Question about LG Vu CU920 Cellular Phone
My phone wont ring when i go to set a ringtone you can hear it but when a call comes through it doesnt ring?
My i phone wont ring
Like when you recieve calls? go to your settings and make sure that you have a ringtone set, turn the volume up, and check the silent switch on the side of the phone. if they are all on try and play music through the external speakers, if that doesnt work and you hear nothing then you might need a speaker replacement... you can buy these on ebay and search youtube how to open your iphone (only able to do this on 3g/3gs) and then its as simple as disconnecting a cable and removing the unit and replacing it with a new one bought of ebay. make sure to buy the right thing though.
May 09, 2010 | Apple iPhone Smartphone
I have a Nokia 2610 can't hear ringtone.
Select Menu, Settings, and change any of the ring tones. Select, ALERT FOR to set the phone to ring
Aug 07, 2009 | Nokia 2610 Cellular Phone
Lg shine #cu720 will not ring and vibrate simotaneously
1. Menu -> "Settings"
2. "Audio & Ringtones"
3. "Alert Types"
4. "Ringtones"
5. "Ring & Vibration"
-Nick G
Jan 12, 2009 | LG Shine CU720 Cellular Phone
Have nokia 3120 , incoming call does not rings
check if the format of ringtone set is compatible with your phone..
try to restore the refactory settings once.
thankyou.
Nov 19, 2008 | Nokia 3120 Cellular Phone
Ringtone doesn't want to set
Dear friend
pls go to settings option and open 2nd step go to ring style open then open ring style menu choose line 1 and slect ring tone by you choose then slect by scorall middle button and reday for use if fill diffcult then you go to nearest service center
thanks and regards
alok
bihar sharif
Feb 10, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Ringtone wont play
with the phone closed, goto tools, voice commands....click on settings in the lower right.......scroll down to call alert.......change to ring only or caller id+ring....on the env that should solve your problem
Dec 12, 2007 | LG enV VX9900 Cellular Phone
No sound when phone rings
I called Verizon Wireless and the said, if you go to “My Sounds” or “My Ringtones” select the song that you want to hear and press the play button. While the ringtone is playing press the button on the side of the phone to raise the volume…you should be able to hear the ringtone. Hope this helps!
Jul 29, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
LG Vu CU920 Cellular Phone Logo
54 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
