My GE door handle broke on my spacemaker profile microwave(Model # JVM1490sd 003). How do I remove the door handle? Thanks
  • 5,911 Answers
You will need to access the door handle mounting screws and remove them to replace the door handle. To access these screws on MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. This can be easily be accomplished by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel and pry the plastic up. Work your way slowly around the perimiter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful microwaves.
With the inner panel removed, the door handle screws are visibile and can easily be accessed with a screwdriver. Simply remove the broken handle and install the new one. Re-insert the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
You can view an exploded view diagram of your microwave at pcappliancerepair.com for reference. Just type in your model number and locate the parts listing for the door. If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Nov 17, 2009
Our GE Profile spacemaker 2.0 handle is broken. How can I change it?
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you
May 31, 2010 | GE Profile Spacemaker Over-the-Range...
The plastic door handle broke again. This is the second time. It is the over the stove model. Mdl #JVM1660WB 003, serial # FZ924264S I replaced it the first time. Is there an easy way to do this?
well if you replacedit b4 it should be easier to replace it again. there is not a special handle thats stronger that will not break that i know of. im not sure if you replaced the unit or the handle.write back and let me know
Feb 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE profile mirowave JVM1350WW002. Handle broken
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Oct 10, 2009 | GE Profile Spacemaker Over-the-Range...
JVM 1660WB 003 GE Profile Microwave humming sound/burning smell
the magnetron the unit has gone bad.sometimes there is burning smell as u mentioned.it is little expensive repair arond $ 150.00.find out the price of new unit plus iistallation/delivery chg and then make a decision.
Aug 17, 2009 | Microwave Ovens
How to replace the door handle on a GE, JVM1490SD 003 microwave?
around the door you will see a plastic cover strip. gently pry it off and under there you will find the screws to open up the door and get to the door handle screws. you dont have to worry about breaching the seal.
Aug 13, 2009 | GE JVM1490 Convection/Microwave Oven
Our handle broke off our GE Profile Spacemaker Oven
You can easily perform this repair on your own and save the cost of labor charges and a service fee. Go to appliancepartspros.com and type in the model number you provided. The door handle is located under Section 1 as item number 1801. Make sure you order the correct color.
To access the door handle mounting screws, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to simply pry the plastic up and work your way gradually around the perimiter of the glass. Most microwave ovens have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, please let me know. I hope you find this information helpful.
May 12, 2009 | GE JVM1490 Convection/Microwave Oven
Broken handle on GE Spacemaker XL1800 microwave
New handles for microwaves can be bought on amazon. Take a look here Amazon com microwave handle and choose one (which fits). P.S. watch out on reviews and handle sizes. I hope this was helpful. cheers
Sep 07, 2008 | GE JVM1851BD 1100 Watts Microwave Oven
GE spacemake microwave handle door
Apparently the part number for the black handle is WB15X10020 and the white one is WB15X335.
You can order either and find find helpful exploded view diagrams here.
Enter the part number to order the part, and enter your model number to find the exploded views.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Aug 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Profile Microwave and the handle is broken....
I have the same issue. The Handle broke off my GE Microwave Oven (Model JVM1190SY 001). GE does not sell the handle seperately from what I can tell. I just ordered a new door. It's rediculously expensive. I tried to replace the handle with a nice drawer pull but couldn't find a size pull to match and I broke the plastic cover trying to get access to the screws for the handle, which is why I decided to buy the new door. Hopefully installation is not that difficult. This oven was manufactured in 2001, seems the handles have a 7 year life span.
May 28, 2008 | GE JVM1190SY/WY/AY/BY Microwave Oven
Problem with GE Door Handle
You can find helpful exploded view diagrams and by entering your model number here: http://tinyurl.com/gv383
Oct 08, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Washing Machines Logo
168 people viewed this question
Top Washing Machines Experts
