Question about Dell E551 15" CRT Monitor
Hello, I just got a used computer system. I hooked it up and everything was fine but then I went to power it down and can't get the moniter to come on without powering itself off! Do I have a bad moniter or what?
  • 2,229 Answers
Very possible. The easiest way to troubleshoot this is to try another monitor. Borrow one from a friend and try it.
Posted on Nov 17, 2009
I WANT TO USE MY DESKTOP TO PLAY FILMS ON MY TV . DONE THE CONNECTIONS AND GOT THE RIGHT SCREEN WHEN THE COMPUTER STARTED UP THEN IT WENT BLANK SO I CHANGED THE RESERLUTIONS ON A MONITER SCREEN THEN...
What you should try at this point is shut everything down, Unplug your desktop, hook it back up to tour moniter and boot. If you now get a picture, go to your device manger and click on display adaptors. If you have more than one selection. choose your monitor. Let me know if this works.
Mar 11, 2011 | Computers & Internet
Just replaced power supply unit from a 250 watt to a 480 watt and now computer comes on but will go into power saving mode instead of booting up and keyboard doesn't stay lit like it used to.The system is...
Which power supply went bad? The 250watt or the 480watt? If a power-supply goes bad (dies), it generally takes some (if not all) hardware with it.
Jan 05, 2010 | HP Computers & Internet
HELLO, I have a Toshiba laptop note book computer, Satellite A15-S127...INTEL CELERON 2.0 GHZ With USB 1.1 made in 2003 and a slot for PCMCIA Cardbus... I already have a second moniter (externaly)...
Suggest you buy and install a USB 2.0 adapter card.
Example:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4143850&CatId=511
Sep 06, 2009 | Computers & Internet
When I hook up my moniter it does not work like other moniters.
ok sounds like you have a broken pin on your cable if you look in the end of the cable plug the part thet goes into the box but also check both ends if they are there
failing that take monitor to roof and heave ho away it goes
Jul 25, 2009 | Compaq P 1220 22" CRT Monitor
Computer would not boot up, only showed red light
I'd say power supply first.
If you have an expansion slot filled with a video card, remove the video card (provided you have onboard video connector as well) then try to reboot. I just went through similar issues with an GForce video card, it went bad, but the machine appeared to boot althugh I couldn't see the screen. Removed the card & it came up using minimal VGA drivers provide with WinXP.
Obviously you cannot check the video driver if you're not booting up...and seeing the screen.
Find a buddy with a regular monitor and hook it up and try to boot. Dell monitors sometimes require their propietary drivers, so write down the model when you take your pc to a friend's place, and DL the driver and install it (provided you got it to boot up)
Brad
Feb 14, 2009 | ZT Group Cisnet PC Desktop
Moniter is black but has power
It's your video card! No Doubt! that happened to mine once and my friends and it was the same thing!
Dec 19, 2008 | HP Compaq FP5315 15" LCD Monitor
Qdi motherboard only 200watt power supply hooked up and the 4 12v pin is not hooked up computer turns on but moniter doesnt
you need min 250w power supply with the right connector.
do not try to splice any of the power wire. it will work but you will get burn later.
Oct 02, 2008 | Computers & Internet
Monitor blinks no image
first you need to isolate the problem to either the computer or the moniter. I would sugust that you hook a know good moniter to the compter and go from there. If the other moniter works then you have a moniter issue aif not chek the video card in the computer. good luck
budman630
May 01, 2008 | E-Machines eMachines Monitor E15T4
Constant beeping,won't turn on
What is the beep pattern? beeeeeeeep, beep,beep beeeeeep etc. also what BIOS do you have?
Aug 05, 2006 | Gateway EV 700 17" CRT Monitor
Dell E551 15" CRT Monitor Logo
mukhtar21 shaikh
mukhtar21 shaikh
