Question about Video Game Consoles & Games
My console will not light up. It works it turns on, spins, reads the game but the light on the ring and power light do not work. The conslole also does not read controlers, that is why i cant play
  • 456 Answers
The lights on the ring wont light up if there isnt a controller present. Try using a plug and play cable to ensure the controller is faulty or the battery is faulty. Also try using the sync buttons on the xbox and the xbox controleller. If the Xbox controller lights up the controller the controller is ok.Good luck.
Posted on Nov 18, 2009
When i insert a disk it does not spin to read it and i hear 3 knocking sounds
The motor for your xbox has been damaged, so it is unable to spin the disk to read it, the knocking sound is the motor trying to work but failing. You will have to speak with a technician to get it fixed and/or replaced.
Mar 01, 2011 | Microsoft Xbox Console
Cannot open the disk and cannot read the disk as well. The green light at the center of the ring always blinking
Hello
If you only get a flashing green light on the center while you turn on the console. You should get a green light going in a circle around the center light, (the 4 other lights, that can turn red as well (famous Red Ring of death))
if you don't get any red or green lights around the flashing center ring, then the console is not able to turn on / boot up properly and is in need of repairs, check the powersupply led, what color is it? it should be green when you power on and orange when not in use.
Jun 08, 2010 | Microsoft Xbox 360 Console
Dvd drive is not responding
turn off your console, unplug from the power source, remove the harddrive, reattach the harddrive, plug it back in, power on
Mar 10, 2009 | Microsoft Xbox 360 Console
I got three red rings and it wont read any discs
If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
Additional support loadTOCNode(2, 'moreinformation'); If the steps in the previous section did not resolve your issue, your console may have to be repaired. For more information about how to start the online repair process, please visit one of the following Web Page links: United States customers - Online console repair (http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx? redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx? step=repair) Outside the United States - Online console repair
Feb 03, 2009 | Microsoft Xbox 360 Console
Just opened new rock band for xbox360 system won't reconize drums
Have you tried to connect the drums to the console? You do this by pushing the connect button on the console first, which is a little circular button located on the front faceplate of the console next to the memory card slots. The lights on the light ring should start spinning. Then you press and hold the connect button on the drums controller, and the lights should stop spinning. This should connect the drums. If you have tried this already, let me know.
Jan 18, 2009 | MTV Games Rock Band Bundle for Xbox 360
Front lights kep spinning.
It sounds like you have a problem wiht your scanner. Because the lights are still spinning around alot that means that it is trying to read the game, but can't. So I would suggest getting a DISC cleaner. If that doesn't work, contact MICROSOFT if your warrenty isn't up and they should replace it for cheap. If your warrenty is up, then it will cost around $95 to fix.
Nov 10, 2008 | Microsoft Xbox 360 Console
Rings around the disc
It's caused by badly pressed discs - due to shake caused by the high speeds of the disc spinning and then catching the laser assembly. There are things you can do such as place foam pads inside the DVD drive itself, so discs cannot move as much when they spin.
Jul 18, 2008 | Microsoft Xbox 360 Console
XBOX 360 Core system
there is something in your xbox 360 called a lens and that what makes the xbox read cds so try this go to a store like walmart or maby even a local store and find something called a laser lens cleaner this can clean a lot of stuff game consloles cd players dvd players and probaly more so over the years haveing a xbox 360 it collects dust on the lens and does not read good
May 13, 2008 | Microsoft Xbox® 360 Core System Console
My guitar hero3 will not read in the system it worked fine earlier today i turned it on and now it wont work at all it saids disk not readable it is 3 weeks old
Check the disk. if it has a bis ring arond the disk it is screwed. this is caused by moving the xbox before the disk has stopped spinning.
Apr 13, 2008 | Microsoft Xbox 360 Core System Video Game...
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
