Question about Harman Kardon Audio Players & Recorders
No sound from surround and center channels - Harman Kardon Audio Players & Recorders
    Problem Solver:
  • 5 Answers
Ensure all plugs are connected to the receiver and speakers and try using different cables.
Posted on Nov 17, 2009
Sound card
center not open.?
center of what?
are you saying the center channel of 5.1 is problematic.
do say what?
is this a hardware question or software. ?
Oct 03, 2013 | Sabrent 6-Channel 5.1 3D Surround Sound...
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Dav dz750k
Check your center channel. Most dialogue is routed to the center channel in surround.
Jul 24, 2013 | Audio Players & Recorders
What's a surround sound?
Surround sound is the main reason peoplepurchase themselves media centers. . Dolby Digital isthe common surround sound standard. The DVD manufacturers encode each DVD with5.1 channels of discrete Dolby Digital audio, which your receiver then decodes.The format creates a rich audio soundstage that brings movie soundtracks tolife with crisp dialogue, realistic-sounding special effects, and deep bass.
Jul 29, 2012 | Furniture
What is the time delay switch for on a sa 5760 receiver
Hi,here is the basic info for your question..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Surround Sound System Settings ---- Correct Time Delay Setting in Multi-channel Audio
A correctly set surround sound system can yield dramatic improvements to your
home theater sound or multi-channel music listening experience. In particular,
a correctly set time delay setting between the different channels is essential
for a realistic and unified surround soundfield.
Luckily, most of today's surround processors make setting the time delays
between the rear and the fronts a matter of a few entries in the setup menu.
Yet having a proper understanding of the principles behind correct time delay
settings is essential for the best results.
In this guide, we explain the principles behind time delay settings in surround
sound and show you how to adjust your surround processor or AV receiver for the
best surround sound field.
Time Delay Setting in Multi-channel Surround Sound Systems
Correct home theater speaker placement and properly balanced sound levels
between the different channels in multi-channel audio, while crucial, are not
enough to sustain a unified soundfield in a surround sound setup. A correctly
set surround sound system requires that sound from all the different speakers
reach the listener at exactly the same instant.
This explains why all fronts, left, right and center channel speakers, should
be set at exactly the same distance from the listening position. At the same
time, in a typical home theater setup, the surround speakers are closer to the
viewer than the fronts.
To compensate for this distance discrepancy, surround sound playback systems
apply a split-second delay to the surround sound channels.
Jun 22, 2011 | Technics Audio Players & Recorders
I have background sound on my TEAC HTX1800 DVD player, but I can't hear the people talking. Please help?! Regards /Hester
Chances are you are playing movies coded for Dolby Digital Surround. Depending on what kind of receiver your DVD player is plugged into, the receiver may not have the Center channel operating or turned up. Most all dialog comes from the center channel of a surround sound system. The receiver usually has a separate output for a center channel speaker, and a separate volume control as well. This will adjust the dialog volume up.
If you are not using a receiver, or plugged directly into the TV, check the audio settings on the TV. They may not be set up for the surround, hence why you are missing the dialog. Good Luck
Feb 21, 2011 | Audio Players & Recorders
No sound of voice, only surround sound
If you do not have a center channel speaker connected, then in the reciever setup menu for speakers, there should be a selection for center channel that says something like either yes or no. I'm guessing it says yes. Then you need to select "no" so that the circuitry will direct sound specified for the center channel to be reproduced through your front speakers.
Dec 07, 2009 | Pioneer VSX-D711 Receiver
When I play a DVD in the system I can only get the surround sound out of the speakers but no voices. If I play a CD or hook it up to my tv everything is ok.I have tried a number of DVD's and all have the...
sounds like you need to surround modes. There is usually a Stereo, Dolby, DTS, "virtual surround", 4-speaker mode etc..
When you play a CD or connect to TV it likely defaults to playing stereo or virtual surround.
With real surround, almost all of the voices are coming from the center-channel speaker (normally placed closest to the TV).
Also, check to make sure the center channel is connected properly.
Aug 31, 2009 | Panasonic SC-HT930 System
AMPLIFIER CENTER CHANNEL NOT FUNCTIONING
Center channel will not work unless unit is set for Surround or Pro Logic. Make sure center channel's volume is up
Apr 28, 2008 | Yamaha DSP-A3090 7-Channel Amplifier
Poor voice track but great sound.
Unhook your center channel speaker and see if it still goes into protect.You might have bad center speaker
Sep 09, 2007 | Sony STR-V555ES Receiver
117 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
