Question about Zanussi ZWF1440 Front Load Washer
Trying to change door seal on zanuzzi 1200 cannot get it back on
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
Follow these steps to replace your door seal:
For all Free appliance repair videos visit our VIDEO TUTORIALS
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Posted on Jan 19, 2010
Need door seal for axm-1200 mobilchef microwave oven
If you google it you may fine stores that carry it.
Sep 19, 2016 | Microwave Ovens
Fixya does not sell replacement door seals. Suggest checking with a local appliance parts supplier.
Miele W1926 burning smell
The front support seals -felt around the top of the door -are worn out. You can order them online with your model # or call the parts distributor and tell them you need the replacement kit - it comes with the top and side seals. To get them separate is more money. You will have to take apart the front of the unit - top first - then the control panel and then the door (front). It supports the drum. You will need to scrape off the old seals and apply the heat glue for the seals. Put the new seals on and reassemble the unit. This should do it if it was rubbing on the front plastic.
Jan 08, 2014 | Miele W1926A Front Load Washer
I got a Hotpoint Aquarius Extra Washer Dryer WD64 GB 1200, it worked before and suddenly did not work yesterday, when i supply the power and close the door properly and start the programme, the light is...
most common reason for what you are describing is a faulty door lock part no. 1602390.
easily fitted by undoing door seal retainer, removing two screws holding on door lock and then just change over wire for wire.(only 3 wires).
this should get you going
Jul 07, 2011 | Washing Machines
Front seal leaking in my bosch exxcel 1200
This video will show you how to change a door seal on this bosch bosch exxcel 1200
Mar 28, 2010 | Bosch Classixx WFL 2066 Front Load Washer
My refrig door wont seal tight can you buy
if you are having frost buil up on the model and it appears to be a freezer the seal may not be bad but you can not buy new magnets.the seal comes as one piece.you can do it your self.but try sealing the air flow vents in the bottom of the door with tape or silicone.the the diffuse plate in the back if it has slotted holes in it they can be covered with some aluminum tape.if you change the door seal the insultaion in the door panel should be change as well it more than likely has some ice build up in there
Sep 19, 2009 | Frigidaire FRU17G4JW Refrigerator
Looking for a door seal for a Hotpoint Ultima 1200.
If you have not yet got door seal, then go to www.hotpoint.co.uk.
Please rate my solution.
Thanks.
Jul 09, 2009 | Hotpoint Ultima WD72 Front Load...
Hotpoint aquarius 1200 washing machine leaking
this could be
1 door seal
2 heater ellement
3 front plate
4 front plate seal
5 outer container split
try looking at these first
Jun 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Door seal replacement
This video will show you how to change a door seal on this Bosch classics 1200 WFL 2463GB/12 FD
Jul 24, 2008 | Washing Machines
Zanussi ZWF1440 Front Load Washer Logo
185 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
