Question about Uniden Radio Communications
What is busy indication on uniden uho65sx-2. The radio appears not to recieve, cant get rid of busy indication.
The uniden was returned to Aucklands "wonderful" service team and it was found the ceramic coil inside had been damaged, after i dropped it I would say!
Posted on Dec 10, 2010
Squelch to low?
Posted on May 13, 2010
Uniden uho65sx Stuck on busy,and when press any key doesn`t emit noise.How to fix?
Turn your coded squelch off and adjust your manual squelch adjustment so that BUSY is not shown.
May 29, 2014 | Radio Communications
How do reset a uniden uho65sx
Manual is availabe from here: http://www.uniden.com.au/RESOURCES_MAIN/pdfs/uh065SX_2_OM.pdf
May 26, 2014 | Radio Communications
Uniden uho65sx manual
Hi Anthony,
Very simple answer: join yahoo group specific to your radio Make/Model, they have the answers you need, plus you can download manuals and schematics for free.
I hope you find this helpful.
Regards,
Peter
Dec 14, 2011 | Uniden Radio Communications
Uho65sx stuck on busy,how do i get it off.
make sure he Mic is plugged in correctly andd taghat the Mic was wired for a 4 pin cobra Style nd not midland.
Mar 28, 2011 | Uniden Radio Communications
I have a uniden bearcat portable and base I cant figure out how to program it
With the scanner powered ON,
1. Press [HOLD].
“HOLD” appears on the
display.
2. Press [PROG]. CH appears
and blinks to indicate that you
are in the Programming Mode.
To change the displayed frequency,
use [UP] or [DOWN]
while “CH” is blinking.
3. Press [PRIVATE]. “PRIVATE”
appears on the display.
If you want to program it into
another bank, press the
desired bank key. The lowest
open channel appears on the
display.
2 screens alternate to indicate
that open channel is available
to be programmed.
The scanner automatically
selects the lowest open
channel (000.0000) for easy
programming. If all channels
have been programmed (there
are no open channels in the
bank), channel 1 appears.
Use [UP] or [DOWN] to select
a new channel and even overwrite
old channels.
4. Press [PROG] to store the
frequency in the desired
channel.
Note: Press [BAND] to escape
from programming mode before
step 4.
Need the manual? You can download/print it here:
http://www.uniden.com/pdf/BC350Com.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Oct 01, 2009 | Uniden BC350 Base Scanner
Have no info booklet need to get rid of feed back
To select the VOX level:
1) Enter the Menu. Advance through the Menu until
the vox icon appears on the display. The current
level (OFF, 1-3) will be indicated. Level oF (OFF)
disables VOX, while levels - set the
sensitivity of the VOX circuit.
2) Press either the up arrow or down arrow key to the desired VOX
sensitivity level. Use level 1 for increased
sensitivity to voice in normally quiet
environments, and use a higher level to reduce
undesired activation in very noisy environments.
3) Exit the Menu.
Feb 27, 2009 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
Uh049sx." BUSY" light on all the time. wont recieve
Contact a service center in your own country.
turn the squelch button down.
Oct 19, 2008 | Radio Communications
Radio Communications Logo
1,040 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
