Question about Bissell LiftOff Revolution Pet Vac 37602 Vacuum
It won't pick up. I cleaned all of the filters. what next?
  • 701 Answers
I would try changing the belt. A worn, stretched or broken belt can cause the vacuum to not pick up well. Here is a link to the belt you need and the manual which has instructions:
Bissell Lift-Off Revolution belts and manual
Posted on Nov 17, 2009
We bought the Dyson DC66 a few weeks ago and all of a sudden it will not pick up dog hair or clean the carpets properly
The filters probably need cleaning. The filters on new Dysons block very quickly initially because of how much they pick up. Youll probably remember the feelings of astonishment and shame at how much dirt was picked up on first use. I know I was
Mar 03, 2015 | Dyson Vacuums
Roomba is squealing
Sounds like it needs to be taken apart and cleaned. Turn it over on it's back. Press down and release the two buttons that hold the cover. Take out the two spinning bars, clean all hair and thread off. Check ends of the bars to remove hair there. Reinsert bars noting the one end with square has to be fitted in properly for each bar. Often at this point you'll find something too pick or heavy to make it into the filter compartment, just remove it and replace cover. Next open filter compartment, Remove filter and clean.
Jun 29, 2014 | iRobot Roomba 530 Robotic Vacuum
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
I have a hoover steam vac F5915-900 I bought at walmart about 4 months ago. I used it about 5 times in differnet rooms. Today when I went to use it It won;t pick up the dirty water. I cleaned the filter...
Make sure the suction area of the face plate is clear of all debris. If anything else, call the number on the machine, it's still under warrantee if the machine doesn't work from normal use.
Sep 05, 2011 | Hoover Vacuums
My henry wont pick up any dirt and how do i change the filter ...
The filter on a Henry does not need changing (unless torn or
damaged). It simply neeeds cleaning, either by vacuuming with
another machines or brushing clean. For maximum suction, air
must be able to flow through it. Next, change the bag. Finally
remove hoses and pipes etc and switch on, the suction that you can feel by putting your hand against his "nose", is the same suction that you should feel when pipes are back on.
If it is not, then you will have a blockage, usually in the flexi hose, but drop a coin through in order to establish where.
Feb 07, 2011 | Numatic Henry Bagged Canister Vacuum
Do07 not picking up out only suction with hose
Check and clean filters, looking at it from front filter is located in base on right hand side, take out filter clean sponge and let it dry overnight. see here page 5
http://www.dysonmedic.com/PDF%20docs/dyson_dc07_owners_manual.pdf
Mar 01, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Not picking up dirt
clean ALL the filters or buy new one it would be better to buy all new filters also check for clogs in the vacuum also check the belt if the belt is broken it will not pick up much 1. check all tubes for clogs if still dose not pick up 2.check the belt and replace if broken if it still dose not pick up 3.do the filters that worked on my bissell
Feb 02, 2010 | Bissell 6594 PowerForce Bagless Upright...
My bissel vacume was not picking up the dirt on the carpet. So I found that the hose was clogged. I unclogged it but the vacume still is not picking up the dirt. I also changed the filters.
I found out that if you remove the front filter holder, tip vacuum back and look down inside. Sometimes there is hair caught back in there and you won't get suction. I had to use something long, knife, very long type tweezers, to pull all the hair out. Worked great after that. About half way through vacuuming I will stop and remove the foam rubber filter and clean it. Oh yea, you will have to use a flashlight to look down inside to see all the hair caught behind the foam rubber filter cup.
Dec 14, 2009 | Bissell 6594 PowerForce Bagless Upright...
My Dyson vacum's suction power apperas weaker the usual.
You might want to check three things. First, is the washable filter under the dust bin clean. Take off the dust bin, open the filter cover and check the washable filter. Wash it while you are at it, let it dry 12 hours. Next, make sure the gasket that seals the flip open door to the center of the dust bin is on correctly. Owner's manual shows the correct way and you want to be sure the ribs on the gasket are seated in the grooves on the center tube in the dust bin (this will also cause your washable filter to clog really badly if not on correctly. Third, your cyclone could be plugged with hair or something. This will happen if you pick up something wet, or damp or clean up lots of pet hair. Here's a good site on how to take your cyclone apart and clean it. http://www.exonotes.com/content/node/4
Oct 06, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Does not pick up anything and makes weird noise
I had the same problem with very low suction and weird noises, the orange light kept coming on.
I always empty the cannister and clean out any hair from the roller. I would take the filter outside and clean it as good as possible. I don't know if I can post a picture on here or not, but I will try. It is unbelievable how much hair comes from long haired girls. Particulary my daughter. Back to the point...
I was cleaning out a drawer one day and came across an extra filter. I put the new filter on, and its like brand new again!
Man, did I feel like an idiot! Just needed a new filter.
Oct 13, 2007 | Eureka 431A Optima Bagless Upright Vacuum
Bissell LiftOff Revolution Pet Vac 37602 Vacuum Logo
389 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
