Question about Frigidaire AEQ7000ES Dryer
Error code DR
The dryer is only a couple of months old. It will not work. The dryer beeps and the display flashed DR. Can you help?
  • 1 more comment
  • Miljo Jan 23, 2008
    Same here....beeps three times and displays error "dr"...cannot reset or start
  • Anonymous Apr 09, 2008
    Brand new unit, turned it on and it thumps really bad. It is not out of level but seems to be inside the unit itself.
  • Anonymous Aug 23, 2008
    Have error code dr on dryer. It is only 2 years old
Pull the tech sheet out of the dryer ( behind the lower front access panal ). The lights flashing are trying to tell you a fault code.
A copy:
MODEL DIFFERENCES: • Better models have a digital readout display
• Good models do not have a digital readout display
READING ERROR CODES 1. Position cycle selector knob to the 3 O’clock position.
2. Press and hold the Select and Pause Cancel buttons simultaneously for six seconds.
3. Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds.
4. Rotate the cycle selector knob to the 2 O’clock position.
On better model dryers, the error code will appear in the digital display. On good models, the five indicator lights of
Drying, Cool Down, Wrinkle Rid, and Clean Lint Filter Spin will flash the number of times for the first digit of the code
and the START indicator light will flash the number of times for the second digit. Take separate counts of each indicator
light, then repeat to confirm in order to be accurate in identifying the proper error code. The code is obtained by counting
the number of times the lights flash. Example E24: The five indicator lights would flash twice indicating the 2 and the
START indicator light will flash four times indicating the 4. The five indicator lights and the START indicator light start
flashing at the same time. The control will pause for 2 seconds, then repeat the code.
Note: A letter appearing in the code stands for a number higher than nine.
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code E4A: the first digit would be 4 and the second digit would be 10. If this code would appear on a dryer in
the Good model line, the five indicator lights would blink four times and the START indicator light would blink ten times.
Troubleshoot problem by using chart below.
To move on to the next code, press the OPTIONS button. To clear code, press the Select button.
To exit this mode, simultaneously press and hold the Select and Pause Cancel buttons for six seconds.
jeff.
__________________
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Posted on Feb 10, 2008
I have a Frigidaire front loader washer model number LTF7000EGO and it was washing fine then started a beeping noise with dr flashing. What does that mean?
Hello friend, thank you for your post!
I understand that your Frigidaire washer, LTF7000EG0, is displaying a "DR" error code. "DR" stands for door which means a problem with your door it could be an issue with the door latch assembly or door strike. I would suggest resetting your washer and you can do that by unplugging the power cord or flipping the household circuit breaker for ten minutes.
If you continue to experience an issue with the error code "DR" I would recommend reaching out to a professional technician for proper diagnosis and repair. I hope this information has been helpful. -Matt
Oct 09, 2014 | Washing Machines
Electrolux ewf1074- cycle time flashing and beeping and not running cycle
Consult the manual first, if there is no troubleshooting , contact your dealer (thinking about the warranty term)
Dec 02, 2017 | Electrolux Washing Machines
Dryer will not start display works, when i push the start button it just beeps and does nothing, shows a E01 code.
Hi, this is what the error code means,
E1 or E2 Thermistor Failure The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
Hope it helps.
Jan 19, 2011 | Whirlpool GEW9250 Electric Dryer
TS error unresolved on ned7200tw
I have a gas model but this is what I found on the sight and it helped :
dt63 2 Solutions February 27, 2010
Check to see if your thermistor is bad by measure the resistance. It should be 10K Ohms at room temperature.
If it's bad, replace it BUT you have to CLEAR to error code.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Jul 12, 2010 | Amana NED7200TW Electric Dryer
I'm getting an error mssg "dr" displayed on my kenmore dryer model 84082. help!
"DR" is not a known error - please re-check and post the error code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 11, 2010 | Kenmore 67082 Electric Dryer
GLEQ2152ES the error "PF"
My dryer keeps beeping all by itself. I had to turn the breaker off. Now I tried to use it it it tumbled for a minute but kept flashing err & beeping then flashed E68 & shut off.
May 25, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer model#DPGT750GC1PL
Huuum At your service!
With an error code.
This can reset the system.
First unplug the washer and wait a 5 minutes then restart it.
If you can't reach the plug, use the breakerto cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Let me know how it works out.
How old is the appliance?
Please remember to leave a rating before you sign off.
Sep 02, 2008 | GE Profile Harmony DPGT750EC Electric...
Frigidaire Electric Dryer error code "dr"
try pressing options and select for ten seconds loc shouls come on then do it again to turn it off also check to see if the door is closing properly and that the door switch is closing and let me know i cant find no dr code so i dont think an error code i suspect it has something to do with the door closing
Jan 24, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire LEQ2152ES Electric dryer
Just to verify does it also beep six times? This model has the actual pushbuttons. Press all buttons lightly and see if any release. Disengage button.
Nov 25, 2007 | Frigidaire GLEQ2152ES Electric Dryer
Dryer turns itself on & beeps, then off again
aye, see if you can enter the diagnosis mode. What we are looking for is the F-02 code. This will flash when there is a stuck button or user interface problem and only displayed in the test mode. With the unit plugged in and all indicator lights off, select any button except stop. Press for 3 seconds, release for 3 seconds, press for 3 seconds, release for 3 secnds and press for 3 seconds. If you did it right 88 should appear. Press the same button again and if there is a error, it should show up. If no error code shows, open the consol and check the p-5 connector. This will be the interface ribbon to the board. Reseat it and see if the problem stops. Catriver
Jul 16, 2007 | Kenmore 67082 Electric Dryer
Dryers Logo
1,315 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
