Question about HP 9200c Flatbed Scanner
Black line on scanned documents from the feeder om 9100c scanner
    President:
  • 3,085 Answers
Open up and clean the scanner glass
Posted on Nov 17, 2009
I am getting a black line on scanned documents of my HP Officejet 6310 All-in-One Thanks
It would require you to open scanner and clean scanning head unfortunately.
Aug 02, 2015 | HP Office Equipment & Supplies
Black vertical lines come and go for scans to computer and copies
I suspect the Document Feeder is not aligned properly and light is leaking in. You will need to have a technician in to check the alignment of the scanner to see if it needs to be readjusted. random black lines on edges usually indicate light leaking into the scan area.
Aug 28, 2017 | Xerox WorkCentre 3220
Black line scan document
Does the scanner have a ADF ( automatic document Feeder)
If yes then there is a tiny spot or something on the glass
a dot equals a line
Oct 10, 2013 | NEAT Office Equipment & Supplies
Vertical Black Line
Probably there is nothing wrong with that scanner, just open and clean document feder with alcohol or glass cleaner.
Mar 29, 2013 | Canon PIXMA MX870 Wireless Office...
The photocopying using the feeder leaves a black line
There is a separate scanner glass from the flatbed scanner glass.
Without a make/model I cannot tell you exactly how to access it, but once you have uncovered the document feed scanner glass area, the glass will need to be cleaned well, and then you will be able to scan from the feeder without the black line appearing.
Jul 27, 2011 | Office Equipment & Supplies
When I use the feeder either for scanning or copying, the page has a black vertical line . When I make normal copies or print outs it is fine, only the feeder makes the black line. Thank you
Under the Automatic Document Feeder is a small glass.
This glass becomes dirty, creating lines on the page.
open up the scanner cover and clean the glass
Feb 17, 2011 | HP Officejet 6500 Wireless All-in-One...
My scanner is now adding a page with a black line that runs from top to bottom of the page and the actual document scanned is page 2. But the document is fine with no line through it. Does this mean that...
Check your scanner software settings. It is probably set at duplex ever time you start to scan. That is why you get two pages for every pass, the front and the back. You must place the document in the feeder in a way that the front side of the document is page 2. You may want to flip it next time you scan. So the main question is why there is black line from top to bottom? That is because there is a piece of dirt stuck on the glass of the scanner. You see, this scanner actually does two scanning when a page runs through it: the front and the back in duplex mode. So there are two scanners in side the box. The front page scanner apparently is dirty and needs to be cleaned with clean cloth and lens cleaner.
Aug 31, 2010 | Canon DR 3060 Path-Through Scanner
Why do I have a black line down the side of my scanned documents?
If you are using the ADF (Automatic Document Feeder) there is likely debris in that section of the scanning glass. The ADF parks the scanner in place and moves the paper over it, if something is on the scanner it will show up as a line. Check the thin section of glass at whichever end of the scanning deck for dust and clean it with a dry towel. If this is happening with documents on the scanner bed the debris is likely in the scanner and will likely need professional servicing.
Jun 09, 2010 | Office Equipment & Supplies
Black line in the middle of the output - scaned document
A black line down a scanned page indicates a dirty scan glass. Lift the top of you scanner like you would putting a page or book down to scan. On the end of the scanner that has the document feeder you should see a thin piece of glass the is separate from the larger glass pane. This is the document feeder glass. Now check it over for a very small mark of ink or dirt. You can use regular glass cleaner to wipe this glass just spray it on a piece of cloth not the scanner then wipe. You may have to wipe and then try scanning several times if the ink or marker is died on. while you are cleaning you should also clean the main glass pane, it will make the scans clearer and crisper.
I hope this helps, if so please rate our solution.
buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 05, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
Vertical lines when using document feeder to scan
you may have dirty glass on scanner or the feeder rollers are dirty or need replacement.
Jun 02, 2009 | Canon PIXMA MP750 All-In-One InkJet...
HP 9200c Flatbed Scanner Logo
116 people viewed this question
Seeker5211
Seeker5211
