Question about Shredder Office Equipment & Supplies
Whare you put the oil? - Shredder Office Equipment & Supplies
  • 610 Answers
I put the oil on a piece (5-6 lines of oil across the page) then feed in the paper. or put a thin stream of oil where you feed in the paper.
Posted on Nov 17, 2009
Whare is the oil filter on a buick grand sport
All filters are under the engine. I suggest you look at what an oil filter looks like and get under the car. You can't miss it. Normally, (I say this with hesitation) are under the engine towards the front of grill or on the passenger side. (normally) They can be any color to white, orange, depending on brand that was installed last. But it will look just like the one you purchased to replace it. You also didn't give the year which may have been more helpful.
Jul 31, 2014 | Lisle Swivel Grip Oil / Fuel Filter Wrench...
What can I do
2stroke or 4stroke ? oil in engine or gearbox low ? 2stroke oil low ? if no oil in 4stroke then you will have damaged piston as it needs lubrication but it will have damaged the crank bearings/shells etc ! if 2stroke gear oil then gears and bearings will be damaged , no 2stroke oil will damage piston and crank bearings ! let me know more info and i tell you what to look for !
Nov 11, 2013 | 2009 Yamaha WR125X
Oil leak in 96 c1 series truck
I need to know whare its leaking from what area main baering valve covers is there antifreeze in the oil pull out the dip stick dose if have a foemey white yellow on it
Mar 08, 2012 | Chevrolet C1500 Cars & Trucks
My xv 1100 smokes and fouls plug when it has right amount of oil in
If the oil level is correct, about the only thing remaining is worn rings. You can try another brand of oil and use a heavier oil, but it will always come back to the rings having to be changed in the end.
Mar 11, 2011 | Yamaha XVS 1100 Dragstar Classic...
Whare is the oil sending unit on the 2000 plymouth neon?
in the block on the back near the firewall under the exhaust manifold.
Nov 20, 2010 | 2000 Plymouth Neon
Whare can i finde the speed sensor for my 91 accord and whare can i look to see a diogram of whare its located
Not sure where you can find a picture besides a repair manual, but the sensor is located on the pass side of the car below where the lower radiator hose hooks up to the engine, look straight down you will see a sensor with three wires going into it, two 10mm bolts hold it down.
Apr 28, 2010 | 1991 Honda Accord
Doe i use 10w-30 or 5w-30 oil when changing oil in my 2000 jeep wrangler in-line 6?
Multi viscosity oil use is dependant on the average temperature whare you will be driving. Read the can/bottle for recomended temperature range for the oil you are looking to use.
Aug 01, 2009 | 2000 Jeep Wrangler
Message Ctr and compass area
get the message center to whare it reads change oil soon then push both buttons at same time and hold for 5 seconds
Mar 23, 2009 | 2004 Lincoln Town Car
Oil Leak
sounds like the oil filter housing gasket is leaking. clean the area up real good with some brake clean and then run vehicle for 15 to 30 min and see if u can see whare its coming from. it may also be coming from valve cover gasket.
Nov 19, 2008 | 1994 Ford Crown Victoria
56 people viewed this question
Top Shredder Office Equipment & Supplies Experts
Ross Keen
Dave Reilly
Level 1 Expert
gbob59
Are you a Shredder Office Equipment and Supply Expert? Answer questions, earn points and help others
