PC Chips M825G Motherboard
Problem for PC Chips M825G Motherboard
PC Chips Motherboard Problem
By Horner - usenet poster
Let me check Ill let u know..
Best Solution
posted on Aug 09, 2005
Very Helpful)
Ranny
Rank: Apprentice
Rating: 0%, 0 votes
Is your RAM rated for the higher speed?
| Ok BIOS is up to date, but still no luck using 166 cpu
clock speed.   Any
| ideas..
| | > Just installed a Sempron 2800 on a PC CHIPS M825G 333
motherboard.  I
| > installed Windows just fine, but noticed it was showing
an Athlon MP 1600
| > processor. Cpu Clock was set at 133 on MB, so I changed
it to 166.  It now
| > shows correctly as a Sempron 2800.  Problem is now
Windows goes to BSOD.
| > So I attempted to do a clean install and when it started
Windows setup
| > again BSOd.  Any ideas or do I have something set
wrong...
Was this helpful?
Yes
No
Solution #2
Very Helpful)
man1
Rank: Apprentice
Rating: 0%, 0 votes
Ok , figured it out.   It was a cooling problem on a Sempron 2800.  Weird
thing was it was seated correctly with extra artic compound.   Removed
fan/heatsink, and put back on the same way and heat went down 50 degrees.
Was this helpful?
Yes
No
Solution #3
Not Rated)
Kim1
Rank: Apprentice
Rating: 0%, 0 votes
Its 2700/333..
Was this helpful?
Yes
No
Solution #4
Not Rated)
Bray
Rank: Apprentice
Rating: 0%, 0 votes
I think I'm out of ideas now. Only other thing I can think of, have you set
the BIOS to its safe default settings I must admit it sounds like a timing
problem to me.
Best of luck.
Neil
Was this helpful?
Yes
No
Solution #5
Not Rated)
Brad
Rank: Apprentice
Rating: 0%, 0 votes
Apart from the memory I can't think of anything else now. I know you said it
was 2700/333 is it branded memory or if you have more than one module have
you tried one module on its own. If you can borrow a module and try it at
least you could rule that out.
all the best
Neil
PS I run a +2600XP on a PC Chips M848ALU v2.1 and have never had any
trouble.
Was this helpful?
Yes
No
Solution #6
Not Rated)
2Pansy
Rank: Apprentice
Rating: 0%, 0 votes
Have tried the memory solution to no avail. It will boot just fine at the
166 cpu clock , but Windows does the BSOD routine.  Even on a clean install
same problem.  At booting it reports a Sempron 2800+.  If I change to 133
clock speed it reports an Athlon MP 1900, but will boot just fine..
Was this helpful?
Yes
No
Solution #7
Not Rated)
pawa
Rank: Apprentice
Rating: 0%, 0 votes
Ok BIOS is up to date, but still no luck using 166 cpu clock speed.   Any
ideas..
Was this helpful?
Yes
No
Solution #8
Not Rated)
Mini Me
Rank: Apprentice
Rating: 0%, 0 votes
Have you checked the latest bios for Sempron support, if you haven't the
latest bios your board may not run a Sempron.
Neil
Was this helpful?
Yes
No
Solution #9
Not Rated)
Lizzy
Rank: Apprentice
Rating: 0%, 0 votes
PC Chips is just plain a bad...
most machines i've worked on that used PC Chips mobo's were unstable
unless i underclocked them...
you should just leave it it 133 mhz if that's what it takes to keep it
stable.
if there is a multiplier setting you can adjust...
you may be able to clock it up a bit faster
Was this helpful?
Yes
No
Solution #10
Not Rated)
pawa
Rank: Apprentice
Rating: 0%, 0 votes
Just installed a Sempron 2800 on a PC CHIPS M825G 333 motherboard.  I
installed Windows just fine, but noticed it was showing an Athlon MP 1600
processor. Cpu Clock was set at 133 on MB, so I changed it to 166.  It now
shows correctly as a Sempron 2800.  Problem is now Windows goes to BSOD.
So I attempted to do a clean install and when it started Windows setup again
BSOd.  Any ideas or do I have something set wrong...
Was this helpful?
Yes
No
Popular Solutions for PC Chips M825G Motherboard
Questions and Unsolved Problems for PC Chips M825G Motherboard
Do you recommend PC Chips M825G Motherboard?
Answer
Answer
Hi, i have a technical problem with one of the slots of the mainboard (grapic card). I like to buy a... (More)
Answer
how do i unlock channels on an ntl set top box?
Answer
i can't install a cpu heat sync because my mobo does'nt have the white square where you put the cpu... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Chips M825G Motherboard:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14909
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
