Question about American Standard Plumbing
Drain stopper won't engage to keep water in tub for bath
    President:
  • 1,515 Answers
Hi, looking at this straight on, you will see 2 screws going through the lever plug section. What it looks like on the inside, is a long brass rod connected to another brass rod with a adjustable section on it and a brass looking piston at the end. If you remove the 2 screws, grab hold of the lever and chrome plate and pull straight out and up to remove the assembly.No worry, nothing will fall in as it is all one piece. You can try cleaning the lever section up and add some wd-40 to it and this may help some. It sounds to me like the lever ball joint is worn out, so it is best replaced. Home Depot has them for under $20.00. Take the old one with you and if need be you can adjust the new one to the same length as the old one. It will keep hanging up on you believe me. Good Luck,
Shastalaker7
Posted on Nov 17, 2009
How to remove bath tub pop-up stoppers
Put the lever in the open position so that you can grab the stopper. After you get a grip on it, put the lever in the closed position and the drain plug and rocker assembly will pull out in a horizontal direction.
Sep 25, 2014 | American Standard 1583.470.020 Universal...
Water is draining from hot tub after its filled & dont know why
Hi Mary,sounds like your drain stopper may not be closing tight.Try removing the stopper by turning it counter clockwise,then jam a small rag in the drain as tight as you can to stop the water and fill the tub.If it still leaks then the drain plug where the stopper goes may have to be re-sealed or one of the jets may have a leak.If the tub is over a ceiling do not keep re-filling the tub you will cause major water damage to the rooms below.
Jan 05, 2014 | Leisure Time Filter Clean 1 Quart - 12...
I can not close my bath tub drain. the plunger is all internal and wont come out either. I tried a coat hanger to push it down. no go.
on most tubs the stopper is made to come out! does the stopper have 2 screws at the stopper lever. if it does just remove these screws and pull the stopper out slowly. when putting in a new one. have the same length as the old one, then slide it back in the drain fairly slow until it goes all the way in. replace screws and try it! good-day!
Aug 05, 2011 | Kohler Bath Drain KOH-K-7104
Tub drain would not work . pulled on metal rod with vicegrips and it opened the eyehook connect it to the stopper. i can get it to grab on the stopper , but not enough to get it out. what can i do?
kohler hooks on to kinda of a coiled spring that you just unscrew,after you take the two screws out of the trip lever keep turning it to the left until it pulls right out.the stopper for the water slides into that spring at the height to make it go up and down with the trip lever,Ive done lots of them but its hard to explain. if not can you get at it in the basement?
Jan 07, 2011 | Kohler CLEARFLO BATH DRAIN K-7160-TF-BV
I have akohler bath drain that seals/drains simply by pushing down on the gasketed spring-loaded chrome stopper. The drain is clogged with hair but I can not figure out how to remove it and snake the...
Toe tap stoppers remove by just gripping the stopper and unscrewing it. Once the stopper has been removed the hair will be usually caught on the crossbar underneath the stopper where it can be removed with needlenose pliers.
Spring type stoppers for drains are just about as notorious for being hair catchers. Once again there is nothing to stop the hair from leaving the tub.
May 21, 2010 | Plumbing
Removing bath drain
There are two types of tub drain stoppers for the delta brand - lift & turn and toe tap.
Lift and Turn:
The lift & turn stopper for the bathtub unscrews counterclockwise while in the full up position.
Toe Tap:
The toe tap stopper does also but if the cap may unscrew from it before the entire stopper comes out. In that case, there is a nut that is now exposed and can be accessed to unscrew the assembly.
If either of these is "spinning" without unscrewing, the threads are stripped and you would need to exert upward pressure while unscrewing in hopes of uncoupling this from the bath waste. If that doesn't work you would have to unscrew the bath waste flange from the drain pipe.
This will require access under the tub. I hope this answer the question for you. Thank you for using FIXYA. Jeff
Apr 09, 2010 | Delta Home
Direct push-type Kohler bath drain won't drain.
Spring loaded chrome stopper will not stay down to fill tub with water.
Jan 12, 2010 | Kohler Plumbing
Tub drain will not stay in up position
Hi it may well do clogged up in drain hole or it may have come loose inside try tighenting up
Dec 20, 2009 | Kohler Model 7202: Drain For Purist® Baths...
My tub is stopped up
you any thing that can fit the surface of the stopper and provide a good suction
Jun 05, 2009 | Kohler 1014-H2-96 Portrait 5' Whirlpool...
Plumbing Logo
396 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
