Question about Singer 7422
My needle is hiting bottom plate on singer 413, i need to know how to properly time the machine.
    Brigadier General:
  • 3,513 Answers
Hope your machine does not have a broken plastic gear. The one that usually breaks is at the top of the verticle shaft that drives the timing belt! Below is a website that will be of help to you! believe the website I gave you has those instructions on how to do that.
http://www.tandtrepair.com/StylistLine.html
Follow-up! Here is a .pdf file about the Singer 413 parts. The gear will be number 155819.
http://www.parts.singerco.com/CPpartCharts/4_4999/413K.pdf
Thanks
Posted on Nov 17, 2009
My singer 413 won't picking up bobin thread plz give me solution
Replace the needle with a brand new needle. (Check that it is installed facing the correct direction.)
If that doesn't work, then your machine has probably been knocked out of time. Take it for service.
Jul 22, 2017 | Singer Sewing Machines
Needle breaking
Is the needle all the way up? Are you sure it's actually hitting the bobbin? It MAY--and quite possibly IS--inserted too low in the needle clamp. Make absolutely sure that it's all the way up. Another factor can be your foot--make sure that it's properly inserted and tight, because it's probably hitting the foot and breaking--not the bobbin. In addition, it could be hitting the needle plate. You can determine WHERE it's breaking by manually turning the hand wheel--ALWAYS towards you--several times to see the position of your needle relative to the foot and needle plate.
Aug 15, 2014 | Singer Confidence 7463 Computerized Sewing...
Singer sewing machine 534 Machine and bobbin are threaded - won' sew
A few things you can check are.
1. is the needle the right one for the machine?
2. is the needle properly inserted and oriented correctly for the machine?
3. Is the bobbin inserted correctly, so it unspools correctly for the machine?
If that all looks right, then take the needle plate off and watch the shuttle hook. It should be very close to the needle when the needle is at its bottom most part of the stroke. If it is well behind, your machine\'s timing is retarded. You\'ll need to take it in for adjustment.
Apr 13, 2013 | Singer Sewing Machines
I recently obtained an Old Singer machine in a cabinet. On the front is a metal plate that states 1851 to 1951 100 years, also a metal plate on the front bottom of the machine with number AK213362. I...
hi, congratulations on the sewing machine, if you want to know more about the machine check out these two websites
Ismacs.net
sewalot.com
for the type needle & bulb & manual---check with sewvacdoctor.com
I check on the singer website for a free operation manual but I did 't come up with any thing so
definitely contact the sewvacdoctor for the parts & manual
Sep 05, 2011 | Singer Sewing Machines
Good machine, you may need to retime it, email me and I will attach timing instructions
drivewithken@blueyonder.co.uk
Nov 03, 2009 | Singer 7422
How do I adjust the timing on my SINGER CG590C
If you have a zig-zag machine check to see if the needle is set to the correct position. If you are trying to zig-zag, be sure you have the wide holed throat plate on.
Jan 27, 2009 | Sewing Machines
Singer 6038 needle issues
That sounds like the needle is not in straight or is bent.
Oct 13, 2008 | Singer 6038 Mechanical Sewing Machine
How do I fix a timing problem with my singer sewing machine? The needle thread will not pick up my bobbin thread.
Here's how you set the timing od the Machine alright:
1. Take the side plate off, take the needle plate off.
2. Take the presser foot off, and put a new needle in the machine. 3. Make sure that the needle is in the lowest position and look at the needle bar for the two timing lines. Locate the top line.
4. Then, turn the handwheel toward you until the top line is where the bottom line was.
At this point, the tip of the hook should be directly in the scarf of the needle.
This should set the timing of the machine perfect....
May 03, 2008 | Singer 5050 Mechanical Sewing Machine
Singer 7442 - Needle hitting bottom
FIRST DETERMIN NEEDLE BAR POSITION TURN STITCH REGULATOR TO LARGEST STITCH, THEN TURN HAND WHEEL TIL' NEEDLE IS ABOUT TO ENTER NEEDLE PLATE.
AT THIS POINT THE FEED DOGS SHOULD BE JUST AT OR JUST UNDER PLATE. IF SO NEEDLE BAR IS, IN CORRECT POSITION,AND TIMING WILL BE SET AT THE HOOK.
TO SET TIME REMOVE NEEDLE PLATE TURN HAND WHEEL SO NEEDLE IS IN LOWEST POSITION. USING A SMALL RULE RAISE NEEDLE BAR 3/32 OF AN INCH ( OR 3 MM FOR A METRIC RULE) .HOOK POINT SHOULD BE IN CENTER OF NEEDLES WIDTH. LOOSEN THE 2 SHAFT SCREWS
SLIGHTLY,TURN HOOK TIL CENTER OF NEEDLE. TIGHTEN SCREWS. IF NEEDLE BAR IS OUT OF TIME. BRING HOOK TO CENTER OF NEEDLE AND LOOSEN SCREW IN LEFT COVER. RAISE OR LOWER NEEDLE BAR TO SET 3/32OF AN INCH. THE 3/32 MUST BE VERY VERY CLOSE.
Nov 26, 2007 | Singer 7442 Mechanical Sewing Machine
Singer 7422 Logo
402 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
