Question about Nokia 6236i Cellular Phone
Nokia 6236i The 2.5 mm hole is "loose" my earpiece doesn't always make a good connection. Is there a way to make it tight again?
Why my washing machine`s fly wheel is always get loose, and not engage properly with gear. i found a bolt is get loose which is the top side of the shaft. while tight the bolt the fly wheel fit in rig
is there something that locks the bolt
my advice is unscrew the bolt
about 1/2" 33mm
and then add a few drops or crazy {super glue} or better is thread lock fluid
then screw it up
now the bolt will stay locked in place
good luck
happy crimbo!!!
Dec 07, 2014 | Maytag Washing Machines
Why nokia c2-03 headphone not connected
Hello... does your earpiece working on other phone? if yes ...at first try to connect the same earpiece to your phone and remove it again reconnect, even if there is no sound the only thing is to check the hardware components. If you think that you can do it and you have your own repairing tools. Please follow this https://lh6.googleusercontent.com/-nzNe8q0xLMQ/TXS2TTTMELI/AAAAAAAABI8/Dpm6tME2yio/s1600/Nokia+E5+Headset+solution.jpg or if you doesn't have tools please visit nearest mobile repairing shop/nokia priority
Thank you and good luck
May 01, 2014 | Nokia C2-03 European
Senco nailgun sn4 plunger doesn't retract
The driver will not retract if the driver is bent, piston oring too loose or too tight or the check band is loose or missing. Easy test, remove air and push the piston to top of cylinder. It should move up with very little effort. If hard to push, oring too tight or driver bent. If piston moves too easily and drops back down under its own weigth, oring too loose. If easy to push and stays suspect check band (check band is located on the outer lower part of the cylinder. Looks like black rubber band or series of orings that fit over series of holes. ). If the band is split or broken, replace with series of orings to cover all holes, or use any rubber like bicycle tube. Good luck with your repair.
Sep 28, 2012 | Air Tools & Compressors
My bose headphones have just stopped working, is there a decent chance I can get them repaired fairly cheaply?
You can try taking to a electronic repair shop to check if the cable is broken somewhere, if so, it can be repaired, if thats not the case bad luck. always take care of the headphones cables, never tie them tight always keep them loose.
Apr 07, 2011 | Bose On-Ear Headphones
In the frig part their is 2 light bulbs1 doesn.t work at all the other flickers tried replacing it does the same it flickers
the bulb that does not work replace and the light sw mabe causing the flicker and if not you have a loose wire connection . mm
Sep 02, 2010 | Whirlpool Refrigerators
Problem with Nokia 6300 - Can't hear anything
You need to changed,Your mouth piece, and you earpiece.
As for your ringer, it can be changed,but sometimes the problems always from the panel of the phone,and when it's from there, and ones is from there,it's damaged.
For your mouth piece and your earpiece it will workafter changing it.
Jan 20, 2010 | Nokia 6300 Cell Phone
I have a blackberry 8330. does the jupiter fit in
I assume you mean the Jupiter Jack and not the planet. The Jack fits into the 2.5 mm round earpiece hole on the side. The planet is huge and will not fit into a blackberry.
Aug 24, 2009 | Cell Phones
Nokia 6236i Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
