Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
Speed selector is fussy, and a short has occured
  • 235 Answers
CCFSILVER - When you say your speed selector is fussy, do you mean fussy in a 'electrical' sense or fussy in a 'mechanical' sense? Also, you didn't say if the short is causing power to the motor to be cut or what specifically the short is doing. For now I'll assume that you mean 'fussy' in an electrical manner. That being said, the speed selector is fixable. If your mixer is under warranty, contact KA and ask them to remedy the problem. If it is not under warranty, then you can attempt to fix it yourself. This will not be for the weak of heart, as you have to disassemble your mixer. It that is not within your capabilty than you should take the mixer to an authorized KA repair shop in your area. If you think you can do it your self, great!
First, do you still have the KSM90 Parts List? If not, you can download a PDF version from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number (in your case, use KSM90P) and select one of the files that appear under Parts List. If you turn to page 6 you will find the exploded view of the motor and the speed control. I suspect your fussy selector issues are being caused by Illus Nos. 24, 25, or 27 (the Governor Assembly, the Control Plate Assembly or Phase Control Board, repsectively). I would order all three parts on the assumption that if one has gone bad, the others aren't far behind. As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part may vary widely between vendors, so do your comparison shopping.
Good Luck, I hope this is helpful. Howard, Burke, VA
Posted on Nov 19, 2009
I just searched the KA parts data base for this model and there is no such part???
There are a few parts that make up the speed control mechanism, the selector can only be the knob and lever. That moves the speed control plate which is the ********* square thing under the back cap that tilts when the lever is operated. There is a governor on the end of the armature under that control plate, that governs the speed by cutting the power through a circuit to maintain an even speed. Above the black control plate is a PCB (phase board I think they call it) that along with the other bits & pieces regulates the power to the control plate.
Oct 06, 2016 | KitchenAid K45SS Classic Stand Mixer
Krups ka950 food mixer no speed control always top speed
The speed selector circuit has been compromised but either an electrical short, or disruption from particles that entered the switching mechanism and covered contacts. Needs technical attention.
May 10, 2014 | Krups 240 Watts 8008 3 Mix Combi...
I have a KA k45ss and it is stuck on high speed only
Obtain a copy of the Repair Part List for your model from Kitchenaid.com.
You need to adjust the mixer speeds:
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted.
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 28, 2011 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid speed controller (don,t work
You need to adjust the mixer speeds.
Obtain a copy of the KSM150PS Repair Part List from Kitchenaid.com.
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 20, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid Artisan KSM150 Stir problem - Stir speed is the same as setting 2, but all others (4, 6, 8, 10) work fine. Tried adjusting the control board but "stir" and "2" still spin...
You are not adjusting the screws correctly. All three screws (2 top left and right, and 1 bottom)
must all be adjusted. Here is how:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jun 20, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid mixer not mixing
remove the back cover, and try tightening the two (on top) adjustment screws.  that might help but no guarantees!
Dec 24, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
Overloaded Motor
Are you mixing at a high speed. For bread, you shouldn't go above a '2' setting on most of the mixers and keep the time fairly short -- more isn't needed.
Sorry if this is redundant, but info posted to another problem works here as well:
KitchenAid has one of the best user forums of any company as far as I'm concerned. The participants are great and the monitors are exceptional (some of the best problem solvers you are likely to run across). You may find your experience already has a thread, if not, post it. I checked in and they seem to have added a video library that has some of the topics I've seen posted at this site.
http://www.kitchenaidconversations.com/
Oct 29, 2007 | KitchenAid K5SS Heavy Duty Commercial...
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
107 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
