Magnavox MPD835 DVD Player will not load disc. It has power but will just turn saying loading and then No Disc!
  • 163 Answers
SOURCE: TROUBLE WITH KLH DVD-8350 PLAYER
need more info, but did you try with another movie dvd? have you clean it with a cleaner dvd, blow some dry air by the port of the tray when it is open(could by a can in radio shack), if everything dosent funcion, then, you need a tech, the disc is not runing or the reading sistem has damage...good luck
Posted on Aug 09, 2006
SOURCE: dvd player wont eject or load..........
http://www.fixya.com/support/t208832-lite_lvc_9016g_dvd_drawer_not_open
Posted on May 22, 2008
  • 3 Answers
SOURCE: ge 1101 pa dvd player keeps saying no disc
Try turning the disc over.
Posted on Dec 25, 2008
SOURCE: insignia portable player NS-8PDVDA not working
Here's how I've solved same symptoms with our NS -PDVD8a:
1. Cleaned laser optics with isopropyl alcohol/swap --make sure you let the optics dry/IPA evaporate from the optics before running
2. Using compressed air can--cleaned laser track
3. Gently move laser along track several times - it seems laser is having most trouble at start of disc -- not sure it needs lubrication, but running it along track several times seems to have righted it
Had to do this a couple of times, but it's working now -- expect I will need to do this again -- no idea how long fix will work.
Posted on Feb 14, 2009
SOURCE: dvd player
the motor on that spins the disc has burnt up...I have this same problem and I am looking for a replacement motor. It doesnt seem to be a common item
Posted on Nov 30, 2009
E disc it doesn't rI have a gpx DVD player D200B and when I insert thecordnize it. Says
see the next remedies:God bless you
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours
Jul 21, 2012 | GPX Televison & Video
Magnavox tv combo
Did you try disconnecting the unit from the power for a few hours?
Apr 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Dvd player says no disc when there is a disc in
Hi
Please check weather you have inserted the disc ,whose format is supported by your KOSS player.
If the formatt is not been supported /regonised by the player,It shows as NO DISC only.
check with some other disc which you previously played.If it plays the disc which you using has the problem.
Thanx
Jul 26, 2010 | Dynex DX-PDVD7 Portable DVD Player
My Polaroid DVD player - Model # PDM0822BD player shows that a disc is loading however the disc does not rotate. It then stops saying "loading" and says NO DISC. I've had it for about 5 years and I love...
If the disc does not rotate it means there is something wrong with the power supplying the disc motor or the motor itself is defective. Try to rotate the disc motor manually, If its rotating freely then the problem is in the circuit that supplies the disc motor.
Jun 09, 2010 | Polaroid Portable DVD Player PDM-0822BD
Dvd reading
you will need to get the lense cleaned in the dvd player .
Sep 17, 2008 | Philips Magnavox DVD/VCR Dual Player
DVD player repairing
Double-check your DVD player's user manual/spec sheet to see if it plays Mp3 format files at all. Find out, specifically what kind it can read.
If your Mp3 disc is a DATA CD instead of an AUDIO CD, then nothing besides a computer is going to play it.
Sep 05, 2008 | Philips Magnavox DVD/VCR Dual Player
Off and on the players says bad disc
I turn it on and all i get is a blue screen. It will loading disc and say bad disc.
Aug 02, 2008 | Polaroid PDM-0743 Portable DVD Player
Magnavox portable dvd player
i've had two magnavoxes, one that i just got about 2 months ago and they're both doing that. I got a lens cleaner CD from walmart, it's like $15, but that didn't completely fix the problem. It helped for a little while, but then the player completely broke and won't even load the cleaner. I'm not going to buy magnavox things anymore.
Jun 02, 2008 | Philips Magnavox MPD845
Can't make it work
If the DVD doesn't recognise a DVD disc, then if can only be one of the following:
1. Not a compatible disc... Try a store bought disc.
2. Defective disc... same as above.
3. DVD player is defective and needs repaired or cleaned.
When a DVD player says "No Disc" it also means " Can't read Disc".
Hope that helps,
Geno
Mar 22, 2008 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
214 people viewed this question
Top Televison & Video Experts
Electro Med Services...
