Question about Sony Ericsson T303 Mobile Phone (Shadow Black)
How to get mass storage on a t303 phone. - Sony Ericsson T303 Mobile Phone (Shadow Black)
How do I down load photo's from my Samsung 2 phone please
First make sure you have the correct USB drivers for your phone installed on your pc. Go to device manager and see if your phone or mass storage device is listed. If not, download the drivers here, http://www.samsung.com/us/support/downloads. Make sure debugging on your phone is enabled. Please refer to the following:
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > Applications > Development" and enable "USB debugging".
  2. Then drag the status bar down and tap on "USB connected".
  3. The "USB connected" screen with the large green Android icon will appear. Tap on "Connect USB storage".
A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 4.0)
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > More... > USB utilities" and tap on "Connect Storage to PC".
  2. Then plug the USB cable into the device and connect to your computer.
  4. A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 2.3)
Jan 09, 2015 | Samsung Cell Phones
Welcome to samsung mobile initializing file systems... wait 30 secs mass storage initalizing... wait (1min) mass storage mounted...
Samsung (and other) smartphones are like a computer, when you turn them on for the first time they require a little amount of time to boot up. This is normal, and necessary for the phone to work properly. If the phone continually says "Mass storage initializing", try turning off the phone and removing the battery for 30 seconds then returning the battery to the phone and rebooting.
Mar 07, 2011 | Samsung Jet S8000 Cell Phone
My nokia n97 32gb does not locate.When i plug it to my computer i di not see the mass storage.
The phone needs to be in mass storage mode, when you plug it in it should ask whether you want to put the phone in Ovi Suite mode, internet connection or mass storage. If this is not happening, you need to go to Settings > Connectivity > USB and select the correct option.
Feb 02, 2011 | Nokia N97 Cell Phone
My computer does not recognise my CECT i9 phone
Switch the phone on, then connect. You should have 3 options; Mass Storage, Webcam and PictBridge. Select Mass Storage. Depending on your system on your PC will connect immediately or maybe (older model) ask for driver. Driver for mass storage is 'generic' so will install automaticaly. After that go to 'my computer' and there will be 2 (!!!) new 'drives', the first one the external card on your phone, the second one the internal drive of your phone.
May 30, 2009 | Dual Electronics CECT P168 Cellular Phone
Can't transfer photos from Sony erikssa W 350 phone to dell laptop. computer recognizes conection to phone but wont get the photos
Make sure the phone is set to mass storage device. you will see your phone once it is set to mass storage device in the my computer window as another hard drive. it should say removable disk in the my computer window. Just remember when you plug the phone in, make sure you set the phone to use as mass storage device.
Mar 16, 2009 | Cell Phones
How can i download pictures on my SGH-G800 to my computer?
The quickest way to do this is to put your phone into Mass Storage Mode then connect it via the USB cable to your computer. Your phone shows up as a USB Mass Storage Device and you can select the folders you want to download your pictures from.
To set your phone to Mass Storage Mode, do the following:
- Go to the main menu
- Select Settings
- Then Select Phone Settings
- Choose PC Connections from the menu
- And then click on Mass Storage.
When you connect the USB cable to your computer, your phone will show up as a USB Storage device and you can just copy and past files to it like you would a USB Thumb drive. If you select the Samsung PC Studio option...your file transfers will take ALL DAY. Just use Mass Storage mode. Good luck.
Mar 16, 2009 | Samsung SGH-G800 Cellular Phone
Mass storage
Maybe its just the connection. It happeins to me all the time. Just unplug the connection and try it again. It doesnt always connect on the first or even second attempt. Make sure your phone is set to mass storage and not PC suite.
Jan 03, 2009 | Nokia N73 Cellular Phone
What is a USB mass storage?
A USB mass storage means a storage module or storage unit for data such as pictures, music, etc. that you can plug into the USB on a computer. A cellphone becomes a USB mass storage when plugged in a computer because inside a computer is a place to store such data. If you have further questions do reply back.
Nov 16, 2008 | LG Shine KE970 Cellular Phone
Samsung Wafer R510
get a usb cabel and tranfer it across or get bluetooth and send it across
Feb 02, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Can't download photo's onto computer
Are you connecting your phone as a Mass Storage Device?
  1. From the home screen, attach one end of the Motorola Original Enhanced USB cable to your phone and the other end to a USB port on your computer.
  2. On your phone, press Yes to use the phone as a portable USB storage device.
    Note: When connected as a storage device the phone cannot perform regular phone activities. Disconnect to resume normal operation.
  3. On the PC, open the My Computer window and find where your phone displays as a Mass Storage icon.
    Double click the Mass Storage Device icon.
  4. Drag and drop files between your computer and phone.
  5. When finished, remove the phone safely from your computer. Right click the "Safely Remove Hardware"
    icon at the bottom of your computer screen, then select "USB Mass Storage Device" and click Stop.
  6. Select USB Mass Storage Device and click OK.
    Now it is safe to disconnect the cable. When the cable is disconnected, the phone restarts
Jan 02, 2008 | Motorola Mobility W375 Cellular Phone
Sony Ericsson T303 Mobile Phone (Shadow Black) Logo
69 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
