Question about Panasonic Lumix DMC-TZ3 Digital Camera
The shutter is not opening all the way....so you see dark edges on the pictures. What should I do...where do I get serviced?
My Nikon coolpix l820 the screen doesn't work on camera setting but does on the video camera setting
hi,
when the still camera works the shutter of the aperture and iris is opening for a limited time, if it opens without limit the excess light will enter in and the result will be blurry picture, if the shutter is not opening the picture will be dark. in movie mode the shutter will be always in opened state, so I think there may be fault in shutter.
in some cases a slight jerk giving to cam when you depressing the snap button will reset the shutter and will work normally.
Nov 24, 2015 | Nikon COOLPIX Cameras
The lens shutter doesn't open to display picture
If this is a Kodak Slide Projector, it is equipped with a "dark shutter", to keep blinding the audience with white light when there is no slide in the optical gate. The shutter is spring-loaded, and there is an adjustment required in order to make the shutter operate correctly. Your projector either needs a spring, needs the spring re-hooked to its mount or and adjustment to the trigger. Kodak still has service manuals on their support website, or contact: www.micro-tools.com for parts and assistance (they purchased all Kodak's repair parts). Good Luck!
Sep 01, 2011 | Office Equipment & Supplies
My camera is a Pentax Optio m50, and there is no image on display. It's all dark and when I take a picture, it is also dark. Help me please. I've tried all settings.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 24, 2011 | Cameras
Hi, I have a Cannon Powershot A610 and when I take a picture the picture comes out too dark. How can I adjust the it? thanks
"Too dark" or do you really mean "totally black"? I'm asking because a stuck shutter is a very common failure mode for your particular model camera.
Apr 06, 2011 | Canon PowerShot A610 Digital Camera
My pictures are coming out too dark
There are four ways to make the image lighter
a) more light (flash, sun, etc)
b) slower shutter speed (allows more time for light to "expose" the sensor)
c) larger aperture (bigger hole = more light)
d) higher ISO (basically, amplify the available light more).
If you are using a point and shoot camera, the flash is usually only good for about 10 feet, so trying to get a good bright picture of subjects further away won't work.
Items b, c, and d are handled by the camera in automatic mode. In manual mode, set the iso has high as it can go. Set the aperture as large as it can go, and decrease the shutter speed.
Depending on the camera, you can enable the histogram to see if the images are too dark, usually by pressing the display button while taking pictures. If the histogram is off to the left edge, the picture will be too dark.
In post-processing, (e.g. photoshop), you can use Levels (control-shift-L for auto-levels) and it will move the histogram to the right, making the picture look brighter.
Feb 27, 2011 | Cameras
Dark on lcd screen when turn on. no display or picture.
A stuck shutter is another common failure mode for digital cameras, especially the S2 IS. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Also pay attention to the blurb there about Canon possibly fixing this for free (for the S2 IS only).
May 08, 2010 | Canon PowerShot S3 IS Digital Camera
Can't take a picture
shutter failure due to failure of power supply to the shutter/sticky blades
Feb 28, 2010 | Kodak EASYSHARE M1063 Digital Camera
Screen is absolute dark.Batteries o.k
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Dec 18, 2009 | Canon PowerShot S2 IS Digital Camera
Pictures too dark. Shutter operating too slowly.
Are you in auto mode? If it is manual then it is possible that the settings are not correct for the light. You can look at the meter to see what the camera thinks about the exposure.
It sounds as if your subject is too dark. Does this happen when the area is brightly lit? Does the flash fire?
May 01, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
One of the pictures has a great blue sky but the green tree is very dark and the other one has the green tree and very bright sky?
The two pictures were shot at dramatically different exposures - the "dark" one at 1/1600 shutter speed, f7.3, the "light" one at 1/320 shutter speed, f4.0. This accounts for the great difference, as the exposure conditions for the "light" one allowed much more light into the image during the exposure period. You didn't tell the whole story of how you set this up, I think you were shooting in a "spot" metering mode, where the particular exposure conditions the camera uses would vary considerably whether you were aiming at a dark area (making the picture light) or a light area (making the picture dark). I would make two recommendations: Switch your metering mode to "center weighted" (the mode labeled "[(•)]"), and also change your ISO setting to AUTO, as there would be no reason for shooting these photos at ISO 200 that I can think of.
Sep 04, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
