Question about Hotpoint WMA76 Front Load Washer
Detergent Dispenser When the drum has filled with water for the wash some detergent is left behind in the drawer and behind it, and there's some water added to the softener (but not enough to siphon). The remaining detergent gets washed out with the rinse water! I've given it all a good wash but it's no better.
  • Hotpoint Master
  • 3,463 Answers
The syphon tube needs cleaning by poking something through it to clear blockage.
Posted on Dec 11, 2008
Water leaking from detergent drawer
The first thing to do is take note of what the washer is doing when water leaks out in order to help pinpoint the cause. Does it only leak when filling? Is it leaking during wash or rinses? Or is it leaking only when it goes into spin?
Only leaks when filling
  • Water pressure that's too strong. Some dispensers can't cope with high water pressure. Make sure the washer is level as one leaning forward can leak if combined with high water pressure. Try turning the tap on the washer down. Only suspect this if you know the water pressure is high and it looks like it's gushing in quite fast on fill
  • If there is an optional detergent flap fitted in the drawer for holding liquid detergent make sure it is removed or drawn into the up position if using powder otherwise it prevents detergent running down into the drum
  • A build up of grease and slime in the nozzles at the top of the dispenser where the water flows in causing water to spray at the front and run out when filling. Check this article -black jelly-like substance in soap dispenser and on soap drawer (In extreme cases I've had to replace the dispenser.)
  • A build up of undissolved detergent in the base of the soap dispenser under the drawer (depending on the design). Remove the soap drawer and check the bottom of the soap dispenser for a build up of detergent that could allow water to run over the lip of the dispenser
  • Blocked dispenser hose: Some washing machines can flood water out of the soap dispenser if the hose leading out of the dispenser into the tub gets blocked. Blockages can be something put into the drawer by a child or a chunk of undissolved detergent tablet. Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and it wasn't wide enough. Undissolved powder from a tablet or lumps of detergent through poor water pressure can block this hose solid causing water to back up. Unplug machine, remove lid and feel this hose carefully for obstructions.
  • Overfilling: If the washer starts to fill and never stops it will flood out of the drawer eventually - Washing machine overfills
Leaks out of drawer during the wash or rinse cycle
  • Too many suds? If you can see the door glass is white with foam up to the top it could be foaming out of the dispenser. Too much foam in the washing machine
  • Overfilling: If the washer starts washing but the water doesn't stop coming in it will eventually fill the drum so much it will start to pour out of the soap drawer and other places. If this is the fault you should be able to see the drum is so full of water it's making a different sound, maybe labouring under the load, and the door glass full to the top with water. You should also hear that water is still running into the machine and be able to detect it by opening the drawer. However, in most cases an over filling washing machine should trigger an error code long before it gets to this stage but if you suspect overfilling check this page - Washing machine overfills
  • Surging: There are (often intermittent) faults that can cause the motor to spin out of control on wash or rinses. Instead of turning slowly the fault causes the motor to surge into spin instead which throws the laundry and all the water about violently. Water can then be forced out of the soap dispenser drawer. This fault should be relatively rare these days but if you observe this behaviour call an engineer to diagnose the cause.
Leaks from drawer only when spinning
  • If it only comes out on spin it can be caused by a partial blockage preventing the water being pumped out fast enough resulting in excess water being thrown around on spin and backing up into the dispenser. This fault is similar to the surging fault described in the last list but different in that the problem only occurs when it's on a proper spin cycle and much of the water has been pumped away. Troubleshooting this fault is all about finding out why it isn't emptying the water properly which is usually due to a partial blockage. Follow the same troubleshooting as described for a washer not pumping any water out at all - Washing machine won't empty water
  • If water is being forced out of the drawer when the washer is spinning but it is on wash or rinse and shouldn't be spinning follow the procedure for surging in the previous section above
Dec 23, 2016 | Washing Machines
Kenmore HE 4t Elite Front Loader Washing Machine
Inside the dispenser drawer, at the bottom there is a tab that you can push down to remove the dispenser drawer. Remove the drawer and check if the dispenser holes are clogged, this is a common cause.
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
Detergent dispenser drawer leaks.
give the draw a good clean by pulling it out, and check the level of the machine
Mar 15, 2014 | Hotpoint Washing Machines
Remove detergent drawer
If powdered detergent is used, water is directed through the drawer to flush it into your washer.
Jan 11, 2014 | AEG Washing Machines
Leaves detergent in despencer tray
Most of the time this is a dispenser housing issue. Remove the dispenser tray from washer and make sure it is cleaned very well. In the more serious clogs, you may need to clean the hose from the dispenser to the drum.
  1. Make sure the detergent dispenser drawer is opening. This issue occurs due to jammed soap dispenser. Dispenser Distribution System is located in the top left corner of the washer. The system consists of a motor that turns a cam gear. The Detergent Dispenser Assembly is located under the washer top. Begin by removing the washer top, console and front panel.
  2. Separate the water inlet and window washer tube from the boot. Pull the water inlet tube from the outlet connector of the detergent dispenser. NOTE: When reinstalling the water inlet tube, wet the water inlet gasket on the detergent dispenser with water only. Do not use any other lubricant. Align the tab on the water inlet tube with the indentation on the dispenser connector and slide the tube onto the detergent dispenser assembly.
  3. Remove the screw securing the front of the detergent dispenser assembly to the top front frame member.
  4. Disconnect the vent tube from the detergent dispenser assembly. Remove the screw securing the detergent dispenser assembly to the top left frame member. Slide the assembly back slightly and lift the assembly out.
  5. To remove the detergent dispenser motor assembly,disconnect the cam follower spring and lift the cam follower from the diverter cam and rotate the diverter cam clockwise to access the motor mounting screws. Check for all the connections to the dispenser motor or anything obstructing the dispenser drawer functioning.
  6. Pull the diverter out and clean it, including the shaft, spring, etc.
Feb 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Why would the machine leak out the detergent drawer when filling?
When the machine starts to wash water passes into the detergent dispenser and carries the detergent into the drum, if the detergent outlet is blocked, or resticted, this will cause the water to leak out of the dispenser.
Check the dispenser to see if an accumulated crust of powder is clogging the outlet holes, most dispensers are removable for cleaning, check your machine instructions for details.
Dec 13, 2010 | Whirlpool GHW9400 Front Load Washer
Lg tromm front loading washing machine has
Yes the system is cloghed. Pull the detergent drawer out and clean the drawers housing. try using some bleach. It allways helps.
BE ADVICED: after using bleach run quick wash cycle on without any load, it's just to get rid of all bleech remains and not to damage your clothes
Update me about your progress
Jul 20, 2009 | Washing Machines
Detergent dispenser is filled with water after wash is completed.
The water is left there because the syphon action is not working in the dispenser, what you need to do is to remove the dispenser drawer completely and thoroughly clean the conditioner compartment, poking any holes or tube, particularly the syphon tube with a piece of flexible wire or similar to ensure it is completely unblocked.
. to test, fill the conditioner compartment with water, and it should slowly empty itself, if it does not, then it is still blocked.
Plz rate this solution.Thanks.
Dec 27, 2008 | Bosch Washing Machines
The softener holder just fills with water but will not drain.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
  • Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
  • Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
  • Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
Dec 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
He2 leaking from detergent dispensor
Plug off the wall, etc. Remove the rear cover. There is a thin tube coming from the control panel area to the base where the water exits, this should not be blocked, remove from top and blow to check, refit. Next clean out your outlet filter, it could be clogged, refit. This tube controls the water level. Another thing that could be the problem: Try to take the top of the machine off; there are three tubes coming into the dispenser box, these may hv come loose or something. Connect well.
Sep 12, 2007 | Kenmore 46462 Front Load Washer
Hotpoint WMA76 Front Load Washer Logo
93 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
