Question about Kyocera Strobe K612B Cellular Phone
My kyocera strobe k612 ran out of battery and shut off. when i plugged it into the charger which worked fine yesterday, it doesnt charger and when i try to turn it on it just blinks n does nothing. what can i do to fix this? or can i atleast get my contacts out of this phone?
I have a stanley Ultra Bright LED Spotlight - I plugged it into the charger until the light turned "green". Unplugged it and went to use it and now the light flashes on & off constantly like...
Mine did the same thing so in desperation before disposing of it I did the following and it worked. I turned it on and while strobing, I locked it in place wanting to run the battery completely dead before recharging. It ran that way for about 45 seconds, it beeped and started working correctly. It may only be temporary, but worth a try.
Sep 12, 2011 | Garden
My camera battery ran out and when i plug it in to charge it with the original charger nothing happens at all, cant switch it on and it doesnt charge, it wont do off the computer either, i tried it with a...
yes replace both ,batterry and the charger,thath way youl be shure and the new battery must be charge for 12 hrs ...
and should works fine after ..
hope that will help you
regards Alan..
May 27, 2010 | Kodak EasyShare M863 Digital Camera
Laptop mouse pad doesnt work if being used on flat surface
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 27, 2009 | HP Compaq nc6320 Notebook
Kyocera wildcard dropped into water and flashes white screen
im unsure if theres a problem with the scree or you mightve gotten a shortage in the phone
May 29, 2009 | Kyocera wild card Cellular Phone
Kyocera Wildcard charger doesnt work.
You can go to your carriers retail store and use one of their chargers for free. Then you can determine if it is the phone or the charger.
Mar 01, 2009 | Kyocera wild card Cellular Phone
STROBE WON'T CHARGE
you gotta go buy a new charger,or see if your company will replace it.The chargers for the strobe are garbage
Oct 19, 2007 | Kyocera Switchback KX21 Cellular Phone
Kyocera Strobe K612B Cellular Phone Logo
155 people viewed this question
Top Kyocera Cell Phones Experts
Sue Hale
Level 1 Expert
Shane Martin
Level 1 Expert
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
