Question about Yamaha HTR-5990 Receiver
No real booming base on my Yamaha HTR 5900
Since it was Brand new and I cannot seem to get any real base out of the subwoofer. The test tone sound ok. I assume I am doing something wrong on hookup but can't find out what.
  • rholland356 May 11, 2010
    What speaker mode do you listen to? It's got to be one of the modes that includes the subwoofer channel. Try it on the different movie modes.
SOURCE: yamaha htr-5830
I own this receiver, and 18db is damn loud. Granted - your room might be significantly larger than mine with your speakers spread much further apart, or your speakers might be much less efficient than mine (this means that they want more power than the receiver can dish out - I have whatever speakers came with the "YAMAHA Home Theater in a Box" [the model that came with the HTR-5830]), but I'm pretty sure that the receiver doesn't get any louder (or at least not much). My suggestion is to turn down the volume to about -20db and work up from there after the movie has started. It might be easier to test the volume using music. The negative sign is deceiving - I rarely bring mine up to 0db. Also check the resistance - there's a red switch on the back of the receiver that switches between 6 and 8 ohms - make sure that it matches your speakers' resistance. If turning down the volume doesn't work, then post the problem again. Hope This Helps.
Posted on Nov 07, 2006
cancerags
  • 36 Answers
SOURCE: Connecting a Yamaha VX7 Subwoofer on my Yamaha HTR 5730 AV Receiver
Hello srqwrk,
You can connect the VX7 to the 5730 using an RCA Y cable like the one shown in the picture below. You get your one connection for the receiver and 2 for the VX7. These are available at any electronics store. Remember that the cable should be long enough to go from the receiver to where subwoofer will be placed.
Hope this helps. Let me know.
cancerags
Posted on Jan 01, 2008
  • 236 Answers
SOURCE: subwoofer
the best connection is to connect your sub to the output connector (subwoofer) of your HTR. it should have one. But you can also connect parallel to the speakers, any of right or left speakers or both. i normally connect to the speaker set B if thorugh the speaker connections.
Posted on Mar 31, 2008
SOURCE: Yamaha HTR-6130 Front right and left speakers with no sound
As simple as this sounds, try hitting the speaker a/b button on the front of the unit, next to the headphone jack. I had the same problem, and was about to package the whole thing back up and go back to Best Buy when I hit this button and then the audio test worked.
Posted on Dec 05, 2008
rteemon
  • 578 Answers
SOURCE: HTR-5740 Receiver Subwoofer Problem
as long as there is a speaker out from the receiver you should be ok just make sure polarity for spkr is right --remember you workng with AC current bad wire will cause fire==
Posted on Jun 26, 2009
My HTR 3063 is not producing any sound
The YPAO isn't on the 3063 model. only 4063 and up. If this is used and you can't get your money back, there is a firmware file here http://download.yamaha.com/search/product/?language=en&site=ca.yamaha.com&product_id=1436250 that can help get your receiver running correctly.
Apr 28, 2013 | Yamaha HTR-3063
How to solve a W 1 error on a Yamaha HTR-3063
Are we really talking about a HTR-3063?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-HTR-3063-Receivers-manual/id/23653ag915/t/2/
Strangely enough, that message is NOT documented in the HTR-3063 manual, but in another Yamaha manual (HTR-5063) it means the speaker being tested is believed to be Out of Phase, meaning wired incorrectly.
Your unit (HTR-3063) doesn
Feb 15, 2011 | Yamaha 5.1-Ch. Surround Sound Home Theater...
There is no sound coming out of the subwoofer
I assume it's an active subwoofer, since it hums. Did you activate sub in the receiver menu? Did you turn up the volume on the sub?
Jul 08, 2010 | Yamaha HTR-5840 Receiver
No test tone from subwoofer during balance testing Yamaha RX-V430
there's no test tone under normal use for the sub. It only shoud test the three front and two rear. ther' are disc you can use to test all the speakers. ( If you are into Pink Folyd, the movie The Wall has what you need to help balance the speakers
Jan 19, 2010 | Yamaha RX-V430 Receiver
Subwoofer doesnt work
New sub (never worked) or sudden failure (after it used to work)?
Type of sub? Has to be self-amplified (active).
Have you read the manual? You can find it on Retrevo.com. Just register and download it.
Did you define the Sub properly (SWFR or BOTH) in the SET Menu (page 42)?
Did it produce the test tone (Page 21)?
If all of these are done and the sub still doesn't work, maybe the sub is defective. Connect a CD player analog output to it to prove it can produce sounds.
Oct 20, 2009 | Yamaha HTR-5540 Receiver
Surround speakers work in test mode but won't come on during play
Check that you set it to Pro logic and check the speaker set-up. Set it to 5.1 Sounds like somthing is in the wrong setting.
Dec 22, 2008 | Yamaha HTR-5830 Receiver
Yamaha HTR-5990 Receiver Logo
70 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
