Question about SimpleTech SimpleDrive Portable USB 2.0 60GB 5400rpm 480Mbps USB 2.0 USB 2.0 External (STIUSB2560FT) Hard Drive
My computer does not recognize my simple drive when I plug it into computer
  • 358 Answers
Please note that: a drive formatted with FAT32 file system will not see NTFS formatted file system, whereas, a drive formatted with NTFS file system will definitely see FAT32.
To make it clearer, this means that, if on your system, your hard drive which is having the operating system installed on it, is formatted with FAT32 file system, and you bring an external drive, or even a backup drive which is formatted with NTFS file system, and you plug it to your system, the system will detect it but it wont be able to access the full drive capacity, you will just see it in the device manager page that it is connected.
But If it is Vice-Versa, the NTFS formatted drive will detect the FAT32 drive.
Now in your own case, if your system is formatted in NTFS file system and you plug in your external drive which is NTFS formatted also, then it means that you have some hidden partitions on your external drive, so when you plug it, try and do this:
Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
If you see any other hidden drives there, do the same thing to it.
This should make your External Drive to be detected automatically.
Also Make sure that the USB port that you are using is a USB 2.0 port, and not USB 1.0 port, you can just try the other ports there, to be sure.
Hope this helps you out.
Posted on Nov 18, 2009
  • robbecker3 Nov 02, 2010
    please help me my computer wont even recognize the divice i plugged it in to every usb port on here and the same thing every time it says new hardware found then installs then it says its malfunctioning. how can i fix?
Is my simple tech 60GB compatable with windows 7 the disk said for windows 2000 and xp
Most portable hard drives work with any operating system
Plug and Play is a simple Windows controller that enables your Windows computer to recognize and adjust to hardware changes and devices plugged on your computer such as hard drives, memory cards and USB and Firewire-powered devices with little or no input from a user. If your system is not recognizing plugged-in hardware, the plug-and-play device may be disabled and may cause instability on your system. Enabling this feature is simple.
Click "Start" on your computer screen and then click "Run." Type in services.msc on the run window and hit "Enter." Scroll down the services window and right-click "Plug and Play." Click "Properties" on the pop-up menu. Select "Automatic" under start-up type if it is disabled. Click "OK" to save the changes. Click "Start" on your screen and click "Control Panel." Double-click "System" and click the "Hardware" tab. Click the "Device Manager" button and then right-click the plug-and-play device you want to enable, then click "Enable." Close the device manager. Hope this helps.
Dec 23, 2012 | SimpleTech SP-U25/60S 60 GB USB 2.0 Hard...
Device is not recognized
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked. I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 22, 2010 | Western Digital Passport WDXMS2500TN 250...
My external hd Trascend 500 gb was recognized on start windows vista bussines on USB2. But after few minutes he became unstable not recognized after that again recognized and again
Jun 18, 2010 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
UPGRADE DRIVER FOR MAXTOR 3100 EXT HARD DRIVE
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 17, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
Out of the blue my computers quit recognizing the device.....
Jun 16, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
USB Memory Key not Recognized on Desktop running Windows Vista
check the formats of the keys. if they are NTFS they might not be recognized by earlier Windows versions. What version of windows does the laptop computer use? It may be as simple as using the correct formatting (FAT or FAT32) on the USB memory key.
Sep 14, 2009 | Maxtor Hard Drive
The computer does not recognize the Simpletech external hard drive. I plugged in a different external hard drive into the same USB port and the computer recognized it right away. What is wrong with the...
not all usb devices work on all machines
You need to find a driver or ask simple tech what the issue is i had the same issue with My WDC drive Western Digital gave me a driver after emailing them
Aug 13, 2009 | SimpleTech 750 GB USB Hard Drive
My SimpleTech 250 gb external hard drive has changed from being
The reason for drive letters changing is often as simple as having two plugged in at the same time. Changing them again is simple but should be done while all drives are plugged in simultaniously.
So, plug in both usb drives, then right-click on My Computer and select Manage, when the management console opens select disk management. Strating with the other USB drive, select it on the right hand side and then right-click it and select "Change drive letters and paths". Select change from the next window and select a high letter X/Y/Z from the drop down box. Then click ok.
Repeat the last few steps with the external harddrive and select E, when you're done you should have to restart to allow the changes to take place but then it will be set in. You will have to repeat this process if you change which USB port you use for the hub or if you add other additional external drives.
Hope this helps FixYa,
Chris
Jun 03, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Brand New Simple Drive won't connect again to comp.
Try plugging the simple drive into another USB port to see if it is recognized.
If this doesn't solve your issue, let me know.
Jan 09, 2009 | SimpleTech SimpleDrive Portable USB 2.0...
Computers & Internet Logo
895 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
