not working instead of buying a complete keyboard.
http://www.laptopkey.com/BrowseKeys.php/HP
I hope this will help. Please revert for clarification.
Jun 10, 2010 | HP Pavilion dv1000 Notebook
I have a 24" single gas wall oven model JGRP17VEW4BB and it is displaying an F7 error code and the time. I've tried shutting off the power but it comes back right away. Do you know what part I will need...
HI. This is a basic communication issue that will concern, either the control board, or touch/Key pad assembly. Normally, this will produce a stuck key, which will cause one of the power relays to become suspended.
Determine if The problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting the key pad Ribbon Cable from control(main), and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
NOTE_ Some models incorporate the touch/Key pad into the ERC as a single assembly(Whole device), in which case this test is not necessary. Simply replace the ERC (Clock).
Jan 17, 2010 | GE JGRP17 Gas Single Oven
Missing Key , From Key Board
No, Highly Doubtful You'll Find A Single Key For A ThinkPad Keyboard...
Lenovo Parts Are Hard To Come By, Yes, You Can Get The Whole Keyboard For Under $30.00 USD On Ebay....
And Usually Someone's Offering Single Keys For Keyboards, Just None Available For Your Model At The Current Time...
Nov 25, 2009 | Lenovo ThinkPad X200 Tablet Laptop
G key not sounding
If it is a single key, then the key contact either needs cleaning or there is a crack in the circuit board with the contacts. These likely are conductive rubber contacts. Take them apart and clean with 99% isoprophyl alcohol. They are usually a black rubber "pill" in a silicone rubber dome that is pressed onto traces on a circuit board. Clean both the pi;ls and the circuit board. Do all thekeys at the same time to avoid having to take apart to do others later.
If ALL G sharps keys are dead, then either a wire is broken or circuit board connector or a crack exists in the board. Cracks in the board is USUALLY fatal.
Jul 07, 2009 | Korg Pa800 Synthesizer
Not able to type ''at the rate, hash, dollar sign etc
Can you please try pressing and holding Shift and then pressing the single quote key ( ' ). Do let us know if that gets the @ sign
May 14, 2009 | HP Compaq nc6000 Notebook
Sony VAIO VGN-AR630E Notebook Logo
21 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
