Question about Ecoquest Flair Air Purifier
Absolutely nothing happens when i turn it on, it says to check fuse. how do i figure out where the fuse is
    Scholar:
  • 74 Answers
The fuse is contained in a compartment just above, but integral to the plug receptecle on the unit (where the cord plugs into the unit). First unplug the cord from the unit. Next pry the fuse out with a small straight screw driver. If you own the 110v version (as opposed to the 220v unit) you'll need the 1.6 amp slow blow fuse. For the 220v unit use the 1 amp slow blow fuse. Just match up the fuse you remove from the unit. The above information was found in the manufacturerers owner manual. Found online at: http://www.ecoquestintl.com/support/US40135_Fresh_Air_Owners_Manual.pdf
page 7 - Changing the Fuse
Posted on Jan 02, 2010
Won't turn on
Might be a fuse BUT it is enclosed in the unit. You would have to take it apart to see. IT could also be other parts in the power supply that have failed, With that in mind, if you do take it apart, take pictures so that you can put it back together.
Aug 27, 2012 | Sharper Image Ionic Breeze 3.0 Air...
BIOZONE 1000 HAS NO POWER
Maybe it also needs a new fuse or power supply?
Mar 01, 2012 | Biozone Standard 1000 Air Purifier
My XL-15 won't power up. Everything seems to be in place but when I flip the power switch to the on position, nothing happens. I have looked at the fuse and it looks ok. Could there be another...
Hi Jan,
If the fuse is good and you are sure your outlet has power, then check the safety switch is being depressed. On the back is the lint screen, there should be a clip that depresses the switch. Hope this helps you.
Jun 30, 2011 | Alpine Air XL-15 Air Purifier
Came home and unit was off and cannot turn back on. No response at all. Cleaned it and still nothing happens
Check to make sure the screen is pushed down in the back to activate the failsafe button. Sometimes the button can get finicky. Take off the screen and push it down with something. See if it does anything, if not, check the fuse and the plate, if it cracks, it's blow the fuse later.
Jun 08, 2011 | Ecoquest Breeze AT Living Air Purifier
No ozone smell. i checked the voltage on the primary and secondary of the high voltage transformer and get nothing.
check the fuse on the bottom curcit board it is a round black fuse on some units labled f21 it is solidered in the board on some units it is 400ma 250v fuse
Sep 03, 2010 | Ecoquest Flair Air Purifier
I purchased my purifier about 3 years ago but it has only been in use for maybe the last 2 years and it just stopped working. When I plug it in and turn it on nothing happens? I dont think for such a...
if you pull the unit out of the black box ( one screw on bottom) and then turn the unit up side down, their is a glass fuse in it. See if it is blown, their is also a fuse for the ozone part it is marked F21 on the same board
Aug 22, 2010 | Ecoquest Flair Air Purifier
I have the living air classic. When I turn it on,
The common things to check are the fuse, and make sure the filter tab is making a connection to the safety switch. You can find the fuse and the filter tab on the back of the purifier. Hope this helps.
Jul 02, 2010 | Ecoquest Living Air Classic Air Purifier
I cleaned my Ecoquest, it was working fine, how no power
Assuming that the unit was working fine before you cleaned it. Did you remove the back lower panel while cleaning it? It the panel that holds the electrical socket and fuse. If you did, check to see if the electrical connector is seated to the main board. Also check if the keyboard connector (the one that looks like a telephone jack) is plugged into the main board. Also, check if you model has a switch on the back that it is set to the on position. And press the power switch on the front keypad to see if that make the unit work. That all I can think that might have gone wrong.
Jun 30, 2010 | Ecoquest Fresh Air Air Purifier
I have 5 air purifiers Ecoquest, Alpine all in need of repair, need someone in Tempe, AZ to look at them. Thanks
The problem:  EcoQuest is now Vollara, and has discontinued the sale and service on the Breeze machine.  Some of the machines may have basic problems which you can troubleshoot.
1)  If absolutely nothing happens when the machine is plugged in, check the fuse.  Replace if needed with the EXACT same size (usually available at auto parts stores).  Also check the plug, making sure it's inserted firmly and is not frayed or broken.
2)  If the machine turns on, buzzes, but the fan doesn't turn, you can remove the front grid and fan blades and oil the shaft with a light household (sewing machine or hair clipper or 3-in-1) oil.
3)  If the fan turns, but no/little purifier odor is emitted, check the plate(s).  Inspect them carefully for any flaws, cracks, loose seals, broken screen filament, discoloration, burned spots.  Any imperfect plates must be replaced.  (Call Vollara Customer Service at 800-989-2299, using #16618 as the dealer referral number.)
4)  Clean plates which show no defects.  Use a solution of ammonia/water 50/50.  DO NOT USE any kind of sudsy or scented ammonia, nor any cleaning solution which is merely ammonia-based.  DO NOT use detergent or any other cleaning product!  Use a soft brush to scrub, then rinse well.  Blow-dry or air-dry.  DO NOT USE any kind of towel or cloth to dry!  Avoid touching the screen mesh with fingers.
5)  Clean antenna ionizer (the circular metal object) and the plate contact "fingers" with a cotton-tipped swab and alcohol.
6)  Double-check to see that all parts are inserted and aligned correctly, and that there are no visible loose or corroded wires.
If none of these options works, the problem is most likely in the computerized works, and cannot be easily repaired.  Perhaps some machines can be used for parts and a knowledgeable electronics person may be able to reconstruct a couple of working machines.
You can attempt to locate a dealer near Tempe by going to www.vollara.com and entering your zip code in the "Find a dealer" link.  Or you can call the above customer service number and ask them to find a dealer for you.
Jun 07, 2010 | Ecoquest Breeze AT Living Air Purifier
Does not turn on
Fuses often fail without appearing to be bad. Test the continuity of the fuse by using an ohmeter.
If, after testing your fuse, you continue to have a problem, let us know and we will dig deeper.
I hope you find this to be very helpful as a jumping off point, moving forward.
Please leave a rating. :-)
May 14, 2010 | Ecoquest Fresh Air Air Purifier
Ecoquest Flair Air Purifier Logo
536 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
