Question about Kodak ESP 5 Printer
Why does the printer ask for calibration every time I turn on the printer?
  • 31 Answers
It seems, Printhead has come loose or has gone corrupt.
Try reseating the printhead, do calibration. It should help you out.
1. Take both ink cartridges out.
2.Take printhead out
3. Wait for 10 seconds.
4. Put the Printhead back in.
5. Wait for 5 seconds.
6. Put the cartridges back in.
7. Go to Maintenance (Printer Conrol Panel or ? Help on your Home /Center software) and clean printhead.
NOTE: If issue still persists, pls contact kodak for printhead replacement.
Best Of Luck
Posted on Nov 18, 2009
2 Suggested Answers
nonontech
  • 4737 Answers
SOURCE: Printer keeps asking for printer
Where is the error message shown? On the printer or on the computer? I think it's showing on the computer.
You can try this, Remove all the cartridges, memory card, unplug the power cord, disconnect the usb cable, unplug the power from the outlet (if you wish to clean the cartridges, you can clean the Gold contact with a cotton bud dampen with alcohol, don't ever touch the contacts or the head with your hand, also clean the contacts on the printer). After about 20 minutes, reinstall everything (if you have memory card installed, don't install it, you can do it later). Now press the Menu button on the printer and navigate the settings using the Left Arrow or Right Arrows until Reset All Menu Settings is visible in the front display. Press the OK button. A message will appear on the display confirming that all menu preferences have been reset.
If this doesn't help, try installing another cartridge/s and check the outcome.
It'll be also helpful to uninstall the drivers/software and reinstall them after the both the printer and the pc are restarted.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Oct 22, 2010
How to calibrtate canon lpb 5050n
Most people have the opposite problem with this printer it calibrates all the time!
The calibration is automatic try turning off the printer and disconnect the mains lead, wait 5 mins and switch back on and it should calibrate.
Good luck
Jul 08, 2014 | Canon LBP-5050n Laser Colour Printer USB...
Why does my printer calibrate for every print?
Check the toner level. Turn the print off and on.
Oct 11, 2013 | Dell 3115CN
Printer performs toner alignment every time it is turned on
A friend of my faced the same issue years ago with another HP AIO printer. That model required you to scan that printout. In other case - firmware "thought" calibration is not completed and was printing out head alignment/calibration page every next time printer was turned on. You should check you printer manual for head alignment/calibration procedure...
Oct 15, 2012 | HEWLETT-PACKARD CM1415fnw AllInOne Laser...
Printer colour alignment out. How do it align this?
CALIBRATE THE PRINTER
Use the menus
1. Press OK to open the menus.
2. Press the Left arrow ( ) or Right arrow ( ) button to navigate through the listings.
3. Press OK to select the appropriate option. An asterisk (*) appears next to the active selection.
4. Press the Back arrow ( ) button to scroll back through the submenus.
5. Press X to exit the menu without saving any changes.
Color Calibration
? Power On Calibration. Specify whether the product should calibrate when you turn it on.
? Calibration Timing. Specify how frequently the product should calibrate.
? Calibration Mode. Specify the type of calibration the product should use.
? Normal
? Full (slower)
Full calibration improves the color accuracy of photos printed on 100 x 150 mm (4 x 6 in)
HP Color Laser Photo Paper.
? Calibrate Now. Set the product to calibrate immediately.
NOTE: You must click Apply before your changes take effect.
Jul 18, 2011 | HP LaserJet CP1515n Printer
Zebra S400 does not keep the calibration settings. After calibrating or restoring factory settings (like described in the manual) first label prints OK (using BarTender software) then it's off again. Same...
After you calibrate the printer. Press feed a few times. If it feeds a single label each time, then the calibration was successful.Power off and on while holding the cancel button. (config printout). Keep config for reference. Send label print from computer. If it does not work, then check that the printer driver matches the config printout. The computer printer driver will change and overide the settings in the printer
Apr 29, 2011 | Zebra Stripe S400 Label Printer
My Zebra printer is eating labels on and off. I feel when the printer runs out of labels it losses the labels and never prints it again when the Labels are reloaded. Is there a configuration setup for the...
is possible calibration issues. please run manual calibration,
go through the setings and run MEDIA and RIBBON CALIBRATION.
if ask to load labels,
open printhead, take 2-4 labels from the back papel and load the back paper normaly.
then press enter. Ask for REMOVE RIBBON? open printhead and move the ribbon from left to the rigth of the printhead (remove from the sensors(left and side)) press enter.
let the printer save that figers from the sensors (back paper/no ribbon)
LOAD MEDIA?
ok, put all back on normaly (labels and ribbon set up proply) press enter.
The printer going to run the calibration, if stop on the gap?! save (press twice on SETUP Button.
SAVED? OK. turn of and turn on again, send the job.
Hope help. Rate please. Thanks.
Dec 17, 2010 | Zebra Z4Mplus Label Printer
My ribbon is coming out with the label. the front spindle is not rolling.
You have to calibrate the printer. It thinks there is no ribbon (thermal mode) so it's not winding the ribbon up. The instructions are on page 11 of the manual -
4.2 Ribbon Sensor Calibration
Note: Please make sure the ribbon is properly installed before doing this calibration.
Please follow the steps below to calibrate the ribbon sensor.
1. Turn the printer power off.
2. Press and hold the FEED button then turn on the printer.
3. The LED will turn orange then blink red 5 times. Release after the first red blink and before the 5rd.
4. If the ribbon is properly installed the light will turn green. If it is not it will turn red and blink.
Nov 02, 2010 | Wasp WPL305 Thermal Label Printer
Brady printer 2461 is receiving a message position fault. How can this be corrected?
If you are using die-cut and reflective media you have to perform a Positioning Calibration that sets the TOF and calculates the label length of the media. This process also calibrates the ribbon sensor on printers equipped with the thermal transfer option. To do this;
1) Turn ‘On’ and enter the media setup parameters in the Media Settings-Menu
2) Load media (and ribbon, if equipped with the thermal transfer option)
3) Calibrate the Media Sensor
4)
Press and hold the FEED key for approximately 4 seconds or until 2-3
labels advance. Upon completion, the ‘Ready’ message will be displayed.
Please ask if you need any further details.
Aug 04, 2010 | Brady 2461 Thermal Label Printer
I am trying to print a picture and my pic is coming out with lines through it. Any suggestions?
Try this one, Turn on the printer, Take out the inks, remove the printhead, put back the printhead make sure it will snap and you hear a click, put the inks back, wait for the printer to initialize, Press the Menu button, look for Calibrate printer, then print calibration page, then scan it after. Load a regular paper. Then try to print a demo page by pressing Photo and Copy at the same for 5 seconds then let it go. If same problem persist call this no for further assistance 1800 421 6699
Thanks
Aug 31, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak ESP 5 Printer Logo
247 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
