Question about Drills
It is not my drill.it is the transformer for charging the battery. trying to locate where i can purchase one or two of them. transformer numbers are as follows . WJ-Y41200300D 120 V OUT[UT 24V 300 MA POLARITY 0-0.-0 DATA 0805,10 MFG YUYAO SIMEN TOWN WAWJ I ELECT FAO CHINA THANK YOU FOR YOUR HELP bobdad6@bellsouth.net
emissionwiz
  • 78257 Answers
SOURCE: Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
Posted on Nov 07, 2008
  • 205 Answers
SOURCE: where can I purchase anthor battery for the black
Look for a Batteries Plus store near you, If they don't have your battery they can put new guts in yours.
Posted on May 11, 2009
comax
  • 154 Answers
SOURCE: Bosch cordless drill PSR 120 12V will not charge up.
About the only indication if the charger is not working is when you put the batteries into the charger and no lights come on. This indicated that the charger is faulty. If the lights come on it is most likely the batteries. The best thing to do is take the batteries and charger to a Bosch service center and they will test them for you. Most will do this for free.
Posted on Jan 09, 2010
radar001
  • 1051 Answers
SOURCE: My new Black Max 24v drill charger will not charge the battery
You indicate that the drill is new. I'd suggest you return it for a replacement. Seems to be a defective or wrong charger. If you have problems and If you paid by credit card call the card company and have them stop payment on that charge.
Posted on Feb 21, 2010
  • 178 Answers
SOURCE: I have a B&D Pivot Plus Cordless
If your drill is a model PD600, your battery part number is 5102993-00 and this website is selling it for 15.00
http://www.ereplacementparts.com/battery-p-100105.html
If this helped, please rate me!
Posted on Nov 25, 2010
I have a B&D Firestorm 18v 1-hour battery charger, model 5100235-09 (240v). When I insert a battery to charge, only the green "battery full" LED lights immediately. But the battery never...
Hi I have same problem with the charger. Solution is to replace the charge with new part number issued from B&D Australia
Number of 90515050-01 until stock runs out , then it is replaced by part number of 90578873 early to mid june 2013.
Hope this helps
Lance from Perth , Western Australia.
Jun 19, 2011 | Black & Decker Drills
Charger broke
common problem, go here
http://mrclm.blogspot.com/2009/09/black-decker-18v-firestorm-drill.html
May 14, 2010 | Black & Decker 18V Cordless Drill/Driver
Bought 2 no BTD142 impact drivers from Makita USA got drop down transformer they just start to charge then tones for broken battery are heard and stop charging, transformer new, batteries new have i done...
these newer chargers do make a tone that can be changed. when the batterys are initially inserted they will make a sound and then when they are fully charged they will make another usually longer sound. you can change it by removing the battery with 5 seconds and reinserting until you find the sound that you like.. I would look at the charging lights before deciding the charger or battery are bad.
Nov 22, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
I have a 12v xrp cordless drill. in the past 6 months i have purchase 3 new batteries. none will hold a charge. what is the problem.
You may want to try a different charger base. Any way you can borrow one so you don't have to purchase first?
If for some reason the charger isn't working well, you may be getting a partial charge and only that.
You may even want to rent a cordless just to try charging your own battery on a different base.
before you buy.
Nov 03, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt batteries
did you consider the freq. hertz in your country & US.
50 to 60hz
Jul 07, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
Dewalty Charger 18volts
take it back to where you purchase and dont forget bring your receipt
Mar 22, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drill battery charger doesn't work
Hi Firemedic13; Most chargers like yours have a fuse inside them. Remove the screws that hold the charger together. The fuse will be on the low voltage side of the transformer. Un-solder and replace it with one of the same value. If the charger is not held together with screws (doubtfull) you will have to carefully cut along the seam where they were glued together. A dremmel tool works good for this. After repairing use some ABS pipe glue to re-seal them together. If the fuse is not blown then the unit will require testing by someone that is proficient with a multimeter. Most times it is the transformer that has fried a wire. If the sides of the transformer have any burnt spots on it then it will be the culprit. Hope this has helped. Best regards; HELP2DIY Please dont forget to rate my answer.
Jul 03, 2007 | Hitachi 12v 3/8" Driver Drill Kit with...
Drills Logo
42 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
