Question about Sony Televison & Video
Does not spin up dvd some times when it does will not read
  • 63 Answers
You most likely have a bad lasser assembly
Posted on Nov 17, 2009
Panasonic DMRES15 DVD Recorder disc not spinning
Troubleshooting Solution
1.Display Message " Please wait" Not
booted
2.DVD-Rom Two-Three times make noise but doesnt spinning
3. Doesn't
open tray, No video OUT
1.Bad Main Board VEP79117
2. Bad DVDROM
3. Bad Prosessor
PCB
Mar 16, 2013 | Panasonic DMRES15 DVD Recorder
Tip
I think my problem is the motor, i got this dvd player from my sister, she said...
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
on Aug 28, 2009 | Philips Magnavox DVD/VCR Dual Player
Dvd player not reading new DVD
probably needs a new belt they do wear out and loosen up over time
Feb 16, 2010 | Philips DVP1013/37 DVD Player
DVD Player will spin disk, but will not read
Is your DVD player a multisystem player??????? If no,It is quite possible that the DVD's you are playing are not recorded on the format which your DVD can play. Please check It is also possible that the head of the DVD requires cleaning over use for 2 years OR the DVD being played has been lying inoperative for a long time thus gathering dust and moisture requires cleaning now
Dec 20, 2009 | Cars & Trucks
DVD player will not read any disc
The motor is on its way out - the H02 code indicates motor failure as in it cannot spin the disc. You can sometimes fix it but for how long is anyone's guess. Disconnect from the power, remove the three rear screws and two screws on each side (total 7) and lift off the outer cover. Now if you carefully reconnect the power BE VER YCAREFULLY NOT TO TOUCH ANY PARTS INSIDE THE CASE and put a DVD disc in as per normal, you'll will see that when the tray closes, the upper platen (a honeycomb disc) that sandwiches the DVD to the lower platen does not spin - it should. Give a gentle spin clockwise and it should spin up and the DVD will play. You may need to restart if you missed your chance first time. If you switch off and on, eject and close the tray, the spin should happen as normal. If it doesn't, your motor is knacked and not an economical repair. Buy a new player. If it spins time and time again, you may well have temporarily fixed it for a while.
Jun 17, 2008 | Panasonic DVD-RV31 DVD Player
DVD not reading but spinning
Are you using +R discs(not the -R)? Use Sony brand +R or try using a few +RW's and see if that corrects the problem.
Feb 23, 2008 | iLO DVD Recorder DVDR05
Wont spin
cdfreeze, DVD drives spin up the platter and attempt to read from it. If the read fails, they stop spinning the drive. So, I think the problem you have is that the device won't read. DVD drives have some very small plastic pieces that can break and cause failure. They also have a read head that can get out of alignment. If you're ambitious, look at the drive and see if you can find any other damage. Don't run the drive open, though, because there is invisible laser that can blind you (there should have been a warning on the top of the drive when you opened it). I checked eBay and this DVD player sells for under $20 (including shipping), so don't spend too much time on it. Definitely let me know if you have questions or comments.
Aug 22, 2007 | Philips Magnavox DVD Player MWD200F
Televison & Video Logo
46 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
