Question about Gateway M305CRV Notebook
Does vga cable have sound? or do i need an extra
Does vga cable have sound? or do i need an extra cable for it?
  • 2,229 Answers
No, it doesn't.
You will need a separate cable.
Posted on Nov 17, 2009
VGA to HDMI converter connection and set up
Use VGA adapter to HDMI works for video
Sound is carried over stereo cable
What you are doing needs 2 cables
Video cable for video
Sound cable for sound
Using TV for monitor VGA to HDMI 32" at 120 refresh is best dot pitch .
over 32" dot pitch is lower may become grainy resolve place monitor away more from you when using over 32" TV 120 refresh is important
Jul 15, 2016 | Computers & Internet
Vga and sound
Unlike the HDMI cable, VGA will not provide sound, you need some external speakers or use an HDMI cable for video and sound.
May 15, 2014 | Dell Computers & Internet
How to connect laptop to vga projector?
you need a cable. it may be the one that usually connects a computer to a monitor = depending what the input is on the projector but it sounds like an ordinary monitor cable as projector is VGA ( the other type has a digital input at one end ;but Im pretty sure thats not it.) If you have another computer set up just borrow the monitor cable and try it. There's already an input for one end in your laptop if its ok buy an extra cable
Mar 18, 2013 | Lenovo S405 14.0inch Laptop
Vga to hdmi
for vga out from your notebook to hdmi there are several adaptors on the market just google vga hdmi adaptor. they vary in price usually the sound and video a carried on seperate cables so you will have to check what extra cables you need.
I hope this was useful
Feb 28, 2013 | Lenovo Essential G570 43348pu 15. Led...
Monitor has fast moving color bands. Unplugging has not helped, restarting computer has not helped
looks like to video card is on its last leg now.
if your computer has built in vga port, transfer the vga cable from the video card and see if the problem disappear. Or better if you have extra video card replace the old one and see if the problem remains.
Most likely its the video card problem, you can also try fixing the vga cable connected on your video card and monitor. It has two screws on both end that need to be fix.
let me know if this help
Feb 09, 2011 | 3G Technology GM-170 Monitor
I want to connect my laptop to a LG 32ld310.. I have 1 cable VGA-VGA ( and the sound jack to Audio IN ). I got sound, but no image, no signal, even with AV or COMPONENT. Before, I had a cable VGA-HDMI,...
I want to connect my CPU to a LG 32ld310.. I have 1 cable VGA-VGA ( and the sound jack to Audio IN ). I got sound, but no image, no signal, even with AV or COMPONENT.
Before, I had a cable VGA-HDMI, also no signal ( analogical & diginal ).
If I buy a cable VGA ( for CPU ) and 3 jacks ( green, blue, white ) for Component IN; does-it work ??
I need some help.
Dec 23, 2010 | LG Televison & Video
IBM X335
hello, you can only use sound card on it. if you want to use the extra graphic card you will need to disable the Video adapter on the motherboard before the Extra graphic card can work.
Aug 10, 2009 | IBM x335 - Xeon P4 2.0GHz (512KB) - 512MB...
Speakers connected to the flat panel won't work
Don't Connect them to the Monitor Directly.
It will Be easier for you to Connect them TO THE SOUND CARD (back of computer).
Apr 20, 2009 | Dell ADA745 Computer Speakers
13pins "from the inside monitor" "to the VGA 15 pins connector
hai dear,
i checked your problem and found that you open the cover of monitor and you find the two jack of data cable in main pcb and neck card( 2 connector of data cable).plz you cut the connector of data cable and you will find 8 wires in connector.related red(invild extra ground),green(invild extra ground),blue(invild extra ground),black gnd,white,orange,gold(extra gnd) and now you cut the red wire, you will find two wires.so you refix the main red wire pin no-1 of connector and red gnd pin no-6,green main wire pin no-2 and green gnd pin no-7,main blue wire pin no-3 and blue gnd pin no-8.check for the horizental sync and vertical sync wire you should go in main pcb which invild the other connector. there is present in print, h- sync(two wire of h- sync main wire in pin no-13 and other pin no-5) and ver.-sync wire in pin no-14.first you will check the whose h-sync and vert-sync in color and now finally other wires will fix any pin of connector.
Apr 03, 2008 | SAMTRON 55V 15" CRT Monitor
Gateway M305CRV Notebook Logo
228 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
