Question about Vacuums
Hepa filter stopped on Hoover Windtunnel 2 Model #U8361-900
Self-cleaning Hepa filter stopped turning and overall suction was greatly reduced. Another person had the same problem posted, but all of the solutions posted focused on static filters (of which there are none). There is a pre-filter screen and a dirt collection cup only. The Hepa filter is not removable. Any ideas?
This has a simple solution IF you have a air compressor with a high pressure nozzle. Outside the house, first remove the Dust bin completely and lay the unit down with the dust bin area up. now start blowing the nozzle at the hepa filter, Alot of dust will come out. Now start to rotate the filter while blowing the dust out. The filter will move one way easier, When there is no more dust reinstall the dustbin and check the suction and the rotation of the filter.
Tony
Posted on Jul 20, 2010
Top filter keeps clogging up??
Just make sure the rubber gasket is secure at the bottom of the dirt cup if it rides up the dirt will go straight up to the filters
here is the hepa that should be change when it is dirty
Hepa Filter Hoover U5780 WindTunnel Bagless 93002360
Dec 07, 2015 | Hoover U5780900 Bagless Upright Cyclonic...
My Hoover windtunnel has very little suction. I have cleaned the entire vacuum. Cleaned filters. My Hepa filter is a little torn, don't know if that could be issue. After cleaning it does suck a tad bit...
Is the belt still intact?
Does it has a wand tool, normally they are connected at the bottom of the machine,if it gets plugged up with gunk, that will greatly reduce your suction.
Aug 31, 2013 | Hoover WindTunnel Purely Pet Vacuum...
I have a Hoover Wind Tunnel Self propelled 12amp. There seems to be very little suction. I have cleaned the hoses and filters but still not much suction. any ideas? thanks.
Make sure all filters are cleaned out and entry ways are clear of all debris. Remove hose and check for blockage. Usually the low suction can be remedied when all filters are cleaned. Hope this works for you.
Jul 17, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Hepa filter does not turn on hoover wind tunnel vacuum model U6630900. It was working (turning) and I cleaned the filter and canister and now it no longer spins when the vacuum is running.
The part you refer to is not the HEPA filter. It's a very common misconception that that part spins - it looks like it when there's dust whirling around it. In fact, it does not spin - there are no visible moving parts.
Jan 07, 2010 | Hoover U6630-900 WindTunnel Bagless...
Hoover Windtunnel shuts down after 15 minutes
Might be that its not exausting enough heat & stutting its self down..
Try cleaning all the filters & the hepa filter..
This will increase air flow & maybe fix the issue..
Hope this helps !!
rate me good ;o)
Jul 14, 2009 | Hoover U6630-900 WindTunnel Bagless...
Burning smell coming from vacuum
use a penny to turn the 2 screws on top a quater turn then fold down the vacuum and lift up the cover and you will have access to the belt. Clean the small hepa filter with soapy water. their may be 2 of them. The cannnister filters need to be shaken but not washed. Good luck.
Apr 09, 2009 | Hoover U5753-900 WindTunnel Bagless...
Clogged hepa filter
If the hepa filter is clogged chances are it is not turning like it is supposed to. Hoover apperantly has a terrible R&D department because this is a bad unit. The filter is supposed to be self cleaning because it spins and a little tab is supposed to knock out dirt but does a crappy job of that. The transmission is what spins the filter and this must be replaced. If in warranty take it to your local Best Buy for service.
Dec 15, 2008 | Hoover U8361-900 WindTunnel 2 Bagless...
No suction
have u checked all of the filters. I know that when not all the filters r clean the machine will turn on but then it will sound louder and still have no suction. Most times there is a filter under dirt container thats sits above motor and if this filter is not clean the motor cannot breath. Thus no suction
Sep 29, 2008 | Hoover U6630-900 WindTunnel Bagless...
My hoover wind tunnel vaccum has a hepa filter that is supposed to be self cleaning but continues to plug up. it is not easy to get to and takes forever to clean it out so the suction is strong again.
do you have the SELF-CLEANING, rotating HEPA filter?
I just fixed my HEPA filter not rotating!!
It involves taking apart the vacuum HEPA area. All screws are the same size. There are a LOT of 'em. Really straightforward putting it back together too.
ok, once you take the HEPA canister area off the vacuum, careful with the wires! Unplug them from the controller board. You open up the HEPA chamber by removing more screws until you see where the motor that turns the filter is mounted on the side. Remove motor from the green chamber. Note where the washer goes. Once the motor is off, you'll see that the center hub that drives the HEPA filter is rounded out. What I did was jam little bits of aluminum from a pop can into the space between the circle and the square to force the walls back to square. I started by folding a little piece of aluminum over and over so it was about three layers thick. Jammed that in. That wasn't quite enough thickness so I shoved another piece with it. If you can find something that is about 4 times the thickness of a pop can aluminum, that'd probably work too. Slight wedge shape on the tip would help. Any sort of tiny shim.
To test your work, just put a couple of holder screws into the HEPA cannister housing, plug in the cover/switch, plug in the HEPA moter. Turn it on for a few seconds to make sure the filter turns. Then you can add more thickness to the hub or put things back together.
Apr 29, 2008 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Hoover Windtunnel
Mine does the same thing. There is no suction. I found that there is a door that opens when you tilt the handle in the down possition. I think there should be a spring in place so it can open. Until I find a replacement spring I have to open the door manually throught the opening under the light.
Oct 15, 2006 | Hoover U6630-900 WindTunnel Bagless...
Vacuums Logo
535 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
