Question about Samsung SCH-u340 Cellular Phone
I have a blue screen and an alert "emergency UART upload mode"
  • rahuldrabir May 11, 2010
    GENERAL PROBLEM
    » Nokia
    Solution » Motorola Solution » Sony Ericssion Solution » LG Solution »
    Samsung
    Somution
    UNLOCK CODE
    Nokia
    Unlock Code » Motorola Unlock Code » Sony
    Ericssion Unlock Code » LG Unlock Code » Samsung
    Unlock Code
    aaaaa10
How do I stop emergency alert sounds on dts huawei phone??
Go to messages, then look for the 3 vertical dots at top or bottom of your screen and tap it, then scroll down to settings (may have to scroll down to bottom of list) and tap it, then a menu will come and choose emergency alerts and tap it, then you will have the choices to shut off whatever alerts etc.
Jul 16, 2014 | Huawei Cell Phones
Tip
Samsung rest code Service codes Samsung: E900...
samsung rest code Service codes Samsung:
E900 software version: *#5002*8376263#
E900 full reset: *2767*3855#
Service codes Spice:
S404 enable COM port: *#42253646633# -> Device -> Set UART -> PS -> UART1/115200
S410 engineer mode: *#3646633#
S900 software version: *#8375#
S900 serial no: *#33778#
Service codes Philips:
S200 enable COM port: *#3338913# -> Device -> Set UART -> PS -> UART1/115200
Service codes "Chinese" models:
default user code: 1122, 3344, 1234, 5678
Engineer mode: *#110*01#
Factory mode: *#987#
Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
Restore factory settings: *#987*99#
LCD contrast: *#369#
software version: *#800#
software version: *#900#
Service codes BenQ:
software version: *#300#
test mode: *#302*20040615#
Service codes Pantech:
software version: *01763*79837#
service menu: *01763*476#
reset defaults (phone/user code reset to default): *01763*737381#
Service codes VK-Mobile 3xx, 5xx:
software version: *#79#
software version: *#837#
service menu: *#85*364# (hold #)
Service codes VK200, VK2000, VK2010, VK2020, VK4000:
service menu: *#9998*8336# (hold #)
reset defaults (phone/user code reset to default): *#9998*7328# (hold #)
on Feb 09, 2008 | Samsung SGH-E900 Cellular Phone
Screen shows blue box with 'software update through PC/uart
My bush bu11fvrsd32/X is show this on the front software update through pc / uart how can I get it of
Mar 16, 2014 | Televison & Video
Blue screen saying Emeregency UART Upload Mode on a samsung U340... can you fix?
You've flashed either the wrong firmware or just had a bad flash. You need to re-flash the phone with correct firmware.
May 11, 2011 | Samsung SCH-u340 Cellular Phone
My motorola has an emergency alert button on top, when pressed and held it sounds an alarm on all other radios near it. we pushed it to test and it works well and is a cool feature. however, the call tone...
Your radio may be functioning normally for the emergency alert. Here is an excerpt from the user guide:
Emergency Alert Mode
The Emergency Alert feature can be used to signal members in your
group of your need for urgent help. MR series radios will operate in an
automatic "hands-free" emergency control mode for a total of 30
seconds after activating the Emergency Alert. MR series radios in your
group will automatically advance the speaker volume to the maximum
setting and sound a warbling alert tone for 8 seconds. The alert tone is
emitted from your own radio speaker and the receiving radios in your
group. After the 8 second alert, any spoken words or incidental sounds at
your end will be transmitted to the group for 22 seconds. For the 30
second duration of Emergency Alert mode, MR series radio controls and
buttons will be locked to maximize reception of the emergency message.
1. Press and hold the Emergency Alert button for 3 seconds.
2. Release the button after the LED Indicator glows red and the alert tone
begins to sound. There is no need to continue to hold the Emergency
Alert button or use PTT for your message to be transmitted.
3. After the alert tone ends you may speak into the microphone. Your
voice or incidental sounds will be transmitted. The LED indicator will
continue to glow for the duration of the 22 second period.
4. After 30 seconds your radio speaker will emit a Talk Confirmation
Tone and the LED Indicator will extinguish. Operation then returns to
normal two-way mode.
Note: All Motorola Talkabout EM, MJ, and MR series radios are fully
compatible with the Emergency Alert feature. Radios other than EM, MJ,
MR series can receive the emergency alert signal, but will not respond
with adjusted volume settings, locked controls, or a warbling alert tone.
Users of other radio models set to the same channel and Interference
Eliminator Code will hear a steady tone for 8 seconds followed by the
voice transmission for 22 seconds.
Warning: The Emergency Alert feature should only be used in the event
of an actual emergency. Motorola is not responsible if there is no
response to the emergency alert from the receiving group.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/MR350-351%20User%20Guide%2012-16-08%20KEM-PK14190-90.pdf
Best regards.
Oct 22, 2010 | Motorola MR355R Two Way Radio
When I open my phone it says Emergency UART Upload Mode What does that mean and how do I get out of that?
what do you mean with 'open your phone' ?
This mode you are seeing is a 'flash' mode for the phone. I think you have been trying to flash your phone and you damaged some data.
You probably need to reflash the bootloader and the firmware.
B.r.
Sep 23, 2009 | Samsung Cell Phones
I've lost the operating manual for my Eton FR-300 emergency radio
Your radio does not offer the S.A.M.E. capability that would let you receive alerts for just your specific area, but it will let you receive all alerts broadcast by the NOAA station that your radio is tuned to. Here is a link to the owners manual where you can find more details:
http://www.etoncorp.com/upload/contents/307/U070165_FR300_Manual_US_053107_low.pdf
Bill B.
San Antonio
Mar 28, 2009 | Eton FR300 AM/FM/Weather/TV Radio
China mobile is not detected by pc
You need to install the software for that particular mobile so that your system detects the mobile. For eg. to work on a nokia mobile with your system you need to install the nokia pcsuite software...similarly u need to install the software for your china mobile
Feb 18, 2008 | Computers & Internet
Samsung SCH-u340 Cellular Phone Logo
311 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
