Question about HTC Hero Smartphone
I would like to edit the predictive text words that are stored in memory. How do I do this?
Text Mode show on display nokia1600 handset
You can enter text in two different ways: the traditional text
input indicated by , or predictive text input (built-in
dictionary) indicated by .
To use traditional text input, press the key marked with the
letter that you want repeatedly until the letter appears.
To turn on predictive text input when writing text, select
Options > Dictionary and the desired language; to turn it off,
select Options > Dictionary off.
To use predictive text input, do the following:
1. To enter the word you want, press each key once for a
single letter.
2. If the displayed word is the one you want, press 0, and
start writing the next word.
To change the word, press * repeatedly until the word you
want appears.
W r i t e t e x t
24
If ? is displayed after the word, the word is not in the
dictionary. To add the word to the dictionary, select Spell,
enter the word (using traditional text input), and select OK.
Tips for writing text with traditional and predictive text input:
• To add a space, press 0.
• To quickly change the text input method when writing
text, press # repeatedly and check the indicator at the top
of the display.
• To add a number, press and hold the desired number key.
• To get a list of special characters when using traditional
text input, press *; when using predictive text input, press
and hold *.
or check this link
http://nds1.nokia.com/phones/files/guides/Nokia_1600_UG_en.pdf
Nov 14, 2011 | Nokia 1600 Cellular Phone
How do i edit a contact and how do i turn on predictive text. thankyou
Well in contacts app when you open an contact (pressing your finger on the screen on place where the contact is lol :) ) and press a context menu button (it looks like on your device, there is an option to edit contact8_14_2011_11_48_33_am.jpgAnd for predictive text, it depends if you use Swype or other keypad. You find them in Settings->Locale Setting, if you select swype you will see an option to turn word prediction, for Samsung keypad there is an option called XT9, and for Gingerbread keypad there is an option at the end of menu to Show suggestions.If this is helpful thumb me up :).
Aug 13, 2011 | Samsung Galaxy S GTI9000 Smartphone
When texting and putting in "is" i keep getting HQ. Can i reset this or remove it from the phones memory for predictive words?
take off predictive text... either keep the star key or the hash key tioll you see the symbol in the top corner with the letters underlined, when the line underneath them goes then predictive text is off
Mar 26, 2011 | Cell Phones
Blackberry texting prediction problem
what exactly is the text problem...here are some general solution for text prediction
  1. options > auto text > edit > clear the with field ( this solution is used for instance if you keep type hr and it comes out as hour and you want to change that)
  2. options >auto text > new > enter word ( used to add a new word to auto text )
  3. options > SMS > disable auto text : YES ( used to disable auto text or test prediction )
Sep 11, 2010 | RIM BlackBerry Curve 8520 Smartphone
I cannot get my phone back onto predictive text
during your message composition, press the left soft key to enter your messaging mode or text entry mode, there you can highlight what you want, word mode or voice command mode, etc.
regards
Mar 06, 2010 | Samsung U900 Soul Cellular Phone
My Nokia 6300 does not remember new words in predictive texts, if i type a new name in, mates nickname for example, next time i come to text its not remembered it even though i pressed save. My other...
Hi George.
You must note that if won't remember some words(improper words).
If transferring the dictionary into a new folder in the Gallery which is save in the memory card didn't work, I'll see what I can do to help.
Since you have already try to save it in the memory card, then it's not the memory problem.
The problem is with the phone. Nokia 6300 is famous for forgetting predictive texts.
I can suggest you to try to upgrade the firmware,
You can try to save a word, a simple word like "ani" and check for how long it save that word. Try to switch off the phone, then turn it back on after a few minutes, check if that word is still save or not (Just to make sure it's not forgetting the text because the battery phone/switch off). If still there, see if the word can last for a day.
Note: Nokia 6300 is really bad in this predictive text field.
Sometimes the phone change the words randomly to another number.
Hope it helps.
Feb 24, 2010 | Cell Phones
How do I switch on predictive text
In settings/general/language - make sure that the only language ticked is English - then you can use the *A/a button
Jan 28, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
Predictive text problems with my samsung u900
when on predictive text if you want to change a word just click the "0" button (one with the Cross sign) this will cycle though the different words for you
rate me please thanks
Oct 04, 2008 | Samsung U900 Soul Cellular Phone
Storing words in my dictionary
It's limited to a certain amount of memory, when that's full, your dictionary is unable to expand.
"Time is what keeps things from happening all at once."
Mar 12, 2008 | Sony Ericsson K810i Blue Smartphone
Probs with text
Go to Settings->Other->Text Input->Personal Dictionary or Word Completion. If you have Personal Dictionary enabled, any predictive text words you've used in the past are still stored. With Word completion on, your Razr is auto-completing words from the Personal Dictionary. If you like to type the words in yourself, letter by letter, just turn these settings off. You can also want to reset your Personal Dictionary.
Jan 30, 2007 | Motorola Mobility RAZR V3
HTC Hero Smartphone Logo
136 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
