Question about Pioneer VSX-455 Receiver
Turn on, in a few seconds Flashing "OVERLOAD"
Overload  usually only appears if you have been using higher volumes for a period of time and this trips to protect your speakers and amplifier. Turning off your amplifier and leaving for a while and it automatically resets. other wise a would check your speaker cabling to see if any wires are  touching shorting out the circuit. Try removing you cables from your amp then turn on. If it turns on without Overload appearing the problem is between amp and speakers. Check your cables at both ends and while at it give them a clean then hook up everything ( Amp should be off) then turn on the amp and see if you get message. If you still get this message you could have  dry/ broken soldering on the inside and the amp is detecting a dc short in the system. This seem to a common thing these days. In which it will be a repair job.  Low impedance speakers or speakers that have a wide impedance swing when they are running at high volume can cause a amp to trip if it hasn't got enough current to drive low impedance speakers. Hope this has been of help.
Posted on Nov 18, 2009
Refrigarator not working after power outage
When power goes on and off suddenly, it can cause the compressor to overload and "trip out" This is supposed to protect the compressor from being electrically damaged. In most cases, after 10 or 15 minutes, the compressor will reset. It is usually safer to switch off the fridge or unplug it for 10 to 15 minutes to ensure a full reset. If it doesn't start, the power surge may have damaged the compressor relay. or overload device on the side of the compressor. I would doubt that it damaged the compressor itself. Be aware of the relay and overload device, unfortunately, there are Techs who will quote for a compressor job when all it needs is a relay or overload.
Feb 22, 2014 | AEG Refrigerators
9yr old model Maytag window a/c - just blows cold for 30 seconds - then blows warm. Was perfect until this happened. Is it worth fixing? What would be the usual fix for this?
The compressor is shutting off on overload after running for a few seconds. The overload cools down and starts the compressor running again until the overload heats up and shuts the unit off again.
Aug 02, 2011 | Heating & Cooling
Have a GE Profile Arctica that is a few years old. It is "clicking" every couple seconds, like turning off and on constantly. I have been gone for a week if that matters. The HRS light is...
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Dec 29, 2010 | GE Profile CustomStyle PSI23SCR Stainless...
Paslode im350 has indicator light flashing red/green
The nailer’s electrical system has gone into overload protection. There may be something wrong with the fan motor or the wires going to the fan motor. Remove the cap and grill to inspect the red and black fan motor wires. If the wires are pinched or broken, that may be the problem. It may also help to disconnect the small white connector on the wire assembly that goes to the motor and then reconnect it.
Jun 22, 2009 | Tools & Hardware - Others
Dometic ndr 1292 wont turn on
All domestic refrigerators have a overload protection and it sounds like the overload is kicking in. It wont start right back up to protect the compressor.
Mar 27, 2009 | Dometic NDR 1292 Refrigerator
Overload
Sounds like a voltage regulator or other componant has failed internally. What is the make / model?
Jan 27, 2008 | Audio Players & Recorders
It just starts and stops after few seconds ...
It sounds like either the compressor is bad, or the overload and relay assembly mounted to the compressor is bad. The easiest way to determine which is to put an amp meter on the power wire to the compressor assembly. It should only read a few amps while running. If it reads excessive amperage, you have a bad compressor. If you do not have an amp meter, then you could just go get a start relay and overload from a parts store and try changing those parts, as they are much cheaper and eaiser than changing the compressor....just unplug it before messinfg around inside the overload cover on the side of the compressor! Good Luck!
Oct 10, 2006 | Bosch Exxcel KSR34423 Refrigerator
327 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
