Question about D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842)
I can't access ther router using 192.168.0.1
Iam using a desktop computer. and now i can't open the 192.168.0.1 web page. i have tried to reset the router but still i cant open the page. please help
  • Anonymous Feb 11, 2008
    my router is breaking any time i ping it
  • Anonymous Feb 21, 2008
    i put the ip then i put the user name (admin)
    and password blank
    but he cant login what i must do ?
    plase any one help me:-((
    Novelist:
  • 101 Answers
Hi Wafula,
Unplug the Dlink, wait 2 min, and plug it back in. If that work, on the back is a small hole, marked RESET. Using a pencil, or straightne out a large paperclip, press that the button inside gently. Hold it for 30 sec. Release and unplug the unit. Shut down the whole network. "Starting from the wall", power up the modem, wait 2 min, power up the Dlink, and power up your machine. Your Dlink should be at default now. Remember to reset you security, change the password, etc.
I have had to do this several times, sometimes unplugging the power, and plugging it back while holding the button. (Got 3 hand?)
Posted on Jan 10, 2008
  • Anonymous Jan 10, 2008
    Hi again, Wafula,
    Left out some info. There was one firmware update for one version of the Dlink 624 series that set the ip to 192.168.1.1. A booboo on Dlinks parts. You might want to try that ip after resetting.
How do you change the ip??
Posted on Feb 01, 2008
Please sent me the firmware that will enable me to reset the equipment. The above solution did not work. please help
Posted on Jan 11, 2008
6ya staff
SOURCE:
It has password and I can't open it
Resetting the Linksys Router to Factory Default
To reset the router to its default settings, press and hold the Reset button located at the back of the router for 10 seconds.
IMPORTANT: Older Linksys devices may require pressing and holding the Reset button for 30 seconds to complete the reset process.
kb19584-003_en.png To perform hard reset on your Linksys router, follow the steps below:
NOTE: The location of the Reset button may vary for every model.
If the normal reset does not work, unplug and re-plug the router's power adapter while pressing the Reset button.
You can also reset the router via its web-based setup page. Follow the steps below to learn how.
Resetting the Router Using the Web-Based Setup Page
Step 1:
Access the router's web-based setup page. To learn how, click here.
NOTE: To learn how to access the web-based setup page on a Mac computer, click here.
Step 2:
Click the Administration tab then click on the Factory Defaults sub-tab.
kb19584-004_en.png NOTE: If the screen on your router's web-based setup page is different, click here.
Step 3:
Under the Factory Defaults section, click on the Restore Factory Defaults button.
kb19584-005_en.png The default settings of your router are now restored.
Sep 20, 2011 | Linksys WRT54GX2 Wireless-G Broadband...
Setting up wireless password
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
To perform a hardware reset on your Linksys router, follow these steps:
Step 1:
Take note of the current settings of the router before resetting.
Step 2:
Press and hold the Reset button of the router for 30 seconds.
Figure 1: Location of the Reset button on a Linksys BEFW11S4 router.
NOTE: The image may vary depending on the model number of the Linksys device.
Figure 2: Location of the Reset button on a Linksys WRT54GX router.
Figure 3: Location of the Reset button on a Linksys WRT54GC router.
NOTE: If the image of your router looks different from the ones shown above, consult your router documentation.
Step 3:
If the normal reset does not work, try to press and hold the Reset button for three seconds. The Ethernet light should go OFF then back ON. Unplug and re-plug the router's power adapter while pressing the Reset button. Keep holding the reset until the power light stops blinking.
NOTE: The router must be powered ON when you press the Reset button.
To reset the router via its web-based setup page, follow the steps below.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: To learn how to access the router's web-based setup page using a Mac computer, click here.
Step 2:
When the router's web-based setup page appears, click Administration then click on Factory Defaults.
kb4008-004_en.png NOTE: If the screen on your router's web-based setup page looks different, click here.
Step 3:
Click on Restore Factory Defaults and select Yes.
kb4008-005_en.png Step 4:
Click OK.
Related Articles:
Accessing the Router's Web-Based Setup Page
Setting-Up a Router with Cable Internet Service
Setting-Up a Linksys Router Using DSL Internet
Changing the Linksys Router's Password
Nov 12, 2010 | Linksys Wireless-G WRT54G Router
Cannot remember log in info
Step 1:
Step 2:
Step 3:
Step 1:
Step 2:
Step 3:
Click OK.
Related Articles:
Nov 12, 2010 | Linksys WRT54G2 Wireless Router
The Cisco System logo just stays orange, I attempted to repair on my lap top but it won't let me repair.
Step 1:
Step 2:
Step 3:
Step 1:
Step 2:
Step 3:
Click OK.
Related Articles:
Nov 09, 2010 | Linksys Wireless-G WRT54GS Router...
I need to get into my nat settings
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 09, 2010 | Linksys Wireless-N WRT150N Router
When my pc starts I get an error message concerning something missing in the dynamic link library. How do i fix this?
Try:
Step 1:
Step 2:
Step 3:
Step 1:
Step 2:
Step 3:
Click OK.
Related Articles:
Nov 08, 2010 | Linksys Wireless-G WRT54G Router
Forgot user name and password
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
My router will not connect the power light keeps blinking
Check this tip out from Linksys. It is for a G VPN Router but you could use the same steps to troubleshoot. Title: Resolving Blinking Power or Diag LED on a Linksys Wireless-G VPN Router Article ID: 4982 If the Power LED on your Linksys router is blinking, this means the device is not ready. It should go off once the router completes its diagnostic test. If the Power LED won?t go off, it indicates that there?s a possible hardware problem with the router. To resolve this, you will need to perform five steps: Resetting the Router Assigning Static IP to the Computer Pinging the Router Accessing the Router?s Web-based Setup Page Updating the Router?s Firmware For instructions on how to reset the router, follow the steps below. Resetting the Router Hold in the RESET button at the back of the router for 30 seconds. Unplug the power to the router then plug it back in. If after resetting the router and the Power LED is still blinking, try resetting the router again for another 30 seconds. Then proceed with assigning a static IP address on the PC. For instructions, follow the steps below. Assigning a Static IP Address on Your Computer Most of the time, if the power LED on the router is blinking it loses its ability to assign IP addresses to the PCs connected to it, which is why you need to assign the computer a static IP address. After assigning a static IP address on the computer, check if the computer is still communicating to the router by performing a ping test. To ping the router, follow the steps below. Pinging the Router Ping test helps trace the communication between the computer and the router. The computer sends packets to the router and in return the router sends out replies to validate the connection. In this example, our router IP address is 192.168.1.1. NOTE: If you?re using Windows 98 or ME, click here. Windows 2000/XP Step 1: Click Start, then Run. Step 2: When the Run window opens, type ?cmd? in the Open field, then click OK. Step 3: When the MS DOS Prompt appears, type ?ping 192.168.1.1? and press [Enter]. Step 4: Check the ping statistics. You should get Packets: Sent =4, Received =4, Lost = 0 (0% loss). NOTE: If you?re not getting good replies from the router, it means the router is not communicating properly with the computer anymore. You can already consider the device defective. Windows 98/ME Step 1: Click Start, then Run. A window similar to Step 2 will appear. Step 2: When the Run window appears, type ?command? in the Open field, then click OK. Step 3: When the MS DOS Prompt appears, type ?ping 192.168.1.1? and press [Enter]. Step 4: Check the ping statistics. You should get Packets: Sent =4, Received =4, Lost = 0 (0% loss). NOTE: If you?re not getting good replies from the router, it means the router is not communicating properly with the computer anymore. You can already consider the device defective. If you get good responses from the router, access the router?s web-based setup page to see if a firmware update is possible. For instructions, follow the steps below. Accessing the Router?s Web-based Setup Page In order to perform a firmware update, you should be able to access the router?s web-based setup page. Updating the firmware is one way of resolving the blinking power light on the Linksys router. To access the router?s web-based setup page, click here. NOTE: If you?re having difficulties accessing the router?s web-based setup page, the router is considered defective. If you?re able to access the router?s web-based setup page, proceed in updating the firmware upgrade.
Jul 21, 2010 | Linksys Wireless-G Broadband Router
One computer on network can't open internet pages
Try resetting the modem. It may be the Modem has to re-assign an appropriate ip address to your desktop.
Apr 01, 2008 | Computers & Internet
D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842) Logo
4,028 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
