Question about LG Washing Machines
LG wm16110fd washer. No lights on front panel. Have checked fuse and filter unit where power cable enters washer all OK, is there a reset button or hidden line fuse behind control panel? Kind regards Gary
tzweeb
  • 318 Answers
SOURCE: push start button on control panel - machine does not start
only 2 things can cause this.
1 the control is set to lock out mode. just hold the lock button for 5 seconds and it should go back to normal mode.
or 2 the controls user interface has an internal failure. its the part that has the switches and tells the computer what to do. either way call whirlpool and see if its still covered by their warranty.
of yeah and the 3rd thing is you have no power to unit. make sure the outlet is good by trying something else in the same outlet, like a light or hairdryer.
Posted on Jan 06, 2009
SOURCE: LG front loading washer is turning itself on,then off
You have a fault microprocessor, or the "Brain" is sporadically faulting... You need to get this looked at... it isn't a minor thing unfortunately... look get a firm "Quote" from a reliable service center man
Posted on Feb 01, 2010
skimbot
  • 5 Answers
SOURCE: TROMM WASHER WM2277HW LG. GET IE ERROR AT BEGINNING OF WASH CYCLE
That noise means it is blocked. Did you get the filters in the back of the machine at the inlets? I've been through heck with this.... check out what finally worked.
IE= Inlet Error. I have struggled with this problem. After much trial and error it appears that it is due to my well water. People who have city water will probably not have this problem with this machine. Well water or hard water buyers beware. This machine is VERY much a primadonna princess capable of stopping your rinse cycle at the slightest imperfections. This is the Princess and the Pea of Washers... but I have a series of possible solutions that will have you appreciating her primadonna superiority once again.
Troubleshooting... Listen.... Does she sound like she is struggling and no water is coming in? If so then it isn't. The cycles will last forever as she makes all sorts of grunting noises. Something is preventing the water from coming in. It could also be that the pressure in to the washer is under 55 psi.
a. I have adjusted the pressure in the pumphouse to allow for minor fluctuations so that the machine will have at least 55 psi.
b. Take off the hot and cold inlet hose and clean the screen at the back of the washer. The two screens are supposed to come out of the male receptacles. They are fragile... beware. I use a squirt bottle/atomizer to clean these screens as mine chipped and will not budge.
c. You can add a screen just off the faucets so that you don't have to move the machine each and every time you get an IE error. This helps but does not solve.
d. I installed a faucet filter that I bought from Home Depot in the PVC sprinkler's section. They are made of a black plastic material and can easily cross thread, so be careful. They look about the size of a one liter container and unscrew midway to reveal a removable cylindrical mesh filter. This makes it possible to widen the surface area where tiny particles can be trapped without totally blocking flow to the inlet sensor. :-) When installing this make sure to completely rinse the hoses, and all screens coming into the machine. I took the shortcut first and thought my idea had failed only to discover that the screen behind the washer was partially blocked.
e. Periodically remove the filter and clean. Depending on the quality of your water, you may need to do this at all the points that have a screen.
I now have a screen washer between the sprinkler system filter and hose and the one that comes installed inside the male ends of the inlets for the water hoses. This has helped enormously.
f. Another possible offender is the soap and softener dispenser. To remove and clean press down on the plastic toggle piece on the soap side, the whole drawer should slide off and clean. Non-HE detergents and softeners can create a buildup of gooey gunk. Just clean it. Inside the drawer space you can clean to increase flow. I use baby wipes.
g. Make sure that the filter on the bottom is free from obstructions. If there is water in the drum, you will be flooded if you remove. This is a last resort after all the inlet lines have been cleaned and cleared.
Note: It doesn't take much to lower the flow of water to the point that this machine will not run. Since you cannot override the computer on it to run a spin cycle or even advance to remove water it can be highly frustrating. I've learned to obey my machine and just clear every last possible inlet.
Best of luck.
Posted on May 30, 2010
MNTECH
  • 1543 Answers
SOURCE: My fronter loader LG is not powering up. My son
OK, let's try this: Open the door and (with an empty washer) give the drum a hard spin (either direction) by hand. This uses the direct drive motor to in effect become a generator, and should light up the control. If control lights up only momentarily, then no line voltage is getting to the display board. I would suspect the line filter first. Take the top cover off by removing the lower screws on the plastic clips on the back side of the washer's top. Stand in front of machine and use the palms of your hands to sharply push back on the L and R edges of the top, about 2 inches, then lift top off. Track power cord into washer and on to a small rectangular box. (the line filter, which contain a non-replaceable fuse) Check if power is going in and comming out (heading for the main board) If power in but no power out, replace filter. After the filter, the power goes to the main board, which is in the top back Left hand corner. It has a plastic cover over it. When the machine is powered up, there is a red LED on the board itself which lights up.
Note: on a working machine which is connected to power, you can do the drum spin and the display board will light and remain on, without touching the power button.
That's about as much help as I can do from here. If you need more help, I suggest you contact an authorized LG servicer in your area. (find one from LG at 800-256-0000)
These are very good machines. I know of one guy, runs 10 loads a day, 365 days a year through his LG. Can't say he's never had a problem, but he is very satisfied and probably does more loads each year than that old Whirlpool did in 20.
Posted on Mar 06, 2011
caroldon
  • 17130 Answers
SOURCE: Kenmore washer model #110.28882790 is
Remove the water line from the INLET valve and start the machine , if there is no proper flow of water then the inlet vavle is not working to open , the filter on the vavle is clogged or the inlet filter is blocked. Also check the voltage on the inlet valve to make sure that the controller unit is outputting correct voltage.
If not replace filter , valve to ensure that the drum get best flow for filling.
Posted on Aug 22, 2011
LG washing machine shuts off randomly, why?
only suggestion, next time it happens, unplug like you've done and then hold in power button for 15 seconds to see if that resets it.
Aug 30, 2015 | LG WM3470HWA Front Load Washer WM3470HWA
LG WM3455H won't turn on.
Unplugging to reset only works when the washer has power and on stand by. Start by checking the fuse on the noise filter, that is were the power cord connects to. If good than your main board is bad.
Apr 06, 2014 | LG Front Load Washer / Dryer Combo...
LG washer model wm2301hw won't turn on
We had the same problem (washer would not turn on). The problem was a small fuse blown in the power noise filter unit. The unit is a plastic block near the top of the washer on the inside - connected to the power cord. It is a very commonly produced unit and goes in a number appliances. The fuse inside fails frequently (so I hear) and is extremely difficult to replace due to the protective-covering material so it's easier to just replace the whole unit. I purchased a replacement unit for about $30.
Very easy fix:
1. Unplug the washing machine.
2. Take off the top of the washing machine (two screws in the back)
3. Identify the noise filter unit (top of washing machine, hanging on the right with the power cord attached to it).
4. Remove with one screw and unplug the two cables going into the noise filter unit. Slide out the unit.
5. Put in new unit. Screw it in, and plug the two cables into it.
6. Put the top of the washing machine back on (not necessary to test if the new unit works)
7. Plug in washer and run.
https://www.encompassparts.com/item/7814463/LG_Electronics/6201EC1006L/Filter_Assembly
http://www.amazon.com/LGE-ZENITH-FILTER-ASSEMBLY-6201EC1006L/dp/B006E7V7DW
Oct 18, 2012 | LG WM2301HW Front Load Washer
My fronter loader LG is not powering up. My son put in a load before going to bed. When we woke up the next morning we realized the washer wouldn't power up and it had flipped the circuit breaker. I...
Mar 05, 2011 | LG WM-2277HW Front Load Washer
Dryer control locked light is on and dryer won't start!
Press the Reset Button for 1 minute see if it resets?
or
Are the lights lights DIM on the interface panel ( front of unit with buttons & lights) If so Turn power off to the dryer then you need to remove the top of the dryer lid off and locate the two ribbon cables that go between the CCU and the interface board. as well as two small ribbon cables between the two parts of the interface panel. use a paper clip or screw driver press on the center tab and reset each cable one at a time. Then turn unit back on and try it again.
if none works it could be CCU or Interface panel
Nov 02, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Lg dle3777w dryer filter light remains on and dryer is not working even after cleaning the filter.
I'm sure you solved the problem but as i had the same problem on my electric LG front loader and saw no response i figured I would leave one for anybody else in the future. My girlfriend told me the dryer would not start and as i looke i saw the panel would not power up, I unplugged the power cord for 5 minutes and the LG reset and the panel was on and reading clean filter after checking the filter which appeared clean I tried to restart the dryer at which time it powered off. I again unplugged the dryer and replugged it and again the display read clean filter. I then gtabbed a phillips #2 and unscrewed the filter lint sceen which had a total of 4 scews in the interior of the dryer holding the filter housing unit. Youll see a piece of the housing unit remains screwed into the washer hooked up to two electrical plugs. Seperate both plugs from the unit and unscrew it and remove the unit youll notice two silver strips on the unit and I'm guessing will be covered with a small amount of lint. Clean the unit with a brush and damp cloth inside and out reattach the unit screw first and housing unit and turn on. If the dryer again turns off unplug and youll see the clean filter light. Simply push the custom program light or anything similar and the panel should start working again. I hope this helps someone.
Aug 08, 2009 | LG DLE3777 Electric Dryer
Is there a fuse on the LG that can go out or be reset. I am getting no power to the panel?
No resetable fuse , trace voltage from power cord to board ,there is a small filter board that sometimes goes.
Jun 25, 2009 | LG WM-2277HW Front Load Washer
LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Jun 21, 2009 | LG WM-2277HW Front Load Washer
LG WD-1290RD FRONT LOAD WASHER/DRYER chimes with blank front panel
Unplug the unit to reset the computer.  Wait 5 minutes.  If the problem still occurs, you will need to have the control board replaced.
May 18, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
97 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
