Question about Runco Office Equipment & Supplies
Thought I had a bad lamp - replaced it and still having problems - projector (CL-810) Projector turns on, shows the splash screen, shows the program and runs for about 60 seconds and shuts down with both Lamp and Temp lights flashing RED
Boba
  • 64 Answers
SOURCE: Problem with the lamp
According to Epson the led will flash red in one of two cases: Flashes red with 1 sec intervals - either the lump has burned out(We can rule this one in this case) or the lamps cover is open (try checking the cover's sensor) Flashes red with 2 sec intervals - an internal problem, I'd suggest contacting Epson's support. Good Luck
Posted on Feb 02, 2006
SOURCE: how to replace an hp 070 projector lamp
undo the top cover you will see a black cover with clips and at the back or side there are two small screws which hold the rear concave mirror in place undo the screws bend the clip back gently and remove ....pop out old bulb and put in new bulb with a piece of tissue dont touch it with your fingers.... do all the rest in reverse order ...did mine tonight took 10 minutes just a bit tricky getting screws back in.....you need a long magnetic posidrive with a small head....
Posted on Mar 23, 2008
  • 9 Answers
SOURCE: my projector keep shutting down
After replace the lamp. Please reset the lamp hours and clean the filter. It should work.
Posted on Apr 09, 2008
SOURCE: Projector shuts down after only a few minutes.
enter in Factory Menu
1. How to enter factory menu:
I. Hold press "UP" button until the "Lamp hours info." OSD display on bottom-right of screen.
Press keypad <Power> and <Blank> key simultaneously again, then enter Factory menu.
enter in fan menu and increse the speed of fans.
paul@ula.ve
Posted on Jul 02, 2008
  • 3 Answers
SOURCE: how to check for lamp life of my mitsubishi multimedia Projector xd 450u (DLP)
This should work:
How to reset the operation time meter
Plug in the power cord, switch on the projector, and
reset lamp time by pressing the (left and right arrow) and POWER buttons on the control panel simultaneously.
Important:
• If the 3 buttons was not pressed at the same time,
the lamp time may not be reset.
• Please confirm the TEMP indicator illuminates
about 2 seconds and the lamp time has been
reset.
• The projector will not turn on if you do not secure
the lamp lid.
• You must reset the operation time meter after you
replace the lamp.
• Do not reset the operation time meter unless the
lamp has been replaced.
Posted on Jul 23, 2008
Runco cl-610 projector
Likely the fan blades are dirty and out of balance. If this projector is in a dusty or smoky place you will need to clean them (or have them cleaned by a tech) often. If you are not good with electronics, I suggest taking it to a dealer. If you can get the covers off properly, you will need use a can of compressed air to carefully blow out the projector and fan blades.
Jan 05, 2013 | Runco Lamp for CL-610 Projector
I have a Runco CL-810 projector, how do you clean the fan filter?
Filter will be located near the intake fan. You can remove it and clean it. Normally just blow out the dust. If it is oily you can use dish soap be sure it is fully dried before replacement. The fans you can blow out (with machine off) Be sure not to spin them too fast or the bearings will be destroyed.
Dec 16, 2012 | Runco Cl-810 Reflection Dlp Projector Lens
My Runco CL-410 projector runs for about 30-45 seconds, then the lamp turns off. The hour meter says it has 471 hours on it. Any ideas?
Look inside the lamp. If you look into it if you see any white build up at its base, replace it. Need help, let me know.
Jan 09, 2011 | Runco CL-410 Multimedia Projector
Projector problem
I have a great deal of experience with that projector in particular.
The burning smell along with the circle on the screen can be one of two thing in the same general area. Both are not good.
The lamp assembly has its own dedicated cooling fans. these fans can sometimes **** in dust and insects. the lamp runs at a very high temperature and can burn those things quickly. I have often found old lamps with particles fused to the glass.
The other situation is that the lamp burned something and it got stuck to the glass somewhere in the light path.
if I remember right the projector monitors the temprature of the bulb and will shutdown if it gets too hot.
Runco is based in california and has a great turn around time on projectors. Unfortunately with Runco you would be hard pressed to find a technician that wouldn't just send it to them for repairs anyways. The major down side with Runco is that customers cannot talk directly to engineers or service men.
Locate a Runco authorized retailer in your area, check runcoes site. and give them a call to see if they cant send it to runco for you. if you cannot find one in your area call Roscor or Blair & Associates in Chicago.
May 02, 2008 | Runco CL-510LT Multimedia Projector
HP vp 6120 Projector
Hi there
Have you reset the lamp timer ?
If you have and the problem stil occurs you will have to replace the Ballast ( lamp's powersupply ) This is a very common problem with this specific HP model.
Dec 29, 2007 | HP Digital Projector Vp6120 Multimedia...
Change the lamp/ didnt help, lamp indicator is on
I actually fixed this myself!!!! Same thing, new bulb, fans work, turn on for first 20 seconds or so, see HP splash screen and then it shuts down. Try below....It worked for me.
Here's the fix: Take off the top cover of the projector. Unplug the wire leading from the two fans in the back of the unit to one of the circuit boards in front of you. Just trace one wire from fan to board. Unplug at board. Turn unit on and it will again turn on, show HP splash screen and then shut down, like it should, because the fans are now disabled. After it completly shuts down, plug the fan wire back into the board. Turn the unit back on and, presto, its working again. It will not turn off.
Try it!
Jack-
Nov 12, 2007 | HP Digital Projector Vp6120 Multimedia...
White lines across the screen
Sometimes if the resolution is set too high, white lines will appear.
Dec 12, 2006 | Toshiba TDP-T9U Multimedia Projector
43 people viewed this question
Top Runco Office Equipment & Supplies Experts
Colin Stickland
Colin Stickland
Electro Med Services...
Are you a Runco Office Equipment and Supply Expert? Answer questions, earn points and help others
