Question about Sharp XVZ200 Multimedia Projector
Picture does not have the red component and hence appears yellowish
  • 2,237 Answers
First reset the settings to factory default. if that doesn't work, replace the colorwheel. but you may have to send it in to a sharp service center. try av solutions in ny. they're really good. www.avsolutionsny.com
Posted on Nov 24, 2009
Why is the picture yellowish with low brightness?
Make sure the lamp is made by Osram and not a no name knock off. Cheap bulbs give poor color reproduction.
Jun 14, 2015 | Mitsubishi Televison & Video
The picture of my 51" Mitsubishi TV WD 62531 is dull or yellowish.How can I fix this?
It seems the problem you refered is quite complicated if you are not qualified technican. It needs full servicing of main board, including all the heated areas on board.You will need a soldering iron, and a multimeter to test the components, such as resistors on CRT socket board. The yellowish colour is caused by dry joints, (a common fault causing components to shake from its soldered base by heat). Resolder the main board and test the resistors on the CRT socket board for defective ones, change it. If you think you are qualified for this, give it a try or else consult a technican. thanks
May 15, 2010 | Mitsubishi WD-62531 Projection Television
Picture is yellowish and dim hard to see during daylight
you will have to change the coolant under the blue and maybe the red crt lens
Apr 18, 2010 | Samsung PCL545R 54" Rear Projection...
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
I have a yellowish tint in the center of picture
Why does my picture appear yellowish on the screen? I haven't changed the bulb in at least 2 years. Does this make a difference?
Aug 11, 2009 | Epson - PowerLite S1+ Multimedia Projector
I have a rainbow effect on my television screen.
the deguesing is not working of your tv.or maybe you have a load speaker near the tv. take it away near the tv it damage the color of your tv set.
Nov 15, 2008 | Televison & Video
Yellowish color from DVD
Hello Tsmith4,
Have you tried another source such as a HD cable box on the same component input (Y Pr Pb) By doing this you will eliminate the TV or the DVD player. If the picture shows great using the cable box on that same input then we will assume that the TV is ok for now. You may want to also check the DVD menu under progressive scan that it is set to progressive scan. if the picture is still not good, we would want to look at the I/O board on the TV. The red path after the Video switch maybe open. If this is the case we will have to go to board replacement. I will tell you what board to change.
Best regards
circuitcity
May 25, 2008 | Sony KDF-E42A10 42 in. LCD Television
Monitor screen appears yellowish
resolder components on the CRT neck circuit! the color ICs or Transistor connections migth have loosen up!
Dec 06, 2007 | LG Flatron F700B 17" CRT Monitor
Color problem
Replace D805 (?) Thermistor for permanent fix, manually
degauss with coil is temporary........T.
Oct 29, 2007 | Panasonic CT-36SF37 36" TV
Screen Gone "Yellowish" Colour, Appears that Blue colour is not working
your problem is in blue color cathode circuit. as you say that it becomes ok tha5t means 1 cable wire is loose from computer to monitor. 2 crt base loose. 3 loose contact in blue video ckt. 4 signal processor cable to crt board connector loose.(blue wire)
Oct 14, 2006 | LG Flatron F700B 17" CRT Monitor
Sharp XVZ200 Multimedia Projector Logo
47 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
