Question about LG enV VX9900 Cellular Phone
Phone will not turn on
My envy will not turn on and will not charge could i have fried something on the inside!! please help if i cant get it to turn on any way to get my contacts please please help
  • 3 more comments
  • nolan57 Jan 11, 2008
    same i get stuck at the verizion loading screen
  • Anonymous Jan 12, 2008
    My EnV flashes on the first screen you see when you turn it on. Once on for about 3 to 5 sec., it turns off and then back on, then off then back on again and so on and so on. That's it. It doesnt do anything else. I've taken off the battery but that doesnt help. Verizon will not honor the manufacturers warranty because the stupid water mark is pink now even though its been pink for the last 5 months.
  • R400 Jan 16, 2008
    Same problem... any luck you guys, my water marks are fine.. going to verizon store this weekend
  • blkft Feb 19, 2008
    we are having screen problems also, water mark is red and white, first the big screen started looking strange and then the little screen on the outside totally went out, so idk what the problem is we only bought it right before Christmas!
  • nijlkam May 11, 2010
    Solution link . . . http://www.LGenV-VX9900.com
My daughter set her phone in a car cup holder that had an inch or so of Iiquid in it.Phone would power on but not boot-up. So it appeared that the display and battery were OK even though red dots are present on battery and phone..
I read previous post from buschchris1 and followed his instructions. I used isopropyl alchohol (rubbing alchohol) and cotton swab to lightly clean components inside. Back of keyboard and circuit board at bottom of phone. This was the end that was submergerd (not the camera end). I got the phone to work again. Thanks. Chris.
A couple others tips that might help the next person. You'll need two very small jewelers screw drivers. A No.0 Philips or smaller and a small straight. There are a total of six small Phillips head screws that need to be removed before you can pry cover apart. Four screws are located under smalI plastic caps at corners. You need to pop off the small caps with the straight screw driver. There is another screw under a cap in the middle of phone too. The caps are difficult to remove without scratching plastic, but in my opinion worth it if you can get the phone to work again. The last screw is inside battery compartment, no cap on it. All screws are the same size.
The hint about using the knife blade is also excellent idea. (I literally used a Swiss Army knife too and it worked great - but be careful not to cut yourself or phone parts)
I also used hair dryer on low heat for 3 or 4 minutes (warm not too hot) to accelerate drying process. This worked for me rather than letting phone dry all night. This might not work in all cases i.e. where the phone experienced much more water damage.
Good luck.
Posted on Feb 23, 2008
    Master:
  • 474 Answers
HERE IS A POSSIBLE FIX.
If its has or you suspect water damage. Remove battery, get alcohol wipe and clean the contacts and set aside to dry. Remove the screws and open your phone. You will need to wipe down the circuits with an alcahole prep removing any corosion form all contacts. Check the memory card also, if its not damaged then remove it just to be safe. Once you have cleaned it up, ( both circuit board and the screen section. Be carefull about pulling on the ribons, you dont want to tear one.
Let it lay out taken apart for a day so all the moisture will dry out, put it by a sunny window or just a really dry place wear it can dry up.
This works with Pin Drives also, i washed one in the washing machine and i took it apart and dried it out and it worked, even kept all the data on it. This can work with Phones as long as you havent shorted anything out.
Once it dries, put together and fire it up, see if you get better results. Ultimately if it has water damage, Its warranty is gone and worth nothing, so try this.
Use a small phillips and a this knife balde like on a swiss army knife, this will minimize damage to case when you try to pry the setionc apart, star from a corner.
Hope tis helps
Posted on Feb 20, 2008
    Problem Solver:
  • 7 Answers
If the battery is wet or moist then try to put the battery in rice (i know it sounds ridiculous), but rice absorbs water really well and that may be the problem. i had the same problem and you just have to let the battery dry for a while. and if that doesnt work, then just order a new battery.
Posted on Jan 22, 2008
If you had gotten your phone wet, even having the phone sitting on your sink while you showered, or talked on it in the rain... any moisture at all can fry your phone if it is still wet when you power it on.
The internal components can get wet also without activating the water mark, example- water enters the phone through the keypad. In this case, Verizon will still honor the warranty as long as the water mark on the phone is not showing liquid damage.
If you water damage your phone, and it works fine, problems can arise months down the line from corrosion on the inside. If you can open the phone up, you can take some alcohol and clean off the corrosion in some cases.
Posted on Jan 20, 2008
Hp envy 110 scanner
Hi Preben Andersen,
I am not sure I understand what it is you are asking. In any case, I have located the user manual and support page for the Envy 110 and hope it is helpful.
http://h10032.www1.hp.com/ctg/Manual/c02538782
HP ENVY 100 All in One Printer D410a Troubleshooting
I hope this helps. If you require further assistance, or help with something specific, please let me know.
Thanks, I work on behalf of HP.
Jul 18, 2015 | HP ENVY 110
Spilled OJ by accident on my LG ENVY Touch, everything else is working but the microphone. I could still use the headphone, but when I want to answer the call as normal, the other party could not hear me...
ok 1 of two things is going on,... 1 . the phone could be still wet inside try using blow dryer to help to dry it up.
2. you could have fried the circut leading to the speaker. if drying does not repair then you will need o service your phone.
Nov 14, 2009 | LG enV VX9900 Cellular Phone
My screen is black in my envy 2
CHANGE DA DISPLAY IMRAN 9880400390
Aug 18, 2009 | Motorola Mobility RAZR V3
Phone won't work because its not charged and won't charge
you might need a new battery or you fried something on your phones motherboard and now you cant access your phones files manualy so you will probably need to go to a specialist at a retailer near you to get all your information off of your cell phone or just try to get a new battery and if that doesnt work just get a new phone it will be cheaper than getting it fixed\
hope this helps you
Jul 31, 2009 | LG RUMOR Cellular Phone
Phone Charged up, but cant get the phone to turn on.
phones fried had same problem verizon store replaced it 12 month manufacturs warrenty no questions asked good luck
Apr 21, 2009 | UTStarcom Blitz Cell Phone
MY ENV WONT CHARGE - even with pushing down
does it work when you plug it in on charge and then turn it on? if not its a battery replacement!
Feb 28, 2009 | LG enV VX9900 Cellular Phone
Envy charge port keeps breaking
Although today's electrinics are nicer to look at than things were 5 years ago, they're also more fragile. You must treat things like egg shells if you want them to last. I've had the same cell phone for 4 years, mi wife has been through 7.
Feb 17, 2009 | LG enV VX9900 Cellular Phone
Envy2 White screen
That doesn't sound normal. Call verizon to see if they can troubleshoot it with you. If they cant figure it out, you may need to take the phone in. Good luck.
Jan 19, 2009 | LG enV VX9900 Cellular Phone
I got this phone from someone...
your phones are fried, sorry you got screwed.
May 22, 2008 | LG VX9800 Cellular Phone
TI 84 cant turn on
Sounds like your pc had a static charge that it discharged to your TI and that it fried something inside the TI. No warranty, No fix. You gotta buy a new one.
Apr 10, 2008 | Texas Instruments TI-84 Plus Silver...
LG enV VX9900 Cellular Phone Logo
492 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
