Question about Kenmore Refrigerators
How do I change my Kenmore water filter to my refrigerater . It's stuck
  • 999 Answers
Get one of those rubber strap wrenches. Yes they do get tight sometimes.
Eric
Posted on Nov 18, 2009
Kenmore refrigerater cold on top, warm below. all froze up. defrosted it now it will not run
Your symptoms indicate a failure in the self defrost system. Likely culprit is the printed circuit board that controls most functions of the refrigerator.
May 21, 2014 | Kenmore Refrigerators
Does kenmore refrigerater model 596.57542791 have a water filter ?
In a search of the parts breakdown for your model# their is NO listing for a filter. If it did have one it would be in the refrig, compartment on the right side ceiling above the top most rack/shelf
Aug 13, 2011 | Kenmore Refrigerators
Why won't the water filter turn so i can change it on my whirlpool refrigerater
If its mounted under the freezer door it might be easier to remove the toe plate grill
Oct 01, 2010 | Whirlpool ED5VHGXM Side by Side...
No water to the ice maker
filter cracked because it froze . changing the filter is not enough change the housing . as the lines are frozen and wll brake . mm
Apr 18, 2010 | Frigidaire FRS26H5AS Side by Side...
No water is coming out of the water depenseron the refrigerater
does your ice maker work OK ? if yes , do you have a inline water filter in the upper right hand section of your refrigerator at the rear ? if yes , replace the filter and follow the directions on the new filter to properly prime the water dispenser line. if the unit will not prime with the new filter installed, you'll probably have to replace the water dispenser control valve located at the bottom rear of the refrigerator where the main supply water line goes into the refrigerator.
Mar 17, 2010 | Refrigerators
Kenmore side/side refrig
Your Kenmore may be suffering from old age.
Jul 25, 2017 | Kenmore Refrigerators
Icemaker is leaking into ice bin.
it sounds like the water valve is leaking
May 07, 2009 | Kenmore Refrigerators
Kenmore 106.71299100,water freezes on floor of freezer,drain line freezes,I have opened drain with hot water etc.then problem returns in about one month. the refrigerater is 6 years old and this problem is...
You have a partially plugged drain, causing water to flow too slowly. Try reaming out the drain with a long stiff wire until water flows thru it like a faucet. You may have to unplug the unit for a day to get every part warm enough. Hope this helps!
Jan 28, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Change Kenmore fridge water filter due to slow water dispenser
what you want to look for on the filter is an arrow turn the arrow left and then pull down
Dec 09, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Why doesn't my ice maker work?
You do not list model number, so this will be very generic. If you have cubes in the ice bin, and when you try to dispense them the duct door opens and the auger motor runs, check the auger in the ice bin itself. Check where the spiral auger meets the plastic part on front of the auger. Drive part likely seperated.
Nov 21, 2008 | Refrigerators
Refrigerators Logo
96 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
