Question about Flex 3" Condensation Drain Horizontal
Condensation on double glazed windows
I have condensation on double glazed windows which has turned the wall (wallpaper) around the windows black (damp walls).this is quite bad on 4 windows around the house. How do i solve this problem. I have curtains that are now discoloured from being in contact with damp walls.
    Director Badge:
    Uploaded 100 video answers.
  • 83 Answers
Open the windows more, or use a dehumidifier.
Posted on Oct 29, 2015
    Sergeant:
  • 399 Answers
Hi check the air bricks built into your walls are not blocked
Posted on Nov 18, 2009
What is wrong when the heat is up on high and hardly any heat is coming out
could depend on the size of your unit. if you turn it up high, it can take quite a while for all the water in the tank to heat to that temp.
how many people are using water from that supply, that it has to be turned all the way up?
suggest you turn it down to normal. also, are the pipes insulated or do they run through a cold exterior wall?
Jan 21, 2015 | Water Heaters
Sabre boiler
Vent unit to exterior wall. 10ft from any window or door
Oct 26, 2013 | Protech Systems FasNSeal FSWMKE4 4" Vent...
How do i reset my honeywell thermostat
Remove thermostat from wall, leaving base plate on wall.
Model number appears on back of device.
Google search thermostat model in following format: Honeywell xxxx32 thermostat .pdf
Adding .pdf to search parameter will yield product manual.
Also while thermostat is off the wall, change batteries located in compartment on back of thermostat. These batteries must be changed periodically, for example each 3-4 years.
Jul 17, 2013 | Honeywell TH3110D1008 Pro3000 Thermostat
Gas works fine -gets hot water. But electric will not give hot water, only cold. How do you remove the heating element? It is on the inside of trailer in a black box? Model GC6AA-10E Atwood.
I'm thinking when you say black box, that you also have a wall switch with a symbol like a lightning bolt and you switch that on as well as checked breaker panel to make sure breaker is on as well.
With that said, you'll have 2 of 3/8" nuts holding that black cover on. Remove top one and loosen bottom one and pull cover off. ( Be sure power is off to unit while doing this.) You'll find the element in behind it. Put a voltmeter on black to element (red probe or alligator clip) and (black probe) to ground where you see green wire connected to tank. Turn breaker on then switch at wall. You should hear a relay click and 120 Volts should show at black wire ( red probe) . If you've got 120 volts there, shut off all power, drain water heater and replace element.
Jul 04, 2011 | RTO Atwood Water Heater - 6 Gal LP
Wiring an electric water heater
Hello,You are correct! Black/blue=black & Yellow=white 220volt single phase power.There are 3 wires for 3 phase power connection NOT the case in a home.Also an "off peak"timer option would use (black) only controlling the bottom element and (blue) controlling the top element.
Apr 21, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Worcester combi gas boiler 3.5 highflow is constantantly dripping water at the external flue position over flow pipe
water vapour is one the main products of combustion of gas. With a standard efficiency boiler, upon initial heat up when the flue is cold this vapour can condensate on the inner wall of the flue but should stop once the flue heats up, to stop this condense dripping back on to the heat exchanger the flue should be tilted towards the outlet and thus on initial heat up water can drip from the flue. with high efficiency (condensing) boilers, condensation will occur in the flue and secondary heat exchanger during normal operation, dispense of this condensate is accommodated for in the boiler and therefor the flue should be tilted towards the boiler, if not the flue will drip constantly.
Apr 06, 2010 | Water Heaters
Quit heating water
your element may be burnt out and need replacing
Feb 09, 2010 | Rheem 81VP20S Point-of-Use Electric Water...
I have a 50 galon smartwaterheater that came with the home and im trying to figure out how to work the gray timer box on wall
The gray timer box saves power by turning the power off and on to the water heater. Most that I have seen have a 1/4 inch screw head that you loosen and tighten to change the time it runs and shuts off. Basically operates like the outlet timers you use from a wall outlet.
Installed one for my mom over 25 years ago, still working.
Nov 27, 2009 | General Electric GE SmartWater Household...
Is it normal for my electric hot water heater to "sweat"?
could be a pin hole leak some where on the tank and the insulation is absorbing it for now if it is older then 6 years and u havent replaced the anode rod or flushed the tank once a year you should probibly look to replace it
Mar 15, 2009 | Rheem 81VP15S Point-of-Use Electric Water...
Flex 3" Condensation Drain Horizontal Logo
269 people viewed this question
Top Flex Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Flex Water Heater Expert? Answer questions, earn points and help others
